Results 1 to 19 of 19
  1. Hi eveybody
    I would like to download videos from canalplus (french), they do many politics debate that they unfortunately remove very fast (unlike most of other french channels)
    So, I would love to know how to download videos from their site
    Here is a link for example :
    https://www.canalplus.com/divertissement/le-gros-clash-dans-balance-ton-post-entre-eri...17338596_50013
    I tried everything, nothing worked...
    Thank you very much
  2. Code:
    yt-dlp  -F  https://hssodcplus-s.akamaihd.net/ondemand/playready/wildmoka/d8wimo/wildmoka.com_1120651928291/1047841/wildmoka-com-1120651928291.ism/manifest
    yt-dlp  -f Video-3400+audio_fre-128  https://hssodcplus-s.akamaihd.net/ondemand/playready/wildmoka/d8wimo/wildmoka.com_1120651928291/1047841/wildmoka-com-1120651928291.ism/manifest
    ffmpeg -i your_file.ismv -codec copy output.mp4
  3. @ mister_ nex
    you have forget to give key
    @ ElMagnificato
    need login to play video
  4. Originally Posted by lomero View Post
    @ mister_ nex
    @ ElMagnificato
    No, this video on canalplus website is not encrypted. Some videos are widevine encrypted on mycanal, other are not. For replays like this (C8), videos are not encrypted.
    @ElMagnificato
    A simple way to download NON ENCRYPTED videos on mycanal :
    1. Download yt-dlp and ffmpeg on your PC, and put both in the same folder (let's call it "mycanal")
    2. Open Notepad (Notepad++ ou Bloc-notes) and paste the following script :
    @echo off
    set /p episode=  "File name (without extension) : "
    set /p url_manifest=  "Manifest .mpd or .ism URL : "
    yt-dlp -f best --allow-unplayable-formats "%url_manifest%" -o video_decrypted.mp4
    yt-dlp -f bestaudio --allow-unplayable-formats "%url_manifest%" -o audio_encrypted.mp4
    ffmpeg -i video_decrypted.mp4 -i audio_decrypted.mp4 -c:v copy -c:a ac3 %episode%.mkv && del video_encrypted.mp4 video_decrypted.mp4 audio_encrypted.mp4 audio_decrypted.mp4
    pause
    3. Save the file as .bat INTO THE SAME FOLDER "mycanal"
    4. Open the .bat file, and enter the file name and your video's .ism URL
    5. Amuse-toi
  5. fair observation @mathieuthibault.
    in fact i did not download the video, nor checked if it had DRM. mine was just a bad joke ...
    thanks for your clarification.
  6. https://forum.videohelp.com/threads/403981-How-to-download-videos-from-Canalplus#post2639899
    tried to use your batch file but I get an error
    D:\video>download_ism_manifest.bat
    File name (without extension) : my_video
    Manifest .mpd or .ism URL : https://hssodcplus-s.akamaihd.net/ondemand/playready/wildmoka/d8wimo/wildmoka.com_1120651928291/1047841/wildmoka-com-1120651928291.ism/manifest
    WARNING: You have asked for UNPLAYABLE formats to be listed/downloaded. This is a developer option intended for debugging.
             If you experience any issues while using this option, DO NOT open a bug report
    [generic] manifest: Requesting header
    WARNING: [generic] Falling back on generic information extractor.
    [generic] manifest: Downloading webpage
    [generic] manifest: Extracting information
    ERROR: [generic] manifest: Requested format is not available
    ffmpeg version 3.3.2 Copyright (c) 2000-2017 the FFmpeg developers
      built with gcc 7.1.0 (GCC)
      configuration: --enable-gpl --enable-version3 --enable-cuda --enable-cuvid --enable-d3d11va --enable-dxva2 --enable-libmfx --enable-nvenc --enable-avisynth --enable-bzlib --enable-fontconfig --enable-frei0r --enable-gnutls --enable-iconv --enable-libass --enable-libbluray --enable-libbs2b --enable-libcaca --enable-libfreetype --enable-libgme --enable-libgsm --enable-libilbc --enable-libmodplug --enable-libmp3lame --enable-libopencore-amrnb --enable-libopencore-amrwb --enable-libopenh264 --enable-libopenjpeg --enable-libopus --enable-librtmp --enable-libsnappy --enable-libsoxr --enable-libspeex --enable-libtheora --enable-libtwolame --enable-libvidstab --enable-libvo-amrwbenc --enable-libvorbis --enable-libvpx --enable-libwavpack --enable-libwebp --enable-libx264 --enable-libx265 --enable-libxavs --enable-libxvid --enable-libzimg --enable-lzma --enable-zlib
      libavutil      55. 58.100 / 55. 58.100
      libavcodec     57. 89.100 / 57. 89.100
      libavformat    57. 71.100 / 57. 71.100
      libavdevice    57.  6.100 / 57.  6.100
      libavfilter     6. 82.100 /  6. 82.100
      libswscale      4.  6.100 /  4.  6.100
      libswresample   2.  7.100 /  2.  7.100
      libpostproc    54.  5.100 / 54.  5.100
    video_decrypted.mp4: No such file or directory
    maybe I'm doing something wrong ?
