Page 1 of 3
1 2 3 LastLast
Results 1 to 30 of 75
  1. How do I download videos from this site https://player.pl/? I tried through yt-dlp and found the dash file using the stream detector, but I can't download it. Need to use VPN Poland.
    The show:
     https://player.pl/seriale-online/kontrola-odcinki,32955/odcinek-1,S03E01,230056
    The dash file:
    https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd?indexMode=&dummyfile=
    Any tips please
  2. yt-dlp --allow-u "mpd url"
    https://github.com/yt-dlp/yt-dlp#deprecated-options
    under developer options:
    --allow-unplayable-formats List unplayable formats also
    you could have found it by searching this forum too....
  3. Originally Posted by ElCap View Post
    It's not works for me
    it's says
    C:\Ffmpeg>yt-dlp --allow-u "https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd"
    WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging.
             If you experience any issues while using this option, DO NOT open a bug report
    [generic] playlist: Requesting header
    WARNING: [generic] Could not send HEAD request to https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd: HTTP Error 404: Not Found
    [generic] playlist: Downloading webpage
    ERROR: [generic] Unable to download webpage: HTTP Error 404: Not Found (caused by <HTTPError 404: 'Not Found'>); please report this issue on  https://github.com/yt-dlp/yt-dlp , filling out the "Broken site" issue template properly. Confirm you are on the latest version using -U (caused by <HTTPError 404: 'Not Found'>); please report this issue on  https://github.com/yt-dlp/yt-dlp , filling out the "Broken site" issue template properly. Confirm you are on the latest version using -U
  4. Anyone?
  5. Copy the whole url and put it in quotes, including the stuff after mpd
  6. Originally Posted by ElCap View Post
    I tried that
    C:\Ffmpeg>yt-dlp --allow-u "https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd?indexMode=&dummyfile="
    WARNING: [generic] Could not send HEAD request to https://player.pl/seriale-online/kontrola-odcinki,32955/odcinek-1,S03E01,230056 https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd?indexMode=&dummyfile=: HTTP Error 301: The HTTP server returned a redirect error that would lead to an infinite loop.
    The last 30x error message was:
    Moved Permanently
    ERROR: [generic] Unable to download webpage: HTTP Error 301: The HTTP server returned a redirect error that would lead to an infinite loop.
    Moved Permanently (caused by <HTTPError 301: 'The HTTP server returned a redirect error that would lead to an infinite loop.\nThe last 30x error message was:\nMoved Permanently'>); please report this issue on  https://github.com/yt-dlp/yt-dlp , filling out the "Broken site" issue template properly. Confirm you are on the latest version using -U (caused by <HTTPError 301: 'The HTTP server returned a redirect error that would lead to an infinite loop.\nThe last 30x error message was:\nMoved Permanently'>); please report this issue on  https://github.com/yt-dlp/yt-dlp , filling out the "Broken site" issue template properly. Confirm you are on the latest version using -U
  7. OK, I figured it out, but it doesn't show the video, just a shell file and a dark screen. any tips?
  8. works for me with polish vpn
    >yt-dlp --allow-u -F "https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd?indexMode=&dummyfile="
    WARNING: [generic] Falling back on generic information extractor.
    [generic] playlist: Extracting information
    [info] Available formats for playlist:
    ID EXT RESOLUTION FPS │   TBR PROTO │ VCODEC        VBR ACODEC      ABR     ASR MORE INFO
    6  m4a audio only     │  128k dash  │ audio only        mp4a.40.2  128k 48000Hz [pol] DASH audio, m4a_dash
    4  mp4 320x180     25 │  240k dash  │ avc1.64000c  240k video only              DASH video, mp4_dash
    2  mp4 640x360     25 │  500k dash  │ avc1.64001e  500k video only              DASH video, mp4_dash
    1  mp4 960x540     25 │  800k dash  │ avc1.64001f  800k video only              DASH video, mp4_dash
    5  mp4 1024x576    25 │ 1800k dash  │ avc1.64001f 1800k video only              DASH video, mp4_dash
    3  mp4 1280x720    25 │ 2800k dash  │ avc1.64001f 2800k video only              DASH video, mp4_dash
    What version is your yt-dlp?
