Let me be frank. I understand SoX seems a powerful software. But don't know how to use it being command line program. Tried with sample commands. Nothing works out.Issues as below.
1) SoX when tried to load just flash off and exit. Even if tried to open 'cmd' window, drag and drop SoX it gets loaded but not works if I try with commands.
2) One more prog. wget.exe gets installed with SoX but don't know what to do with it?
My requirement
1) I have wave stereo Audio named Aayiram Malargale_Saregama in desktop. Want to convert this to 6 monowaves FL,FR,C,RL,RR,LFE. The file itself not getting loaded & SoX throws so many errors. Unable to understand. How to go about it?
Can someone help?
Try DVDFab Video Downloader and rip Netflix video! Or Try DVDFab and copy Blu-rays! or rip iTunes movies!
Results 1 to 28 of 28
users currently on my ignore list: deadrats, Stears555
I already saw that link. Based on that only I tried. Afterwards only my post.In that I don't understand command below front left. I mean what to be filled in --dither something in all those spaces. And whatever I do it does not recognize though my SoX Shortcut & file I want to convert is in Desktop giving some syntax error,file loaction error all those. That's why I gave my file name, exact location so that someone can frame exact command & I can try.
Not only tried as per above. Also as per below guidelines someone posted in net that too tips taken from this forum only. That too didn't work.So totally confused how to use SoX.upmixing a stereo file to 5.1 audio with sox
Input: a stereo audio file (L+R)
Output: a 6-channel audio file in 5.1(side) layout (FL+FR+FC+LFE+SL+SR)
This is a simplified process, using just sox command line, to generate a 5.1 audio file.
Step 1: Front left & right channel
we just copy the left and right channel into the first two channels FR + FL.
sox input.wav temp_flfr.wav
Optionally, we could normalize the volume, use 24 bit sampling at 48KHz
sox input.wav temp_flfr.wav -b 24 -r 48000 gain -n -3 (normalize to -3 dB)
Step 2: LFE channel (Low frequency/subwoofer)
we take only the frequencies under 120 Hz for the subwoofer
sox temp_flfr.wav temp_lfr.wav remix 1,2 lowpass 120
Step 3: center channel (voice)
there are sophisticated ways to take only the voice out of a recording, but since we only have sox at our disposal, we will just filter out the human voice frequencies 300-3500 Hz
sox temp_flfr.wav temp_c.wav remix 1,2 highpass 300 lowpass 3500
Step 4: surround channels
the simplest solution is to just use the L+R input but less loud
sox temp_flfr.wav temp_slsr.wav gain -6
a more sophisticated version would use a bit of the ‘oops’ effect and add some delay
sox temp_flfr.wav temp_slsr.wav remix 1v-0.8718,2v0.4898 1v0.4898,2v-0.8718 delay 0.15
Step 5: merge all channels together
sox has a very simple merge syntax
sox -M temp_flfr.wav temp_c.wav temp_lfr.wav temp_slsr.wav output51.wav -
Try my Clever Ffmpeg-GUI, load your 2ch wav as source, audio conversion, continue, set as output ac3, 448k, 48kHz, set channels 2 to 5.1, click convert. Done.
Thank You. Yours will convert to AC3 5.1 DD directly. In case I need to convert to DTS? I think for that also may be some short way.
But I want first 6 mono files. In that especially in Rear Left & Right I want to totally reduce vocals, boost music & then want to remix all 6 files both in DD & DTS.
The reason being all direct conversions to AC3 5.1 or DTS except, if you go for high cost paid soft wares (I don't know about yours above let me try) gives almost equal volume in all 5 channels including vocals which is not so pleasing as individually processed ones. In fact vocals should be high only in center which you know.
So let me give a way first to split stereo to 6 mono (with center vocal boosted & surrounds music boosted) & test their sound quality for upmix to 5.1. -
[QUOTE=ProWo;2601318]Post a 10 sec sample of your wav here[/QU
I have uploaded 15 second sample. Pls.check -
Search for Programs & Features, activate or disactivate features (on the left): See, what .NET Framework is listed and if it's activated. If not, check it and activate .net. All versions >= 4.6 are fine.
Then try to load any mp4/mkv video into clever FFmpeg-GUI. If works, then your system is ok.Last edited by ProWo; 17th Nov 2020 at 11:00. Reason: typo
Checked .NET Framework 4.8 installed already.
Tried to load mp4 file.Same error creeps in. Copied error details and given below. May be it can help youSee the end of this message for details on invoking
just-in-time (JIT) debugging instead of this dialog box.
