Thank you @JoelHruska, this really helps me to gain some new knowledge.
So it seems AviSynth was been continued as AviSynth+ and forged to VapourSynth which uses Python instead of the original scripting language.
I will check out the other tools you mentioned.
But the key takeaway is, it is possible to inject them into Topaz Labs Video Enhance AI which then already receives the on-the-fly changes of the video.
Essentially allowing me to De-Interlace, Crop, Scale, Border, and directly AI update with VEAI.![]()
Results 511 to 540 of 576
Essentially allowing me to De-Interlace, Crop, Scale, Border, and directly AI update with VEAI. -
You definitely can. I've created a virtual drive and done single-ingestion into TVEAI before. I don't typically do it because the method I tested required 700GB of storage for a DVD episode in order to store the uncompressed video. It's a big chunk of storage when I'm already using 1-2TB for storing intermediate files.
I've been using multi-model blending extensively, so I have a bit of a different workflow, but single-ingestion into TVEAI can absolutely work. -
Here's an interesting (Selur's) VapourSynth script from a 3ad @ Doom9 about Cleanup of heavy compression artifacts that performs "QTGMC + BasicVSR++ with Model 5":
Code:# Imports import os import sys import ctypes # Loading Support Files Dllref = ctypes.windll.LoadLibrary("I:/Hybrid/64bit/vsfilters/Support/libfftw3f-3.dll") import vapoursynth as vs # getting Vapoursynth core core = vs.core # Import scripts folder scriptPath = 'I:/Hybrid/64bit/vsscripts' sys.path.insert(0, os.path.abspath(scriptPath)) # Loading Plugins core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/GrainFilter/AddGrain/AddGrain.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/DenoiseFilter/NEO_FFT3DFilter/neo-fft3d.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/DenoiseFilter/DFTTest/DFTTest.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/EEDI3.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/ResizeFilter/nnedi3/vsznedi3.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/libmvtools.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/temporalsoften.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/scenechange.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/Support/fmtconv.dll") core.std.LoadPlugin(path="I:/Hybrid/64bit/vsfilters/SourceFilter/FFMS2/ffms2.dll") # Import scripts import havsfunc # source: 'C:\Users\Selur\Desktop\Zim_01_compression_artifacts.avi' # current color space: YUV420P8, bit depth: 8, resolution: 720x480, fps: 29.97, color matrix: 470bg, yuv luminance scale: limited, scanorder: top field first # Loading source using FFMS2 clip = core.ffms2.Source(source="C:/Users/Selur/Desktop/Zim_01_compression_artifacts.avi",cachefile="E:/Temp/avi_5e80f5192093a24d3bd5bffe5fc965ee_853323747.ffindex",format=vs.YUV420P8,alpha=False) # making sure input color matrix is set as 470bg clip = core.resize.Bicubic(clip, matrix_in_s="470bg",range_s="limited") # making sure frame rate is set to 29.970 clip = core.std.AssumeFPS(clip=clip, fpsnum=30000, fpsden=1001) # Setting color range to TV (limited) range. clip = core.std.SetFrameProp(clip=clip, prop="_ColorRange", intval=1) # setting field order to what QTGMC should assume (top field first) clip = core.std.SetFrameProp(clip=clip, prop="_FieldBased", intval=2) # Deinterlacing using QTGMC clip = havsfunc.QTGMC(Input=clip, Preset="Fast", TFF=True) # new fps: 29.97 # make sure content is preceived as frame based clip = core.std.SetFieldBased(clip, 0) clip = clip[::2] # adjusting color space from YUV420P8 to RGBS for vsBasicVSRPPFilter clip = core.resize.Bicubic(clip=clip, format=vs.RGBS, matrix_in_s="470bg", range_s="limited") # Quality enhancement using BasicVSR++ from vsbasicvsrpp import BasicVSRPP clip = BasicVSRPP(clip=clip, model=5) # adjusting output color from: RGBS to YUV420P10 for x265Model clip = core.resize.Bicubic(clip=clip, format=vs.YUV420P10, matrix_s="470bg", range_s="limited") # set output frame rate to 29.970fps clip = core.std.AssumeFPS(clip=clip, fpsnum=30000, fpsden=1001) # Output clip.set_output()
Hope that inspires !
EDIT: MMEditing v0.15.0 has been released !Last edited by forart.it; 10th Jun 2022 at 10:54.
It's clean, but at the expense of a lot of background detail.
BasicVSR++ was the only thing is could find which produced anything usable.
Would be nice to find a better (automated) alternative than BasicVSR++.
Source is still linked in the thread and available, so anything better is welcome.
Cu SelurLast edited by Selur; 10th Jun 2022 at 11:18.
users currently on my ignore list: deadrats, Stears555, marcorocchini -
What a lively discussion
. I will admit I too was getting starry eyed over the Topaz Video Enhancer AI product...but my key takeaway from these 18 pages is to give Hybrid a try
. I love avisynth and I've seen it do what I thought was impossible...anything to make it easier is just gravy...
Topaz VEAI v3 is coming...
Originally Posted by Topaz Video AI Early Access v3.0.0-0 -
Known Issues
-> that seems like an 'alpha' release at best,...
Problems & Known Solutions
H.264 encoders have a maximum resolution of 4096x40
Level 6.2 allows:
resolution@fps (max refs)
3,840×2,160@300.0 (16)
7,680×4,320@128.9 (5)
8,192×4,320@120.9 (5)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
That's really it. Fools and their money are easily parted. Topaz crapware is inferior to Avisynth, Vapoursynth, x264, etc. The retort is always that those tools are hard (wah!), and Topaz has a whizbang lazy GUI. But it still doesn't make Topaz tools NOT crap. Just cheapware/junkware with a GUI, that lazy people can use to molest video quality. Those seeking quality will not be using it, and have not thus far.
