Hi all-
I would like to get composite video in and out of a MacBook Pro, a 2018/2019 model with USB C connections.
I happen to have an old ADVC110, and firewire via my Thunderbolt display. It lights up (i.e., it powers) and the input-selector works, but no images show up in Final Cut or any other capture software. Sometimes it's detected, sometimes not at all.
Any thoughts? Do I need a more direct connection than the Thunderbolt display? Might an external power adapter make a difference?
Also open to solutions outside the ADVC 110 for bidirectional composite video?
For completeness, my main application is an analog video synthesizer, not capturing/recording VHS. No audio needed.
Thanks and regards,
-Amanda
I'm curious: what's an analog video synthesizer? Something artsy?
You mentioned external power adapter. The ADVC110 does require a power brick, if you're not already using one.
To be honest, I don't even know what "Thunderbolt display" means, but maybe this similar thread will help you:
https://forum.videohelp.com/threads/396546-Video-Conversion-Puzzle-4-pin-Firewire-to-Thunderbolt-3 -
Quite a bit written about this both on the general web and the topic linked to above (and those linked to from that post) - IIRC there was also another topic which I actually replied to with a link for a potential solution.
I'll add a few words here but the topic really belongs to the Mac forum.
The ADVC sends FireWire400. The thunderbolt, if I understand correctly, expects FireWire800. So you require a 400 to 800 adapter. You also require, unless that is what you referred to above, is a FireWire to Thunderbolt adapter.
The ADVC does not send composite. It accepts a composite input but into a PC/Laptop it will output DV over FireWire. -
Thanks for the reply. I'll get a power brick (I don't think it came with one).
Video synthesizers are essentially devices that generate video signals themselves, rather than from recordings. Think of it as test patterns taken to the next level, with the ability to modify/shape/process creatively. (So, yeah, kinda artsy 😸
-Amanda -
Followed the thread: https://forum.videohelp.com/threads/396546-Video-Conversion-Puzzle-4-pin-Firewire-to-Thunderbolt-3
Yep, I've got all those converters
I think the next step is to locate a power brick. Thanks!
-A -
I stand corrected. I was aware that an ADVC (I own a 300) can output analog but I thought that was reserved for 'cleaning' the incoming analog signal before sending it back to something that can accept such a signal - I actually do that for VHS captures when I do not need DV.
The ADVC-300 filtering is ghastly. Very ruinous to the video.
Those Canopus DV boxes are really only acceptable in PAL, not NTSC. The NTSC 4:1:1 is just far too lossy.
DV is also blocky like MPEG, in both NTSC and PAL.
Again, this is tech from the Pentium III era. Very craptastic. Minimum specs were often Pentium II.
This predates lossless capturing, which many people already consider "old" (2000s). But it's a legacy task, requiring legacy hardware and software. But ADVC boxes are just damned old, obsolete, outdated. Not even legacy.
If you must use Mac, you're somewhat screwed with quality video choices, must use what is available. It was never a video capture OS. However, the better option is to build a low-cost Windows XP/7 system for capturing only.Want my help? Ask here! (not via PM!)
Mid-capture fail using WinDV with ADVC-110
By eclipse95 in forum Capturing and VCRReplies: 13Last Post: 4th Jan 2020, 13:36 -
What's wrong with Canopus ADVC 110/55?
By Maris 55 in forum Capturing and VCRReplies: 26Last Post: 13th Jan 2019, 11:58 -
Nero 2019 and 2018 creating dvd's with freezing towards the end, how to fix
By squint85743 in forum Authoring (DVD)Replies: 6Last Post: 9th Jan 2019, 18:09 -
Analog input with ADVC 110
By Knientje in forum Capturing and VCRReplies: 6Last Post: 28th Dec 2018, 03:41 -
BMD Intensity Pro 4K, I-O Data GV-USB2, Canopus ADVC-300 Shootout
By SameSelf in forum Capturing and VCRReplies: 4Last Post: 4th Oct 2016, 08:43
