Hi, i am starting on restoring and enhance a dvd (that comes from old TV VHS series)
I am From Europe, the DVD is on PAL, but the scene seems to be Telecined ?
Find attached a sample of the Original Stream.
Here is my current Script, wich fails at IVTelecine it.
Cheers.Code:#Indexing LoadPlugin("C:\PORT\dgdecnv2053\DGDecodeNV.dll") DGSource("DVD1_1.dgi", rw=1350, rh=1080) #Detelecine "ScanType": "Interlaced", "ScanOrder": "TFF" -> Input Type 0 QTGMC(Preset="Very Slow", MatchPreset="Very Slow", MatchPreset2="Very Slow", NoisePreset="Slower", InputType=0, FPSDivisor=2, SourceMatch=3, Lossless=1, Denoiser="dfttest", Edithreads=3, showsettings=true) Prefetch(4)
Results 1 to 10 of 10
It's a little hard to tell because there's so little motion. But it appears to be a field blended NTSC/PAL conversion:
Next time include a medium speed panning shot.Code:QTGMC() SRestore()
Thanks you for your fast response, will dig it more today and report back.
Tested
Still interlaced, will attach a better sample.Code:QTGMC() SRestore() ---------------AND--------- QTGMC() SRestore(frate=25)
After Reading more docs i activate pure video deinterlacer and it do the job
Code:DGSource("DVD1_1.dgi", deinterlace =1, use_pf=true)Last edited by dolpsdw; 15th Dec 2020 at 02:06.
Simple explanation:
Instead of skipping certain frames or fields for framerate reduction one can merge 2 successive frames or fields into 1 by blending (overlay) successive fields (or frames) into 1 'ghost' field (or frame). Blending gives a smoother playback impression than just skipping which produces jerkiness and may break the field cadence.
There exist other methods though - if NTSC->PAL conversion is required at all as PAL DVD players can usually play NTSC discs without issues.
Edit:
You may find the discussion here helpful:
https://forum.videohelp.com/threads/378461-Query-about-identifying-field-blendingLast edited by Sharc; 15th Dec 2020 at 04:27.
I hope this is a better sample, there is no much action scenes on this one.
This is different from the sample1.
Sample2 is regular PAL 720x576i25.
No ghosts or blends, just blocking artefacts. Has it been digitized with a VHS/DVD recorder?
I would simplify the deinterlacing like
Code:QTGMC(preset="fast",EZDenoise=3.0) #50fps bob-deinterlace #selecteven() #uncomment this line for single-rate (25fps) deinterlacing derainbow() #reduces the rainbows
History:
The samples are part of a spanish "muppets like" show.
The Original signal probably has scenes recorded in NTCS (some songs like sample1 and the first part of sample3) and scenes recorded in spain (probably in pal?, the ones that showcase a giant pink hedgehog)
The actual samples come from a digitalization made by spanish television that produce a nostalgic DVD series.
I want to end having a clean progressive footage.
My current plan is using the DGIndexNV deinterlacer only in frames detected interlaced by NVCUVID pure video, instead of deinterlace everithing.
And then QTGMC() with inputtype=2 to clean a bit, may derainbow can help there to.Code:DGSource("DVD1_1.dgi", deinterlace =1, use_pf=true)
Not sure if this is the best way to go.
Any help is welcomed.
Thanks. -
The second clip is live interlaced PAL video. You want to just use QTGMC. Don't use FPSDivisor=2. That will lose half the motion and make the video flickery.
You can use deblock_qed() to reduce the blockiness -- at the cost of some blurring. With interlaced sources use:
Code:function Deblock_QED_i ( clip clp, int "quant1", int "quant2", int "aOff1", int "bOff1", int "aOff2", int "bOff2", int "uv" ) { quant1 = default( quant1, 24 ) # Strength of block edge deblocking quant2 = default( quant2, 26 ) # Strength of block internal deblocking aOff1 = default( aOff1, 1 ) # halfway "sensitivity" and halfway a strength modifier for borders aOff2 = default( aOff2, 1 ) # halfway "sensitivity" and halfway a strength modifier for block interiors bOff1 = default( bOff1, 2 ) # "sensitivity to detect blocking" for borders bOff2 = default( bOff2, 2 ) # "sensitivity to detect blocking" for block interiors uv = default( uv, 3 ) # u=3 -> use proposed method for chroma deblocking # u=2 -> no chroma deblocking at all (fastest method) # u=1|-1 -> directly use chroma debl. from the normal|strong deblock() last=clp par=getparity() SeparateFields().PointResize(width,height) Deblock_QED(last, quant1, quant2, aOff1, aOff2, bOff1, bOff2, uv) AssumeFrameBased() SeparateFields() Merge(SelectEven(),SelectOdd()) par ? AssumeTFF() : AssumeBFF() Weave() } -
Quick question,
I am looking at this sample4 file.
And after bobing it with QTGMC(preset="fast",EZDenoise=3.0) #50fps bob-deinterlace
*i like the 50 fps output
I see like some ghosting issues, (like what happen with sample 1)
Is this normal ?, can i do something with it?
Could this result be considered progresive ?
Thanks in adviceLast edited by dolpsdw; 16th Dec 2020 at 08:37.
Inverse resizing causing artifacts
By killerteengohan in forum RestorationReplies: 13Last Post: 5th Nov 2020, 21:11 -
Telecine dvd:Artifact on patterned clothings and shakines on parts of video
By Altruo in forum RestorationReplies: 4Last Post: 20th Sep 2019, 22:17 -
Telecine and Mencoder
By danielsender in forum LinuxReplies: 17Last Post: 19th Jun 2019, 20:40 -
Bad PAL telecine dvd help
By spiritgumm in forum Video ConversionReplies: 6Last Post: 4th Apr 2018, 19:06 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 08:51
