I am new to his and have just started doing some PAL raw VHS capture to AVI.
You all say best practice is to do the de-interlacing via software, so I am testing different de-interlacing results. But when I try and use QTGMC the result is unwatchable flickering.
See here
https://mega.nz/folder/PNl1QayL#nfoCfNlbP1L1DG5vSWyung
The original file is 720x576 at 25fps interlaced.
Then look at the QTGMC and yadiffmod2 (double rate) outputs. What is wrong with them? Obviously I have made mistakes with the settings here.
The only way I got a 50fps de-interlace to work properly was using Handbrake and yadiff+bob. That one works fine. But anything I try in both Staxrip and Hybrid are coming out not correct. Yes I am using GUI's for Avisynth as I have not figured out this scripting stuff yet.
Thanks for that it all makes sense now.
I did do a search on the forum before posting this but did not know the key word is 'field order'. It seems my problem was also solved here, with the OP having the same issues using Hybrid.
https://forum.videohelp.com/threads/394294-QTGMC-and-stutter
This must mean industry standard for AVI capture is BFF? -
No it is just more like bottom field is at some points kind of default assumed in avisynth (which does not mean in the industry). E.g. AssumeFrameBased will automatically assume BFF (so BFF is default). Actually it is about the importer that you are using. Some importers might even be correctly detecting and forwarding the info into avisynth (if your container provides that info)
You might want to know, avisynth started off with support for avi files a very long time ago. At this time, a widely used codec was dv which was bottom field. The AVI container is not able to store any "interlacing" based information. I imagine this is one reason why "bottom" is kind of default in avisynth, causing us trouble until today there and where.
If you have time, you can try out our software http://ffastrans.com you can use qtgmc there in the deinterlace filter and it will do it's best to detect and set the correct interlacing for you. -
QTGMC Multithreading Issues
By yesyesnoyes in forum Video ConversionReplies: 8Last Post: 12th Dec 2020, 15:49 -
QTGMC/IVTC issues on AVISynth/AvspMod
By Fraugster in forum RestorationReplies: 33Last Post: 7th Aug 2019, 07:55 -
Aliasing issues from QTGMC or source?
By Ish Kabibble in forum Video ConversionReplies: 6Last Post: 21st Jun 2017, 09:49 -
A/V sync issues: MeGUI + AVISynth - PAL to 23.976 w/ QTGMC + Srestore
By U2Joshua in forum Video ConversionReplies: 6Last Post: 17th Dec 2016, 11:29 -
QTGMC with interlaced PAL
By ziggy1971 in forum Video ConversionReplies: 14Last Post: 16th Jul 2016, 21:24
