Hello all.
I am looking for the BEST PCI BUS solution to accomplish the task I have at hand. That task being the RELIABLE recording of a TON of closed caption information from COMPOSITE VIDEO in RAW format to a binary file via GRAPHS for later parsing by CCExtractor. I need the card to have a proven track record of being able to perform this function as that is ALL it will be doing and it will be doing a LOT of it back to back.
Card Criteria;
* I need the card to be PCI bus based ONLY - no usb devices, or PCI-E etc...
* Needs to have a RCA video input or at least a breakout box that provides RCA connectivity
* doesn't have to be in production (it probably wont be anyway given my set of requirements)
* preferably a card that has ONBOARD CC decoding that can be routed via GRAPH to a binary file via a dump.filter
* it MUST be RELIABLE in the fact that it can do the task all day long and do it accurately
* needs to have drivers that are still available
I have heard that BT878 cards (i.e. Conexant chipsets) have this capability, but have no first hand knowledge as to which ones are BEST for this application. Which is why I am asking the experts for your first hand knowledge of these devices... All suggestions fitting the criteria above are welcome.
Thank you all very much in ADVANCE!
Closed Thread
Please do not open another thread on a subject you already opened,one thread is enough,this thread is closed.continue here.
https://forum.videohelp.com/threads/399547-Closed-Caption-capture-using-specific-hardw...e5#post2611547I think,therefore i am a hamster.
Hauppauge Colossus 2 pci capture card
By Muscleman in forum Capturing and VCRReplies: 9Last Post: 25th Feb 2020, 11:09 -
Data recovery options for reformatted sd and cf cards?
By Garlic in forum RestorationReplies: 12Last Post: 13th Feb 2019, 01:47 -
So many internal TV capture cards - help?
By csecu in forum Capturing and VCRReplies: 2Last Post: 28th Mar 2018, 14:07 -
Best capture cards?
By sledge105 in forum Capturing and VCRReplies: 1Last Post: 30th Apr 2016, 13:53 -
Video capture USB vs PCI-e card
By videocapn00b in forum Capturing and VCRReplies: 6Last Post: 11th Apr 2016, 07:50
