I'm working with SD ProRes content in AviSynth and I want to de-telecine this ProRes master, however, the TIVTC package dosen't support Stacked16 input. I can convert to YUY2 to maintain 4:2:2, but loose 10bit. I can convert to YV12, but loose 4:2:2. It seems to be one or the other which really sucks. Anyone have any ideas?
Is the pattern consistent ? (no edits prior to pulldown removal , or cadence breaks) . If so , you can use a combination of separatefields and selectevery to keep 10bit422
If I convert to 8bit yv12, tfm().tdecimate() works flawlessly, so I would assume so, besides residual combing in the chroma channel, which can be fixed If I use this script for interlaced chroma instead: https://forum.doom9.org/showthread.php?p=1582950#post1582950
TFM is an adaptive field matcher - so it will change "on the fly" and adapt to the changing patterns. It it only supports 8bit . That script uses TFM for some parts, so 8bit only too. srestore is used for deblending and only supports 8bit as well. Even if they supported 10bit the script would have to be adjusted to 0-1023 range for the masktools parts
I was asking if pattern is the same. If it was, you could keep 10bit422 without using TFM. There are only 5 combinations for 3:2 pulldown, it just depends where in the cycle you start. It sounds like you probably can't do this with your source -
The entire file maintains three progressive frames followed by two combed frames. And 8bit restrictions of plugins are fine because i can convert to stacked16 but the only issue at that point is the yv16 output, which tfm only support yv12. If all else fails, I'll just go with 10bit 420.
Here a wrapper function in this post for separatefields and selectevery. Just test 0-4 and it works in 10bit422 with avs+ if your pattern is consistent
https://forum.videohelp.com/threads/294901-Avisynth-manual-IVTC-trouble#post1856153
I question what is causing the combed chroma; I'm wondering if your source filter is returning the frames correctly, or if you're converting correctly, or if it's in the actual source (can you see problem on separate fields?) . If you go down to YV12 it has to be done in an interlaced manner (interlaced=true) if you don't remove pulldown first . That is one common cause of chroma combing (422=>420 done in a progressive manner ,instead of interlaced manner, before removing pulldown). -
10bit BT.2020 HDR content to 10Bit BT.2020 WITHOUT HDR metadata
By wmplib in forum Video ConversionReplies: 3Last Post: 10th Apr 2020, 08:44 -
How to play 10bit videos and be sure to get true 10bit color on the screen?
By flashandpan007 in forum Software PlayingReplies: 6Last Post: 7th Apr 2017, 19:02 -
Re-encoding Bluray content with x265 10bit
By leghorn in forum Video ConversionReplies: 4Last Post: 12th Mar 2017, 08:30 -
How do I convert 1080p 10bit mkv's to 720p 10bit?
By fighuass in forum Video ConversionReplies: 6Last Post: 19th Nov 2015, 02:34 -
AVISynth 24p to 60i Telecine
By jelockwood in forum Video ConversionReplies: 1Last Post: 17th Nov 2015, 12:05
