Not sure where I should stick my question to which Category?
Have a bunch of Videos that have a Single Track with 2 languages [ Mandarin & Cantonese] - The default is a Mandarin and some
jumble up Cantonese in the background,when I played the video.
I can watch the Video with either VLC or Potplayer and select >> Audio stream >> Left Mono [ Cantonese].
Wha I really want is to REMOVE the Right Channel { Mandarin], so that when I play the Video, the default will be in
the Cantonese Language...Any suggestion? - Thanks.
Results 1 to 30 of 32
Are these VCDs or rips from VCDs? AFAIK, only VCDs had dual audio tracks (mono Mandarin/Cantonese one of the stereo tracks). DVDs have separate Mandarin/Cantonese stereo tracks.
If so, this thread details what you need to do: https://forum.videohelp.com/threads/193430-how-to-rip-a-VCD-with-2-audio-channels -
I downloaded the whole bunch from a Chinese Sites,looks like thy are "Old Videos" probably VCD's but the file format are in RMVB format mostly.
I was elavted when I use Handbrake the previous version to convert,it did had an optin on the Audio Tab to set to "Left Mono or "Right Mono"
or the stay with the Default at "stereo ". I was able to convert at least 19 of the 40 files perfectly and then the next 20 or so
came out with a distorted audio.? -
Once you get this set up it's trivially easy:
Download a "static build" of ffmpeg. Extract ffmpeg.exe and copy or move it to C:\Windows\System32. Then use Notepad to put this text
Code:ffmpeg -i %1 -map_channel 0.1.0 -c:v copy "%~dpn1.mono.mp4" pause
After that you can drag/drop any of your videos onto the batch file to mux the original video and encode the left channel of the source audio to aac, into a new file with the same base name pluse .mono.mp4. So, for example, MyFile.MKV will result in MyFile.mono.mp4. The original file is left untouched.
If you put that batch file in your SendTo folder you can right click on any video in Explorer and select Send To -> SL2M.bat from the context menu to perform the conversion. In Win10 you can get to the Send To folder by opening an Explorer window then, in the title bar, type SendTo, press Enter. Drag/drop the batch file there.
I don't have any rmvb files so I can't verify the video codec will work in MP4. You might have to use a different container, like MKV. You do that by changing the output extension in the batch file (change .mp4 at the end to .mkv or whatever you need).
The "Pause" in the batch file is to leave the CLI window open in case there is an error -- so you can see the error message. Once you verified that the batch file is working you can remove the Pause if you want, the CLI window will then close automatically. -
Yes, you are quite right, it is easier than it looks, I tried to highlight 2 or 3 files to Drag and Drop into the .Bat file but it seem to process
1 file at a time?... Also, can I specify a different Output folder for the converted files?......what am I doing wrong?
BTW. it came out perfectly the quality of the audio and video- Thanks.
Sorry about the confusion,it worked for video files with MKV containers but NOT for RMVB, I tested the code with MKV first.
screenshot with MKV files:
http://www.imagebam.com/image/3daacc1342564033
Screenshot of RMVB files:
http://www.imagebam.com/image/cda9ec1342566119
Here I UPLOADED a RMVB file, if you want to try it
http://www.filefactory.com/file/3zedlm5qszft/East.Fall.West.01.rmvb
Hope that clears up the confusion... Thanks again.Last edited by niteghost; 2nd May 2020 at 15:20.
The "0.1.0" in the ffmpeg command line means file 0, stream 1, channel 0. You're working with only one file file 0 is correct. Media files usually have the video stream before the audio stream. So stream 0 is usually the video and stream 1 the audio. But your RMVB file has them reversed -- 0 is the audio, 1 is the video. So you need to change that to "0.0.0".
I managed to find one RMBV file in my collection of odds and ends. Like the file in your image it has RV40 video and Cook audio. The next problem you'll run into is that RV40 video can't be put into an MP4 container (at least ffmpeg won't do it). Unfortunately, ffmpeg doesn't include an RMVB muxer so the new file can't be RMVB either. You can use MKV though.
The command line I gave you doesn't specify what audio codec to use. When making MP4 files ffmpeg will default to AAC. But when using MKV it defaults to Vorbis. If that's a problem for you you can specify what audio codec to use. For AAC:
Code:ffmpeg -i %1 -map_channel 0.0.0 -c:v copy -c:a aac "%~dpn1.mono.mkv"
You can specify a bitrate with "-b:a 160k" (replace 160k with the bitrate you want). For example:
Code:ffmpeg -i %1 -map_channel 0.0.0 -c:v copy -c:a mp3 -b:a 160k "%~dpn1.mono.mkv"
Tested the first line of code, came out great,now if I can incorporate that code that enables me to specify how many files in a folder to process and
able to specify a designated output folder to house the converted files will be PERFECT !!
Thanks fpr ll the effort,you're the RIGHT person to help me. !!
Screenshot of Converted files :
http://www.imagebam.com/image/a42b931342573175 -
Sneaker showed how to step through files if you drag/drop more than one.