************** Exception Text **************
System.ComponentModel.Win32Exception (0x80004005): The system cannot find the file specified
at System.Diagnostics.Process.StartWithCreateProcess( ProcessStartInfo startInfo)
at clever_FFmpeg_GUI.Module1.ShowVideoTracks()
at clever_FFmpeg_GUI.Form2.Show_Tracks()
at clever_FFmpeg_GUI.Form2.Button2_Click(Object sender, EventArgs e)
at System.Windows.Forms.Control.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnClick(EventArgs e)
at System.Windows.Forms.Button.OnMouseUp(MouseEventAr gs mevent)
at System.Windows.Forms.Control.WmMouseUp(Message& m, MouseButtons button, Int32 clicks)
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.ButtonBase.WndProc(Message& m)
at System.Windows.Forms.Button.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
************** Loaded Assemblies **************
mscorlib
Assembly Version: 4.0.0.0
Win32 Version: 4.8.4250.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
clever FFmpeg GUI
Assembly Version: 1.0.0.0
Win32 Version: 2.6.8
CodeBase: file:///C:/Program%20Files%20(x86)/clever%20FFmpeg%20GUI.exe
Microsoft.VisualBasic
Assembly Version: 10.0.0.0
Win32 Version: 14.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/Microsoft.VisualBasic/v4.0_10.0.0.0__b03f5f7f11d50a3a/Microsoft.VisualBasic.dll
System
Win32 Version: 4.8.4200.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
System.Core
Win32 Version: 4.8.4270.0 built by: NET48REL1LAST_C
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
System.Drawing
Win32 Version: 4.8.3752.0 built by: NET48REL1
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
System.Configuration
Win32 Version: 4.8.4190.0 built by: NET48REL1LAST_B
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
System.Xml
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
System.Runtime.Remoting
CodeBase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Runtime.Remoting/v4.0_4.0.0.0__b77a5c561934e089/System.Runtime.Remoting.dll
************** JIT Debugging **************
To enable just-in-time (JIT) debugging, the .config file for this
application or computer (machine.config) must have the
jitDebugging value set in the system.windows.forms section.
The application must also be compiled with debugging
enabled.
For example:
<configuration>
<system.windows.forms jitDebugging="true" />
</configuration>
When JIT debugging is enabled, any unhandled exception
will be sent to the JIT debugger registered on the computer
rather than be handled by this dialog box. -
Your system is 32bit or 64bit?
Do you have the right version of clever FFmpeg-GUI for your system?
Do you have the right ffmpeg version for your system?
Delete this folder (it will be created again automatically):
C:\Users\xxx\AppData\Local\clever_FFmpeg_GUI (where xxx=your user name on windows).
Then restart clever FFmpeg-GUI.Last edited by ProWo; 17th Nov 2020 at 12:18. Reason: typo
You need the Microsoft Visual C++ Redistributable for Visual Studio 2015, 2017 und 2019
https://aka.ms/vs/16/release/vc_redist.x64.exe
Download and install it. -
mscorlib
clever FFmpeg GUI
System
System.Core
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
After installing above & restarting below is the error details generated. -
Sorry for keep on disturbing you informing not working. I have a feeling it is not working in 64 bit system. You can try out
You are using the 32bit version of clever Ffmpeg-GUI. Use the 64bit version instead.
No. Using only 64 bit. Anyhow since you said removed 32 bit, reinstalled 64 bit & tried. Again same error. Below is error log.
mscorlib
clever FFmpeg GUI
CodeBase: file:///C:/Program%20Files/x64/clever%20FFmpeg%20GUI.exe
System
System.Core
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
Anyhow since you said removes 32 bit, reinstalled 64 bit & tried. Again same error. Below is error log. -
mscorlib
Are you sure that your computer:
uses a 64bit CPU (not ARM),
uses a 64bit Windows 10 operating system? -
Try to repair your .net.
https://www.microsoft.com/en-us/download/details.aspx?id=30135 -
After updating/repairing as per above below is error log
mscorlib
clever FFmpeg GUI
System
System.Core
System.Drawing
System.Xml
enabled.
For example:
<configuration>
</configuration>
I have done further research. The specified error may occur if the source file is not found. Is the entire path to the file too long? Try moving the source file to a short path (e.g. D:\) and try again.
Unable to extract audio data to wave file on Subtitle edit 3.5.16
By Nakasofi in forum SubtitleReplies: 1Last Post: 14th Sep 2020, 05:42 -
VHS: Removing vertical wave from image
By Hardcore Legend in forum RestorationReplies: 5Last Post: 17th Apr 2020, 22:57 -
How to Convert 2 channel stereo wave into DD5.1 AC3 448 / AC 640
By Bonie81 in forum User guidesReplies: 36Last Post: 2nd Feb 2018, 13:42 -
Looking to use SOX for command line coversation, need help?
By PeeJayGee in forum AudioReplies: 5Last Post: 17th Jun 2017, 17:29 -
AviSynth's WavSource won't load WAVE PCM files
By random in forum AudioReplies: 7Last Post: 7th Aug 2016, 13:31
