So I have this file im trying to deinterlace in vapoursynth:
General
Unique ID : 161074302322831112421039471205135936440 (0x792DC83F02FF020EEC453F22B56FEBB8)
Complete name : C:\source.mkv
Format : Matroska
Format version : Version 4
File size : 204 MiB
Duration : 3 min 57 s
Overall bit rate : 7 181 kb/s
Encoded date : UTC 2020-09-19 09:00:05
Writing application : mkvmerge v50.0.0 ('Awakenings') 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : AVC
Format profile : Main@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, GOP : M=4, N=28
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 7 036 kb/s
Maximum bit rate : 20.0 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 (59940/1000) FPS
Original frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.075
Stream size : 200 MiB (98%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Duration : 3 min 56 s
Bit rate : 141 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 887 ms
Stream size : 3.97 MiB (2%)
Default : Yes
Forced : No
It was originally converted from a .ts. Trying to de-interlace it with QTGMC (I have gotten a lot of help from my friend doing this).
However, the output video is playing in "slowmo" almost. And it stops at ~halfway through, although the time it takes to get there is the same as the length of the source video. I don't understand what is going on. I will post my script as an attachement.
I searched up a bit and it might be the variable framrate of the source creating issues? I have re-encoded this around 4 times now every time with the same issue. The reason the script says 1920x1080 and the output file this time is 1440x1080 is because I tested changing the resolution if that had something to do with the issue.
My Script: https://mega.nz/file/C0w3QLwT#N4ObLeGyLPtMisWvr5E5YML0kKkL7AUbChAjocVhJPw
Its also way at the bottom.
My output file mediainfo:
https://mega.nz/file/XwxAQQYD#3gCA3-1GlLYQpKmo47nYatOlPMxeN5hWMMIa5GuMMOg
Output file link
General
Complete name : C:VideoHDTV.mkv
Format : Matroska
Format version : Version 2
File size : 248 MiB
Overall bit rate : 8 726 kb/s
Writing application : x264 r3018 db0d417
Writing library : Haali Matroska Writer b0
Video
Format : AVC
Format profile : High 10@L5
Format settings : CABAC / 16 Ref Frames
Format settings, Reference frames : 16 frames
Bit rate : 8 553 kb/s
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.229
Stream size : 243 MiB (98%)
Writing library : x264 core 161 r3018 db0d417
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=9 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=360 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.65 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.80
Language : English
Default : Yes
Forced : No
import vapoursynth as vs
import havsfunc as haf
import fvsfunc as fvf
import functools as functools
core = vs.core
core.max_cache_size = 1024 * 8
src = core.ffms2.Source(r"source.mkv").resize.Spline36(1 920, 1080)
def Deint(n, f, orig, deint):
if f.props._Combed:
return deint
else:
return orig
ivtc = core.vivtc.VFM(src, mode=3, chroma=False, cthresh=8, blockx=32, blocky=32, order=1)
deint = haf.QTGMC(src, TFF=True, Sharpness=0, Preset="Placebo", TR0=2, TR1=2, TR2=1, Lossless=2, SourceMatch=1, FPSDivisor=2)
combProps = core.tdm.IsCombed(ivtc, metric=1, chroma=False, cthresh=5, blockx=32, blocky=32, mi=90)
fin = core.std.FrameEval(ivtc, functools.partial(Deint, orig=ivtc, deint=deint), combProps)
fin = core.vivtc.VDecimate(fin).std.AssumeFPS(fpsnum=240 00, fpsden=1001)
fin = fvf.Depth(fin, 10)
fin.set_output()
I think that AssumeFPS() at the end cannot be there, to just put assume fps at the end so it matches what I want does not work.
And input is 60p so that might not work with that script.
It might be useful to post cut out of original clip not outcome. -
ok, op posted a source in his other , same topic thread:
https://forum.videohelp.com/threads/398867-Help-with-de-interlacing-a-video -
That video (in the thread _Al_ linked to) is telecined film. It should be inverse telecined, not deinterlaced. In AviSynth you would TFM().TDecimate(). I believe those (or some thing like them) are available in Vapoursynth.
VFM / VDecimate is vapoursynth's equivalent of TFM / TDecimate . (But there are some differences)
He's IVTCing, but using QTGMC as post processing for combed frames
Strange issue DeInterlacing DV capture - QTGMC-Bob (Hybrid Vapoursynth)
By SupermanTV in forum Capturing and VCRReplies: 23Last Post: 17th Sep 2023, 17:00 -
Solved: Deinterlacing with QTGMC blends frames together
By PRAGMA in forum Newbie / General discussionsReplies: 6Last Post: 15th Apr 2023, 03:19 -
Variable framerate, lossless rendering even possible?
By Abas-Avara in forum Newbie / General discussionsReplies: 23Last Post: 7th Feb 2020, 23:51 -
Problems Deinterlacing - MBAFF - Separate Fields - Variable Framerate?
By danfgtn in forum Newbie / General discussionsReplies: 4Last Post: 12th May 2018, 18:31 -
Variable FrameRate
By Lazare Londaridze in forum Newbie / General discussionsReplies: 111Last Post: 11th Sep 2016, 02:00