    >yt-dlp --version
    2022.02.04
  9. Originally Posted by jessezveneberg View Post
    im not sure what a shell file and a dark screen means, but the video is encrypted, yt-dlp wont decrypt it for you.
  10. same as yours, then how do I download the playlist? I've tried and it doesn't work, nothing works
  11. Originally Posted by ElCap View Post
    Then there are no more questions. I don't know how to decrypt the file.
  12. Originally Posted by jessezveneberg View Post
    The show:
    The dash file:
    Any tips please
    The player.pl website uses drm like most vods in the world.
    The video can be downloaded but it is encrypted and you need a key to decrypt it.
    Currently, there is no public way to extract keys, each shared method works for some time and is patched by e.g. Google
  13. Originally Posted by jessezveneberg View Post
    You need mp4decrypt.exe
    You can download from here
    https://we.tl/t-k2wCLZPNyh
    Put it in a folder
    Open cmd in that folder by typing cmd in the address bar up there.
    Then in cmd you type
    mp4decrypt.exe --key b4b90d8263349248abb8150444765542:bd0cecc2f163a6547a512f46820bf4be "filename.mp4" "decrypted.mp4"
    You change filename.mp4 with... the actual file name.
    This key works for first episode only.
    Key for 2nd episode
    32e81d28cec1214685a8c61f182eb334:29999a5c7acbedf44147f9a030288bc9
    click click2
    If I/my posts ever helped you, and you want to give back, send me a private message!
    Feb 2022
    Poland
    Put it in a folder
    Key for 2nd episode
    how to find the keys ?
  15. Originally Posted by [ss]vegeta View Post
    Put it in a folder
    Key for 2nd episode
    where did you get the video code? After --key where did you get?
  16. Originally Posted by jessezveneberg View Post
    Put it in a folder
    Key for 2nd episode
    I figured out where the error is, but where did you get the key?
    and I tried it again, but it didn't work for me
    C:\Ffmpeg>yt-dlp --allow-u "https://n-22-6.dcs.redcdn.pl/dash/o2/tvnplayer/vod/22_400_29890_0001/LIBCODER_SMOOTH_720_PL/9e39317f-8a87-49c6-874b-bad8d31c2dcc/playlist.ism/playlist.mpd?indexMode=&dummyfile=" -o video.mp4
    [info] playlist: Downloading 1 format(s): 3+6
    WARNING: You have requested merging of multiple formats while also allowing unplayable formats to be downloaded. The formats won't be merged to prevent data corruption.
    [dashsegments] Total fragments: 324
    [download] Destination: video.f3.mp4
    [download] 100% of 217.75MiB in 03:00
    [download] Destination: video.f6.m4a
    [download] 100% of 10.33MiB in 01:23
    C:\Ffmpeg>mp4decrypt.exe --key b4b90d8263349248abb8150444765542:bd0cecc2f163a6547a512f46820bf4be "video.mp4" "decrypted.mp4"
    ERROR: cannot open input file (video.mp4) -4
  17. Cmon dude, "video.mp4" is the file that you downloaded in yt-dlp, ie. video.f3.mp4
    Youll probably need to do it for the audio file too, video.f6.m4a
  18. Originally Posted by ElCap View Post
    Yes, I figured it out, but where did the key come from? what app/extension?
  19. Anyone?
  20. no app or ext get file for you ...
    you have to use your head to get them. but you are too on high seas to do this ...
    read this forum and maybe in a while you will understand how to get those keys
  21. Originally Posted by lomero View Post
    I've been reading this forum for the second year running, but still haven't figured out where to get these keys. maybe send me an ACTUAL thread that talks about it?