  7. Change "-f best" to "-f best*"
  8. Originally Posted by achilles View Post
    Thanks for help , but downloaded only а video.
    [info] manifest: Downloading 1 format(s): Video-3400
    [ism] Total fragments: 58
    [download] Destination: video_decrypted.mp4
    [download] 100% of 46.05MiB in 01:43
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'video_decrypted.mp4':
      Metadata:
        major_brand     : isml
        minor_version   : 1
        compatible_brands: piffiso2
        creation_time   : 2021-12-11T18:39:06.000000Z
      Duration: 00:01:55.35, start: 0.000000, bitrate: 3348 kb/s
        Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 3345 kb/s, 25 fps, 25 tbr, 10000k tbn, 50 tbc (default)
        Metadata:
          handler_name    : VideoHandler
    audio_decrypted.mp4: No such file or directory
    MediaInfo
    General
    Complete name               : D:\video\video_decrypted.mp4
    Format                      : MPEG-4
    Format profile              : ISML
    Codec ID                    : isml (piff/iso2)
    Codec ID/Hint               : IIS Smooth Streaming file format
    File size                   : 46.0 MiB
    Duration                    : 1 min 55 s
    Overall bit rate mode       : Constant
    Overall bit rate            : 3 350 kb/s
    Video
    Format                      : AVC
    Format/Info                 : Advanced Video Codec
    Format profile              : High@L3.1
    Format settings             : CABAC / 2 Ref Frames
    Format settings, CABAC      : Yes
    Format settings, Reference  : 2 frames
    Format settings, GOP        : M=1, N=50
    Codec ID                    : avc1
    Codec ID/Info               : Advanced Video Coding
    Bit rate mode               : Constant
    Bit rate                    : 3 400 kb/s
    Width                       : 1 280 pixels
    Height                      : 720 pixels
    Display aspect ratio        : 16:9
    Frame rate mode             : Constant
    Frame rate                  : 25.000 FPS
    Color space                 : YUV
    Chroma subsampling          : 4:2:0
    Bit depth                   : 8 bits
    Scan type                   : Progressive
    Bits/(Pixel*Frame)          : 0.148
    Stream size                 : 46.0 MiB (100%)
    Color range                 : Limited
    Color primaries             : BT.709
    Transfer characteristics    : BT.709
    Matrix coefficients         : BT.709
    Codec configuration box     : avcC
    P.S. And I would like to have the opportunity to choose another resolution
  9. Originally Posted by mathieuthibault View Post
    @ mister_ nex
    @ ElMagnificato
    @ElMagnificato
    @echo off
    pause
    5. Amuse-toi
    Good idea to simplify, I tested it but it only downloads the video
    I tried by changing the values of "yt-dlp -f best --allow-unplayable-formats" en "yt-dlp --allow-u" so that it takes the 2 tracks well but suddenly there is a problem for the renaming of the file
  10. In terms of the script, I suppose you can just get rid of the -f and just let yt-dlp do the default and get what it thinks is the best video/audio combination. It's apparently not encrypted so you can just use this:
    yt-dlp "%url_manifest%" -o "%episode%.%%(ext)s"
    ffmpeg -i %episode%.ismv -codec copy %episode%.mp4
    If you want to select your own formats, then what you put in post #2 works well.
