my VCD has 2 audio channels
Left channel is English
Right channel is Japanese
how do I rip it into an mpg with only the Japanese audio
and keep the file size around 230mb
thanks
Some people may have other methods, but this is how I would do it:
Use VCDGear or ISOBuster to extract the MPEG out of the VCD - info here
Then open the MPEG in virtualdub and save the audio out to a WAV file - info here
Then open the WAV in Goldwave or audacity (or any audio editor that shows you separate channels). Then you should be able to remove one channel, and then duplicate the channel you wish to keep to replace it, giving you a double mono / quasi-stereo audio file. Save this out to a new WAV.
Convert the WAV to 224kbps MP2 using besweet or ffmpeggui. Demux the MPEG using TMPGEnc's MPEG tools, then remux the video stream with the new MP2 audio file.
Done
If in doubt, Google it. -
If the channel you want to keep is the left channel, go to Edit > Channel > Left, then go to Edit > Copy, then go to Edit > channel > Right, then go to Edit > Paste at ... > Beginning. This should then replicate the one channel across both channels.
trying to extract the 7.1 channels (8 channels) from Blu-ray disc
By billsantos in forum AudioReplies: 2Last Post: 20th Feb 2011, 15:28 -
Rip audio from VCD
By miamicanes in forum AudioReplies: 9Last Post: 4th Aug 2010, 08:04 -
DVD with two audio channels
By Anurag in forum DVD RippingReplies: 6Last Post: 20th Apr 2009, 00:15 -
rip dvd folder and keep both audio channels ???
By hulinning in forum DVD RippingReplies: 12Last Post: 16th Feb 2009, 11:43 -
Rip Only Certain Channels From Dolby 5.1 DVD to Wave Files?
By dvd-dude in forum AudioReplies: 5Last Post: 3rd Sep 2007, 22:07