  22. Originally Posted by ElCap View Post
    its literally the most recent thread with a reply after this one....
    https://forum.videohelp.com/threads/401717-How-are-you-going-to-respond-to-widevine-l3...th-at-May-31st
    I tried widenine l3 but it didn't work for me, I didn't understand how to work with nodrm
  23. Originally Posted by jessezveneberg View Post
    Here you go, in under a minute. Watch closely and slowly.
    https://streamable.com/ysyttn
    For you to get that "gibberish" in console, init data, you need to install TamperMonkey add on and add this script to it
    // ==UserScript==
    // @name         EME2
    // @version      0.6
    // @match        *://*/*
    // @match        http://ss-cdn1.blim.com/
    // @run-at       document-start
    // @grant        none
    // ==/UserScript==
    (async () => {
        const indent = (s,n=4) => s.split('\n').map(l=>Array(n).fill(' ').join('')+l).join('\n');
        const b64 = {
            decode: s => Uint8Array.from(atob(s), c => c.charCodeAt(0)),
            encode: b => btoa(String.fromCharCode(...new Uint8Array(b)))
        const fnproxy = (object, func) => new Proxy(object, { apply: func });
        const proxy = (object, key, func) => Object.defineProperty(object, key, {
            value: fnproxy(object[key], func)
            proxy(MediaKeySession.prototype, 'generateRequest', async (_target, _this, _args) => {
            const [initDataType, initData] = _args;
            console.groupCollapsed(
                `[EME] MediaKeySession::generateRequest\n` +
                `    Session ID: ${_this.sessionId || '(not available)'}\n` +
                `    Init Data Type: ${initDataType}\n` +
                `    Init Data: ${b64.encode(initData)}`
            console.trace();
            console.groupEnd();
            return _target.apply(_this, _args);
    click click2
  24. Originally Posted by [ss]vegeta View Post
    // ==UserScript==
    // @name         EME2
    // @version      0.6
    // @match        *://*/*
    // @grant        none
    // ==/UserScript==
    (async () => {
        const b64 = {
            console.trace();
            console.groupEnd();
    tampermonkey doesn't work correctly for me for some reason. i have no idea why
  25. Originally Posted by jessezveneberg View Post
    You are in the sources tab.
    click click2
  26. Originally Posted by [ss]vegeta View Post
    thank you so much for your time and help!
  27. A little modified from: https://forum.videohelp.com/threads/404730-How-do-I-download-episodes-from-player-pl#post2647755
    so it will just prompt the PSSH instead of opening the console
    // ==UserScript==
    // @name        EME PSSH Extractor
    // @version      0.7
    // @match        *://*/*
    // @grant        none
    // @description  Extract and prompt PSSH/Init Data from DRM sites
    // ==/UserScript==
    (async () => {
        const b64 = {
            var pssh = b64.encode(initData);
                `    Init Data: ${pssh}`
            console.trace();
            console.groupEnd();
            prompt("PSSH", pssh);
    Here with automatic copy to clipboard
    // ==UserScript==
    // @name         EME PSSH Extractor2
    // @version      0.7
    // @match        *://*/*
    // @grant        none
    // @description  Extract and automatic copy to clipboard PSSH/Init Data from DRM sites
    // ==/UserScript==
    (async () => {
        const b64 = {
            console.trace();
            console.groupEnd();
            if (pssh){
                copyToClipboard(pssh);
                alert(`${pssh}\n\nPSSH has been copied to clipboard`);
            }else{
                alert("PSSH is empty");
         function copyToClipboard(text) {
            var dummy = document.createElement("textarea");
            document.body.appendChild(dummy);
            dummy.value = text;
            dummy.select();
            document.execCommand("copy");
            document.body.removeChild(dummy);
  28. nice zackmark29
    but when paste clipboard is empty ...
  29. Originally Posted by lomero View Post
    nice zackmark29
    Of course you need to copy manually =D
    it doesn't have clipboard function (No need)