  11. Everything is fine , it turned out great
    Batch file
    @echo off
    pause
    D:\video>download_ism_manifest_fixed.bat
    [info] manifest: Downloading 1 format(s): Video-3400+audio_fre-128
    [download] Destination: my_video.fVideo-3400.ismv
    [download] 100% of 46.05MiB in 01:49
    [download] Destination: my_video.faudio_fre-128.isma
    [download] 100% of 1.81MiB in 00:35
    [Merger] Merging formats into "my_video.ismv"
    Deleting original file my_video.faudio_fre-128.isma (pass -k to keep)
    Deleting original file my_video.fVideo-3400.ismv (pass -k to keep)
    Input #0, mov,mp4,m4a,3gp,3g2,mj2, from 'my_video.ismv':
      Metadata:
        major_brand     : isml
        minor_version   : 512
        encoder         : Lavf57.71.100
      Duration: 00:01:55.35, start: 0.000000, bitrate: 3536 kb/s
        Stream #0:0(und): Video: h264 (High) (avc1 / 0x31637661), yuv420p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], 3346 kb/s, 25 fps, 25 tbr, 10000k tbn, 50 tbc (default)
        Metadata:
        Stream #0:1(fre): Audio: aac (mp4a / 0x6134706D), 48000 Hz, stereo, fltp, 127 kb/s (default)
        Metadata:
          handler_name    : SoundHandler
    Output #0, mp4, to 'my_video.mp4':
      Metadata:
        major_brand     : isml
        minor_version   : 512
        Stream #0:0(und): Video: h264 (High) ([33][0][0][0] / 0x0021), yuv420p(tv, bt709), 1280x720 [SAR 1:1 DAR 16:9], q=2-31, 3346 kb/s, 25 fps, 25 tbr, 10000k tbn, 10000k tbc (default)
        Metadata:
        Stream #0:1(fre): Audio: aac ([64][0][0][0] / 0x0040), 48000 Hz, stereo, fltp, 127 kb/s (default)
        Metadata:
    Stream mapping:
      Stream #0:0 -> #0:0 (copy)
      Stream #0:1 -> #0:1 (copy)
    Press [q] to stop, [?] for help
    frame= 2883 fps=0.0 q=-1.0 Lsize=   48981kB time=00:01:55.32 bitrate=3479.2kbits/s speed=1.48e+003x
    video:47114kB audio:1802kB subtitle:0kB other streams:0kB global headers:0kB muxing overhead: 0.132110%
    MediaInfo
     General
    Complete name               : D\video\my_video.mp4
    Format                      : MPEG-4
    Format profile              : Base Media
    Codec ID                    : isom (isom/iso2/avc1/mp41)
    File size                   : 47.8 MiB
    Overall bit rate            : 3 479 kb/s
    Writing application         : Lavf57.71.100
    Video
    Format                      : AVC
    Codec ID                    : avc1
    Height                      : 720 pixels
    Color space                 : YUV
    Bit depth                   : 8 bits
    Stream size                 : 46.0 MiB (96%)
    Audio
    Format                      : AAC LTP
    Format/Info                 : Advanced Audio Codec
    Codec ID                    : mp4a-40-4
    Bit rate                    : 128 kb/s
    Channel(s)                  : 4 channels
    Channel layout              : C L R Cb
    Sampling rate               : 64.0 kHz
    Frame rate                  : 62.500 FPS (1024 SPF)
    Compression mode            : Lossy
    Stream size                 : 1.76 MiB (4%)
    Language                    : French
    Default                     : Yes
    Alternate group             : 1
    Is it possible to change the batch file to be able to choose resolution ?
  12. Originally Posted by STRiCK3R View Post
    @ mister_ nex
    @ ElMagnificato
    @ElMagnificato
    @echo off
    pause
    5. Amuse-toi
    Oops... My mistake, I forgot the following line in my first post :
    That's why you only got video downloaded, not audio.
    I edited the first post and added the missing line.
  13. Originally Posted by mister_ nex View Post
    Yes. For example, if you want 720p resolution, replace the downloading line by :
    yt-dlp -f bestvideo -S "res:720" --allow-unplayable-formats "%url_manifest%" -o video_encrypted.mp4
  14. @mathieuthibault,
    That's it I took the opportunity to add the mp4decrypt option so I enter the url, the key, a file title and it takes care of everything for a ready-to-use video file
  15. Originally Posted by mathieuthibault View Post
    Since the last 2 releases of yt-dlp this can be shortened to:
    --allow-u
  16. Originally Posted by STRiCK3R View Post
    @mathieuthibault,
    That's exactly what I did until now (batch with yt-dlp, mp4decrypt and ffmpeg), when we were able to get widevine protected canalplus video keys
    @codehound
    Thanks, I wasn't aware of this
  17. @mister_ nex
    (the ffmpeg command is not needed, I used rename instead)
    choose resolution:
    @echo off
    :here
    echo.
    echo.
    echo res: 360 480 540 720 1080
    echo.
    set /p resolution="example: type 540 and Enter: "
    echo.
    yt-dlp -S "res:%resolution%" "%url_manifest%" -o "%episode%.%%(ext)s"
    rename "%episode%.*" "%episode%.mp4"
    if not exist "Finished" mkdir Finished
    move "%episode%.mp4" "Finished\%episode%.mp4"
    echo.
    echo ------------------------------------------------
    echo.
    goto here
    tested links:
    https://hssodcplus-s.akamaihd.net/ondemand/playready/canalplus/d8/d8_1258258_15_D8/1115344/d8-1258258-15-D8.ism/manifest
    just be careful not to give the .bat file the same name as the video
  18. I thank everyone who responded and helped to deal with this script.
