  1. There are batch files to download video and audio streams, but I haven't seen any for subtitle streams.
    In order to download subtitles, sometimes it takes long to write yt-dlp command lines.
    To make the things simplier and faster, I need a batch file with two functions - just as video-audio downloading batch files.
    1- to list all the subtitles from a specific MPD link given
    2- to choose subtitles for downloading and saving to a specific folder location
  2. Glad to see another stupid troll is banned, its name was @Gen99 - who tried to hijack this thread with silly links.
    I am sure it will get another nickname and continue to attack other guys who need help. Because that's its way of life. It loves to give headache to people. I say "it", not he or she. Not a human. Just a meaningless creature.
  3. Using a batch will be an extra step (unless you want them all)
    You will have to use yt-dlp to list the available formats for subs.
    Then you will have to select the ones you want.
    Then you will have to write a bat
    https://github.com/yt-dlp/yt-dlp#subtitle-options
    Why dont you just incorporate the subs download along with the video / audio you want to download ?
    Its easy to do. And anyone will help you with this syntax.
  4. Originally Posted by codehound View Post
    "Easy" is relative.
    The famous batch called "Encrypted Video Downloader II" does not have subtitle downloading option.
    I know I will have to use yt-dlp to list and download the subs. The thing was how to make it faster with a batch file. "Faster" = "writing command lines as low as possible".
    Just double click on a batch, copy&paste the mpd link there, then let the batch list all subtitles automatically, then choose the needed subtitle just writing "en" or "fr", then download begins, that's what I want.
    Feb 2022
    Search the forum first!
    You don't have to make a batch file. You can make python create a list of urls for yt-dlp to download one at a time.
    I have a program getUK.py which will greedy download from some of the main UK tv providers. Feel free to adapt to your needs
    from __future__ import print_function
    from bs4 import BeautifulSoup
    import requests
    import os
    import re
    import os.path
    import json
    # need yt-dlp and aria2c as external programs in PATH
    # pip package updates have been known to break this program!!
    # Some programmes on STV are now encrypted - this will not work with those
    my_set = set() #  sets do not allow duplicates
    # thanks;-
    # https://hackersandslackers.com/extract-data-from-complex-json-python/
    # must use json.loads to provide this fn with a dict object
    def json_extract(obj, key):
        """Recursively fetch values from nested JSON."""
        arr = []
        def extract(obj, arr, key):
            """Recursively search for values of key in JSON tree."""
            if isinstance(obj, dict):
                for k, v in obj.items():
                    if isinstance(v, (dict, list)):
                        extract(v, arr, key)
                    elif k == key:
                        arr.append(v)
            elif isinstance(obj, list):
                for item in obj:
                    extract(item, arr, key)
            return arr
        values = extract(obj, arr, key)
        # return list object
        return values
    def getBBCMedia(url):
        # creates a set of urls for yt-dlp to use
        soup = BeautifulSoup(requests.get(url).text, 'lxml')
        domain = ("https://" + url.split('/')[-5])
        for link in soup.find_all('a'):
            if 'href' in link.attrs and 'episode' in link.attrs['href']:
                my_set.add(domain + link.attrs['href'] + '\r')
        for x in my_set:
            if re.search("^.*/ad/.*$", x):
                continue
            str_val = "".join(x)
            print(str_val)
        getMedia(my_set)
    def getSTVSummaryMedia(url):
        # stv links are relative, thus capture domain
        domain = ("https://" + url.split('/')[2])
        # specific json code on stv pages in __NEXT_DATA__ -- May change!!!!!
        my_json = json.loads(soup.find(id="__NEXT_DATA__").get_text())
        # print(f"jason data collected = {my_json}")  # uncomment  for testing correct json returned
        my_values = json_extract(my_json, 'link')
        # my_values is a list
        # remove summary urls and duplicate items in list by
        # adding to a set,  my_set
        for x in my_values:
            if re.search('summary', x):
                pass
            else:
                my_set.add(f'{domain}{x}')
        getMedia(my_set)
    def getITVMedia(url):
        series = (url.split('/')[-2])
            if 'href' in link.attrs and series in link.attrs['href']:
                if re.search("^.*facebook.*$", str(link.attrs)):
                    continue
                if re.search("^.*twitter.*$", str(link.attrs)):
                    continue
                ''' if prog ref too short '''
                # if not re.search("[a-zA-Z0-9]{8,11}$", str(link.attrs)):
                ''' close file and return  '''
                my_set.add(link.attrs['href'] + '\r')
        getMedia(my_set)
    def getMedia(my_set):
        for x in my_set:
            os.system(f"yt-dlp   --downloader aria2c --convert-subs srt --embed-subs {x}")
    def getSingleMedia(url):
        os.system(f"yt-dlp   --downloader aria2c --convert-subs srt --embed-subs  {url}")
    def delineate(url):
        if re.search(f"bbc.co.uk", url):
            # pass url to getBBCMedia
            print("BBC media")
            return getBBCMedia(url)
        if re.search(f"itv.com", url):
            # pass url to getITVMedia
            print('ITV media')
            return getITVMedia(url)
        if re.search(f"stv.tv", url) and re.search('summary', url):
            # pass url to getStv
            return getSTVSummaryMedia(url)
        else:
            print('getting single media')
            return getSingleMedia(url)
    if __name__ == '__main__':
        from sys import argv
        if argv and len(argv) > 1:
            # print(f"{argv[1]}")
            delineate(argv[1])
        else:
            print("Usage: getUK requires a URL to be passed as an argument \n \
            URLs currently processed are BBC, ITV  and STV ")