Supposedly there is some limited success using Topaz + other tools. But I've still not seen proof of this.
Nothing I've seen to date was impressive, and in fact massively disappointing. The artifacts hurt my eyes to watch. It's been impressive how the software makes video so bad that it causes me to blink. So I guess there's that? Kudos Topaz?
FYI, their Photoshop plugins are equally junk, though not as bad as the video offering.
Yep. Try it, use it.
And donate a few bucks to selur, so he can afford to keep releasing updates, expanding features. Of all the freeware video tools available, his is by far one of those most worthy for a donation. It's impressive what he has accomplished. Fork over $25, $50, buy the man a virtual beer. (Topaz junk is overpriced at $200, just ridiculous for how half@ss it works.)Last edited by lordsmurf; 20th Aug 2022 at 07:10.
There are VSGAN filters out there to fix the awful artefacts produced by the bloody veai
Topaz will always be junkware,let others come here and swear it's the best,when i see any ai program that can improve the scenery in any film i will say it did it but not know.
Topaz is not junkware. There is a copycat program "Video Enhancer AI" that is junkware.
I never use it alone. I only use it for 2x scale model, or 4x scale model, then do everything else in Hybrid and grading applications. I use png 8 bit output until final compression.
I used to do upscaling in Hybrid until Topaz.
https://www.youtube.com/watch?v=sF26DDfQiJA
https://www.youtube.com/watch?v=YmyQbr6D7PI
Of course it's not like real true HD but I believe it can produce some of the best results possible today, for an individual on a single computer. The technology hopefully will improve.
I'm not actually liking the direction that Topaz VEAI is headed, as for 3.0, they are adding all these different modules that I think are actually done better in Hybrid/Avisynth/VapourSynth (like deinterlacing and frame interpolation), and they completely redesigned their user interface for reasons I'm not clear on, and of course it broke tons of things that are taking them a lot of time to try and fix. I think they are leaving the scope of upscaling and trying to also make it a filtering application like Hybrid, which I think is a mistake and looks to me like the beginning of feature creep / bloat. -
There is actually some freeware that can upscale pretty good, called Cupscale. It uses user created models.
But Topaz VEAI, at least in my testing, gives the best results, which I would expect from a commercial application.
https://www.extremetech.com/extreme/338403-what-video-ai-upscalers-can-and-cant-do
BTW, none of anything released so far is "AI", that's just a marketing term. I believe the more correct way to refer to these applications are "weighted databases". So, upscaling using weighted databases. I still don't understand why people here seem to be just outright disregarding the tech as "junk" when it demonstrably can do what it claims. -
Yes, I noticed this quite early here on the forums.
Especially those users keep stating their dislike. This leads to nothing but constant backslash.
Maybe a thread would be great, listing all the possible tools for video enhancement.
Then list or brainstorm about the pro, cons, and possible use cases.
I personally saw room for improvement in Topaz VEAI, hence I am happy they started the internal re-design.
Their code was most likely too limited to be shaped and extended, lets wait and see where it all leads. -
It low-key is junkware. Basically you can either upscale with very strong noise reduction and end up with oversmoothened video or use some of their more detailed models and get alright results with bunch of artefacts. Sorta like what you get around the endges when using virtualdubs smoothen filter combined with sharpening
However, used just as upscaler, Topaz VEAI may have an interest and produce good results for some videos, if integrated in a full AviSynth/VapourSynth flow, as we experienced earlier in this thread. -
I agree with this.
But Topaz is also that weird tool you bought on the way out of the hardware store, and it never worked correctly as advertised. So it's mostly a regretted impulse buy, often useless for the task. Sometimes it kinda works when you jam a screwdriver into the side, so you keep it.Want my help? Ask here! (not via PM!)
Personally, i have tried and would like to learn Hybrid, but i'm using Topaz VEAI because it's 100x easier to understand. For example, what would it take in Hybrid to upscale a slightly grainy video from 720p to 4K with similar or better results than Gaia HQ can provide in Topaz' software?
I don't necessarily think it's junkware, however, it's highly underwhelming for such price when their 'robust' de-interlacing model can't even do it properly and instead leaves in severe ghosting and blending artifacts, has color space issues and sucks overall for low resolution video (not severely compressed, as I tried a Pro-Res 240p and it looked better Bilinear-resized than AI upscaled). The program is severely flawed, still.
It is junkware,they resigned their whole software which means there old stuff was junk.
https://forum.videohelp.com/threads/406860-Is-it-actually-possible-to-upscale-480p-to-...sembling-1080p
useful thread for replicating VEAI looks (and getting even better results in some cases) -
junkware
how can i restore an enhance audio?
By enable in forum AudioReplies: 4Last Post: 21st Feb 2021, 16:26 -
DVDFab Video Upscaling--Enhance DVD from SD (480p) to Full HD (1080p) video
By DVDFab Staff in forum Latest Video NewsReplies: 2Last Post: 6th Aug 2020, 03:31 -
Is format factory can enhance video ?.
By mrs.faith in forum Video ConversionReplies: 1Last Post: 21st Apr 2017, 14:15 -
How Enhance video quality in potplayer?
By asiboy in forum Software PlayingReplies: 5Last Post: 1st Jan 2017, 15:01 -
Enhance this image to get the license plate
By thestolz in forum RestorationReplies: 7Last Post: 18th Jul 2016, 12:47
