So I have this file im trying to deinterlace in vapoursynth:
General
Unique ID : 161074302322831112421039471205135936440 (0x792DC83F02FF020EEC453F22B56FEBB8)
Complete name : C:\source.mkv
Format : Matroska
Format version : Version 4
File size : 204 MiB
Duration : 3 min 57 s
Overall bit rate : 7 181 kb/s
Encoded date : UTC 2020-09-19 09:00:05
Writing application : mkvmerge v50.0.0 ('Awakenings') 64-bit
Writing library : libebml v1.4.0 + libmatroska v1.6.2
Video
Format : AVC
Format profile : Main@L4
Format settings : CABAC / 4 Ref Frames
Format settings, CABAC : Yes
Format settings, Reference frames : 4 frames
Format settings, GOP : M=4, N=28
Codec ID : V_MPEG4/ISO/AVC
Bit rate mode : Variable
Bit rate : 7 036 kb/s
Maximum bit rate : 20.0 Mb/s
Width : 1 440 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Variable
Frame rate : 59.940 (59940/1000) FPS
Original frame rate : 29.970 (30000/1001) FPS
Standard : Component
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Interlaced
Scan type, store method : Separated fields
Scan order : Top Field First
Bits/(Pixel*Frame) : 0.075
Stream size : 200 MiB (98%)
Default : Yes
Forced : No
Color range : Limited
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : AAC LC
Format/Info : Advanced Audio Codec Low Complexity
Codec ID : A_AAC-2
Duration : 3 min 56 s
Bit rate : 141 kb/s
Channel(s) : 2 channels
Channel layout : L R
Sampling rate : 48.0 kHz
Frame rate : 46.875 FPS (1024 SPF)
Compression mode : Lossy
Delay relative to video : 887 ms
Stream size : 3.97 MiB (2%)
Default : Yes
Forced : No
It was originally converted from a .ts. Trying to de-interlace it with QTGMC (I have gotten a lot of help from my friend doing this).
However, the output video is playing in "slowmo" almost. And it stops at ~halfway through, although the time it takes to get there is the same as the length of the source video. I don't understand what is going on. I will post my script as an attachement.
I searched up a bit and it might be the variable framrate of the source creating issues? I have re-encoded this around 4 times now every time with the same issue. The reason the script says 1920x1080 and the output file this time is 1440x1080 is because I tested changing the resolution if that had something to do with the issue.
My Script: https://mega.nz/file/C0w3QLwT#N4ObLeGyLPtMisWvr5E5YML0kKkL7AUbChAjocVhJPw
Its also way at the bottom.
My output file mediainfo:
https://mega.nz/file/XwxAQQYD#3gCA3-1GlLYQpKmo47nYatOlPMxeN5hWMMIa5GuMMOg
Output file link
General
Complete name : C:VideoHDTV.mkv
Format : Matroska
Format version : Version 2
File size : 248 MiB
Overall bit rate : 8 726 kb/s
Writing application : x264 r3018 db0d417
Writing library : Haali Matroska Writer b0
Video
Format : AVC
Format profile : High 10@L5
Format settings : CABAC / 16 Ref Frames
Format settings, Reference frames : 16 frames
Bit rate : 8 553 kb/s
Display aspect ratio : 4:3
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Bit depth : 10 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.229
Stream size : 243 MiB (98%)
Writing library : x264 core 161 r3018 db0d417
Encoding settings : cabac=1 / ref=16 / deblock=1:0:0 / analyse=0x3:0x133 / me=umh / subme=10 / psy=1 / psy_rd=0.80:0.00 / mixed_ref=1 / me_range=32 / chroma_me=1 / trellis=2 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=0 / chroma_qp_offset=-2 / threads=9 / lookahead_threads=2 / sliced_threads=0 / nr=0 / decimate=0 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=16 / b_pyramid=2 / b_adapt=2 / b_bias=0 / direct=1 / weightb=1 / open_gop=0 / weightp=2 / keyint=360 / keyint_min=23 / scenecut=40 / intra_refresh=0 / rc_lookahead=60 / rc=crf / mbtree=1 / crf=16.0 / qcomp=0.65 / qpmin=0 / qpmax=81 / qpstep=4 / ip_ratio=1.40 / aq=3:0.80
Language : English
Default : Yes
Forced : No
import vapoursynth as vs
import havsfunc as haf
import fvsfunc as fvf
import functools as functools
core = vs.core
core.max_cache_size = 1024 * 8
src = core.ffms2.Source(r"source.mkv").resize.Spline36(1 920, 1080)
def Deint(n, f, orig, deint):
if f.props._Combed:
return deint
else:
return orig
ivtc = core.vivtc.VFM(src, mode=3, chroma=False, cthresh=8, blockx=32, blocky=32, order=1)
deint = haf.QTGMC(src, TFF=True, Sharpness=0, Preset="Placebo", TR0=2, TR1=2, TR2=1, Lossless=2, SourceMatch=1, FPSDivisor=2)
combProps = core.tdm.IsCombed(ivtc, metric=1, chroma=False, cthresh=5, blockx=32, blocky=32, mi=90)
fin = core.std.FrameEval(ivtc, functools.partial(Deint, orig=ivtc, deint=deint), combProps)
fin = core.vivtc.VDecimate(fin).std.AssumeFPS(fpsnum=240 00, fpsden=1001)
fin = fvf.Depth(fin, 10)
fin.set_output()
Results 1 to 9 of 9
Posting the source would be more helpful than the output. And you can preview the script before wasting time encoding it. Chances are your script on your setup already exhibits the issue
Possibly a source filter issue - did you try LSmash instead ? -
First of all, thanks for answering!
I see, no I have not tried LSmash... not familliar with it
I'll post the source:
https://mega.nz/file/70h3mYJR#q4O69XOhPYqWggqX93IrHFEmR6iBaL09y-gd0I7HeMI
this is the .ts file, i converted it to .mkv but I tried encoding both.
I mean, it looks fine, its just that it plays back really weirdly. When previewing, it plays really awfully as in uh bad fps. This happened to my successful encodes as well, even tho the output was fine the preview was slow... -
It's a source filter issue
Rewrap it into a MKV first with mkvmerge (mkvtoolnix) , then use LSmash . Or if you have nvidia card and license you can use DGSource directly on the TS
Code:src = core.lsmas.LWLibavSource(r'LiSA - Datte Atashi no Hero. [1440x1080i h264 SSTV+].mkv')
Currently trying this out! Atleast the script didnt give me any errors when switching up the source definition, somehow i had "LSmash" installed ^^
Will let you know if it works! -
make sure you're using a recent LSmash release
https://github.com/HolyWu/L-SMASH-Works/releases -
btw is it always better to use LSmash than ffms?
I had some other scripts and they worked just fine with ffms (de-interlacing DVD Mpeg), should i change those?
encoding already started
ill switch to the latest one if this goes wrong too. mine was 2020 march tho so its recent i guess...
Interlacing on video playback.
By Dencorub in forum Software PlayingReplies: 2Last Post: 30th Jan 2019, 08:59 -
De-interlacing video
By CarloJ63 in forum Newbie / General discussionsReplies: 5Last Post: 4th Oct 2018, 10:29 -
Video artifacts - De-interlacing.
By shans in forum Video ConversionReplies: 20Last Post: 22nd Sep 2018, 09:50 -
Interlacing artifacts when changing size of interlaced video
By Bencuri in forum Video ConversionReplies: 25Last Post: 25th May 2017, 22:03 -
Keep Interlacing while processing a video
By Marcoh_ in forum RestorationReplies: 10Last Post: 25th Jul 2016, 18:03
