Is it possible to get the exact command line used when FFmpeg Batch calls FFmpeg(.exe) ?
Results 1 to 9 of 9
add -report to the commandline. A verbose log file should be printed. When I tested it, it was located in the portable directory, because that's the version I was testing
No dice. There's a problem with how FFmpeg Batch is handling the "-report" flag.
When tried running it on the "try on console" button it says:
"Failed to open report "ffmpeg-20210513-230144.log": Permission denied
Last message repeated 1 times
Failed to set value '1' for option 'report': Permission denied
Error parsing global options: Permission denied"
However, using "-report" works fine running my own equivalent 2-pass batch commands which produces 2 log files. Why should FBAC choke only on this flag yet work as expected for other processing controls flags such as "-y -hide_banner -loglevel warning -stats" ? Seems fishy. -
It might be that program is still open or accessing the log. Try closing. I never had to, but I was using "Portable" version
It might be that you have it in a c: directory location, and you aren't running with elevated permissions or as administrator . I'm running as admin, but I never had location issues, because my "portable" location was on a different (non system) drive -
In the settings, I see there is a box "save more verbose log" . You can try checkmarking that and see what it does
It looks like there is a support thread here too, you can also try posting there
https://forum.videohelp.com/threads/386028-FFmpeg-Batch-for-Windows -
I've already have the option checkbox "save more verbose log" checked. The problem is that no logs are written at all.
Yes, running the program as elevated solved the problem, BUT, this should not be necessary ! It writes the processing output files without elevated privilege, why not everything else, too ?
For me, it wrote the log file in the application root directory , not the directory of input or output files. If the application directory is in c: , then you'd need additional permissions.
Command line youtube-dl & ffmpeg?
By Adeptus in forum Video Streaming DownloadingReplies: 2Last Post: 27th Feb 2020, 05:48 -
Need a command line for ffmpeg
By NTradd in forum Video ConversionReplies: 11Last Post: 14th Oct 2019, 11:25 -
ffmpeg command line help
By njscorpion in forum Newbie / General discussionsReplies: 2Last Post: 12th Jul 2019, 12:42 -
FFmpeg does not convert file through command line
By Vidikon in forum Newbie / General discussionsReplies: 2Last Post: 5th Jun 2019, 02:13 -
ffmpeg command line syntax
By sambat in forum Newbie / General discussionsReplies: 2Last Post: 14th Dec 2016, 20:01
