Results 1 to 15 of 15
    Feb 2022
    Search the forum first!
    I went here:-
    https://player.stv.tv/episode/48d2/sony-commons
    to get this:-
    https://manifest.prod.boltdns.net/manifest/v1/dash/live-baseurl/bccenc/6204867266001/b...QzMzdkNDNjNg==
    and used yt-dlp to download an mp4 and m4a file of 563 parts
    The manifest response had this between <cenc: pssh>:-
    AAAAVnBzc2gAAAAA7e+LqXnWSs6jyCfc1R0h7QAAADYIARIQr3ljevwPRLO70nM7c1OFPRoNd2lkZXZpbmVfdGVzdCIIMTIzNDU2NzgyB2RlZmF1bHQ=
    which I used at getwvkeys - to provide:-
    af79637afc0f44b3bbd2733b7353853d:25a89c8c61df0f8f760d3fb5f2b3543c
    Here I get stuck because any combination I seem to try with bento4 mp4decrypt does nothing.
    typically:_
    ./mp4decrypt --show-progress --key 1:25a89c8c61df0f8f760d3fb5f2b3543c /home/angela/input.mp4 /homeangela/output.mp4
    writes a zero byte output file.
    Where am I going wrong?
    I made prat fall. I'd moved the downloaded mp4 with a long file name to something shorter ~ input.mp4 Somehow that file became zero bytes?? Just re-downloased and it decrypted fine. I'll leave this here with egg on my face!
  2. Correct command-line:
    mp4decrypt --key af79637afc0f44b3bbd2733b7353853d:25a89c8c61df0f8f7 60d3fb5f2b3543c input.mp4 output.mp4
    Place "mp4decrypt.exe" and "input.mp4" in the same folder.
    Feb 2022
    Thanks, but as I already noted in my edit, my line eventually worked and decoded fine. Programs can reference files anywhere on the file system - at least in Linux.
    Feb 2022
    So flushed with success I went on to episode 2!
    And got this with three sets of keyid:keys and none seem work.
    [Attachment 63468 - Click to enlarge]
    And @ridibunda suggested the keys in the form <KID:KEY> whereas i found only <1:KEY> to work - I'm on linux - is mp4decrypt different in this incarnation?
    Now thoroughly confused.
    Feb 2022
    Decrypting without writing KID, that's interesting
    usage: mp4decrypt [options] <input> <output>
    Options are:
    --show-progress : show progress details
    --key <id>:<k>
    <id> is either a track ID in decimal or a 128-bit KID in hex,
    <k> is a 128-bit key in hex
    (several --key options can be used, one for each track or KID)
    note: for dcf files, use 1 as the track index
    note: for Marlin IPMP/ACGK, use 0 as the track ID
    note: KIDs are only applicable to some encryption methods like MPEG-CENC
    --fragments-info <filename>
    Decrypt the fragments read from <input>, with track info read
    from <filename>.
  6. Originally Posted by A_n_g_e_l_a View Post
    Keys are from the wrong license server, untick cache tick box on ghosts site and try again
    Feb 2022
    Thanks! That unnoticed check-box has been driving me mad.
  8. Do not send me DM's
    Dec 2021
    Tórshavn
    on linux
    mp4decrypt --key 1:<key> <encrypted file> <decrypted name>
    Is standard. It's confusing I know, and I've had to show exampes to others who refuse to believe it's the right syntax. <kid:key> may work for windows users, but <1:key> is the linux way. Especially with mp4decrypt, in fact all the bento4 tools, added to path.
  9. Originally Posted by Sorenb View Post
    --key <id>:<k>
    on linux
    As A_n_g_e_l_a posted, the id can be either specified by the track id or the kid in hex.
    the majority of times i decrypt it is with the kid:key not 1:key and thats on linux.
    there are some sites that you need to use 1:key as the kid doesnt match whats in the encrypted file but the key still decrypts but theyre in the minority.
    the other problem with using 1:key is that if the key is incorrect you wont get a notification saying the decryption has failed and if you run mp4info on the output file, it doesnt show the [ENCRYPTED] tag, so you assume that its been decrypted but then you will get errors when trying to mux it.
    At least with the kid:key method it will still show the [ENCRYPTED] tag if the kid doesnt match.
    id be using kid:key first on either windows or linux and only using 1:key on specific sites or for troubleshooting/testing.
    Feb 2022
    I think I got lucky with my first decrypt using 1:key. I hadn't understood Ghost's site so hadn't set everything there correctly. But my first series of attempts finally worked with 1:key. KID:KEY didn't seem to work at all. When I sent my Ghost query properly the full KiD:Key worked.
    I moved on to Channel 5 and surprised myself when that worked too!
    Now pondering what is needed for All4; happy days!
  11. Originally Posted by A_n_g_e_l_a View Post
    http://getwvkeys.cc/scripts
    Feb 2022
    Ah! Thanks!!
  13. Do not send me DM's
    Dec 2021
    Tórshavn
    --key <id>:<k>
    on linux
    All true, but I've repeatedly faced
    mp4decrypt --key <kid:key> <encrypted file> <decrypted file>
    not work at all with content from all4, rte, ITV and ABC iView (from memory.)
    instead
    mp4decrypt --key 1:<key> <encrypted file> <decrypted file>
    worked, with a variance of the integer after --key on ABC iView.
  14. Originally Posted by Sorenb View Post
    instead
    wow, interesting.
    i just grabbed some stuff last night from abc iview and it went fine with kid:key and it works fine for me for all4 too.
    but whatever works for you
