Page 2 of 4
FirstFirst 1 2 3 4 LastLast
Results 31 to 60 of 115
  1. Originally Posted by cedric8528 View Post
    What browser do you use ?
    brave (chrome engine) on Ubuntu.
  2. thank you Ecolek
    I am going to test.
  3. Originally Posted by ecolek View Post
    Any hint, please?
    Subs seem to be here
    [Attachment 66152 - Click to enlarge]
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
  4. With setting similar filter I am getting all these stream items that you get. Any extra setting needed in Inspect tool?
  5. Originally Posted by ecolek View Post
    No extra setting. I wouldn't know why you aren't getting what I get. Tried refreshing? Are you using Chrome? Maybe try new account?
    This is the full url for the subtitles
    https://www.rtbf.be/embed/m/api/track?mediaId=2921940&version=frasdh
    So, try accessing it manually?
    And it looks generic except for Id=xxx which matches the exact numbers as the video URL so you can adjust it for your other videos.
    click click2
  6. 'frasdh' turned out to be a good keyword, restart of the movie gave me VTT output.
    Thanks Vegeta for a good hint!
  7. Hello,
    I'm trying to download this video (https://www.rtbf.be/auvio/detail_les-combattantes?id=2938170) with TVDownlloader but I got the same error message as ecolek on 22th July.
    I'm only able to downoad the subtitles. Anyone can solve this issue please?
    Thanks!
    Flo
  8. Originally Posted by Tiflo 62 View Post
    Hello,
    Thanks!
    Flo
    Here's your episode
    https://we.tl/t-xihnCXQMvQ
    click click2
  9. Wow, thanks !
    How do you proceed please? I will apply your method on episode #2
  10. EP2 https://www.rtbf.be/auvio/detail_les-combattantes?id=2938179
    download
    yt-dlp --allow-u "https://c9851ec-az-westeurope.fsly.cdn.ebsd.ericsson.net/rtbf/auvio/assets/2938179_6BA97Bb/materials/Ku0K3NxUTx_6BA97Bb/vod-idx-2.ism/.mpd?"
    key
    22f0fda04ebb42e0b415ed64944a8655:015ca014b010d5ae3d808aa7791182d7
  11. Thank you for your help lomero!
    Video and audio downloaded Now I'm reading tutos about how to find this part of the key
    key
    and how to decrypt the files. I used this cmd but it failed. Still learning
    mp4decrypt --key 22f0fda04ebb42e0b415ed64944a8655:015ca014b010d5ae3d808aa7791182d7 input.mp4 decrypted.mp4
    ERROR: cannot open input file (input.mp4) -4
  12. Originally Posted by Tiflo 62 View Post
    you need to change input.mp4 to your actual downloaded filename and extension
    click click2
  13. I tested with the original filename ".mpd [.mpd].fvideo=5200000.mp4" and even rename it to "inpunt.mp4 and same result.
  14. rename your downloaded file as input.mp4
    your issue is wrong filename inpunt and mp4decrypt don't find your file ...
  15. I tested with the original filename ".mpd [.mpd].fvideo=5200000.mp4" and even rename it to "inpunt.mp4 and same result.
    Already done and it failed.
    I even try with the file posted by avq here: https://forum.videohelp.com/threads/400424-Downloading-DRM-protected-video-and-decrypt...th-a-known-key
  16. but you have mp4decrypt.exe AND your video.mp4 on same folder yes?
    and you run the command from the folder where you have mp4decrypt.exe AND your video.mp4 yes?
    if all if it's all yes, and you're sure of what you've done, then you just have to use shaka packager
  17. or also: go here http://www.dvdvideomedia.com/download.html
    download Free Video Cutter Joiner (it's free)
    open your video and trim a small part (1-2 minute of your video). upload to some server and share link. we need to test mp4decrypt command ...
  18. Originally Posted by Tiflo 62 View Post
    You must put the input.mp4 file in the same folder of the mp4decryt file, then it can see the file, check the location of the file, then check the file name, if not sure type the command in notepad then copy paste to commandline to run
  19. Thank you for your help, it works!
    The cmd was launched in a subfolder and not where mp4decrypt is...
    Now I'll try to get the keys with getwvkeys and I could do it all on my own for the next episodes
  20. Originally Posted by Tiflo 62 View Post
    Thank you for your help.
    Video to decrypt (input.mp4) and mp4decrypt.exe are in the same folder.
    [Attachment 66911 - Click to enlarge]
    It still fails so i'll test with ffmpeg.
    Ah you forgot the -- before the key argument
    mp4decrypt.exe --key keyid:key input.mp4 decrypted.mp4
    try again
  21. wrong command ... --key
    you have used key only
    look your right post#41 for mp4decrypt ...
  22. Typing error in this example I edited my post few seconds after seeing my error and correct it but you're quick
    My first mistake is to have launched the cmd into Bonto folder instead of the bin one.
    I'm waiting for my verification on getwvkeys now. All is OK, thanks for your help!
  23. Originally Posted by Tiflo 62 View Post
    No problems, but I think you should ask for help here than playing their weird logic game on the discord server.
  24. Originally Posted by gadumuc View Post
    If you didn't succeed to get in, there's no need to discourage others to try.
    click click2
  25. Originally Posted by [ss]vegeta View Post
    Generally the help from folks here are very quick and details, and you also a very helpful guy Vegeta, helping lots of folks, I read through a lot here and got what I want so no hard feeling toward the folks over discord, just that screening a little bit off, just say it like it is. But that won't discourage anyone, just a few clicks away to get in.
    I got your point though, peace out.
  26. Originally Posted by gadumuc View Post
    I get your point too. Thanks for the kind words.
    click click2
  27. I'm working on widevine request with python.
    I have the PSSH, the license Url but I have trouble with Headers. I copied everything from accept: */* to the bottom (using quotes when necessary) but I got an error (Method GET not allowed...). What are your settings please?
  28. Originally Posted by Tiflo 62 View Post
    License request is method POST not method GET
  29. I know but that's the error I got
    The license url used is: https://rbm-rtbf.live.ott.irdeto.com/licenseServer/widevine/v1/rbm-rtbf/license
  30. Did you write the python code yourself?
    Would be easier for people to help if you paste it fully or at least the relevant part