If you want to process all the RMVB files in a folder, and put them in a subfolder, put a batch file in that folder with this:
Code:mkdir mono for %%F in (*.rmvb) do ( ffmpeg -i "%%~dpnxF" -map_channel 0.0.0 -c:v copy -c:a aac -b:a 160k "mono\%%~nF.mkv" ) pause
Sorry, I'm really new to this way of converting files and absolutely NO idea about the parameters, you guys
are setting. I highlighted a bunch of RMVB files and drag it into the Code that you provided, ito the .BAT file and it seems to
process the files but I cannot find the subdirectory or the files that were converted? -
There's a bug in Sneaker's batch file. I believe he intended for the bat file to be in the same folder as the video files, and and the new files would go to a subfolder called "output_folder" from there. But the output name spec is built incorrectly. Say your source file is in D:\Videos\Filename.rmvb". "output_folder\%~dpn1.mono.mp4" builds a name like "output_folder\D:\Videos\Filename.mono.mp4" Changing the output spec to "%~dp1output_folder\%~n1.mono.mp4" or "output_folder\%~n1.mono.mp4" should work.
If you want the batch file to work with the batch file in a different folder than the video files (in your SendTo folder, for example) you can modify the code to look like:
Code:PUSHD %~dp0 if [%1]==[] goto :eof :loop mkdir "%~dp1output_folder" ffmpeg -i %1 -map_channel 0.1.0 -c:v copy "%~dp1output_folder\%~n1.mono.mp4" shift if not [%1]==[] goto loop
Unfortunately, I just tried your code but when the converted file that was put into the Output_folder, does not play at all.
A couple of screenshots are shown below :
http://www.imagebam.com/image/6abaec1342593432
http://www.imagebam.com/image/74b76f1342593512 -
It seems to run very well the first time, then I tried a different folder with 20 RMVB files , it created the output_folder, and just did the #13 file, even though
I highlighted the 20 files and dragged them into the .BAT file.
I end up doing them individually...........sigh !! with your Original Code:
ffmpeg -i %1 -map_channel 0.0.0 -c:v copy -c:a aac "%~dpn1.mono.mkv" -
When you drag/drop files onto a batch file Windows builds a command line with a list of all the files you selected. There is a limit to the length of a command line. So there's a limit to the number of files you can convert that way.
Another way of handling many files is to put the names in a text file (with notepad, for example), one name per line. Then use that text file as an input to ffmpeg. -
Well, I'm happy and grateful even though I have to drag individual file one at a time,was just curious it worked before when I
dagged in 3 to 4 or more simultaneously it created the Output_folder and deposited the converted files in the folder. Tanks anyway for all the great help
and patience. Eternally Grateful Bro. -
Here is a folder with a folder with the RMVB files
Screenshots of source file:
http://www.imagebam.com/image/e32ccc1342679743
Screenshot of the Mono folder:
http://www.imagebam.com/image/4b4a9d1342679778
Screenshots of CMD window:
http://www.imagebam.com/image/54a4581342679797
http://www.imagebam.com/image/b7d0d91342679827
Not sure why this particular source RMVB folder does not work? -
The fourth image shows the problem: "stream #0.0 is not an audio stream". Right above that you can see that stream 0 is video, stream 1 is audio. Some of your videos have the audio as stream 0, some as stream 1. I don't know how to make ffmpeg automatically detect which is the audio stream to prevent this error. But you could try using two ffmepg commands, one for stream 0, one for stream 1:
Code:mkdir mono for %%F in (*.rmvb) do ( ffmpeg -i "%%~dpnxF" -map_channel 0.0.0 -c:v copy -c:a aac -b:a 160k "mono\%%~nF.mkv" ffmpeg -i "%%~dpnxF" -map_channel 0.1.0 -c:v copy -c:a aac -b:a 160k "mono\%%~nF.mkv" ) pause
Yep !! That DID IT !!- I'm haoping this "Final " Code that you provided here can be a "Universal " script to convert ANY RMVB
video files,REGARGLESS how the stream of the Video or audio are arranged??
Screenshot of the perfectly converted RMVB fiiles with the Leeft Mono in the MONO output File :
Thanks again for your support and patience... -
Converting TrueHD Atmost track to Dolby Digital + Atmos track?
By illuvattarr in forum AudioReplies: 2Last Post: 21st Jul 2018, 23:09 -
Downmixing 6 channel AAC to 2 channel?
By bizzybody in forum Video ConversionReplies: 33Last Post: 12th Nov 2017, 10:19 -
Convert 6 Channel AAC to 6 Channel AC3
By TheRandomOne in forum AudioReplies: 18Last Post: 4th Jul 2017, 10:40 -
How to fix audio that jump from channel to channel?
By midts in forum AudioReplies: 2Last Post: 24th Apr 2017, 07:04 -
Premiere: Duplicate left audio channel to the right channel?
By ash_melb in forum EditingReplies: 7Last Post: 21st Oct 2015, 11:32
