Whenever I play some MKV files with the AVC1 codec, i get a missing codec error. How do i fix that?
also, on another thread i read this: How do I do that???
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-)
What player do you use? MPC-HC and vlc have their own codecs.
Install Lavfilters should work with most players.
If you're using virtualdub use virtualdub2 or install ffdshow. -
No, I wanna edit them with VirtualDub 1.10.4, build 35491
Therefore, I conjecture that my question is:
How do I enable ffdshow support for AVC1 video in the VfW video settings/codecs section
.... but please do realize, that I don't even understand WHAT the f i am asking here......get it? So, please use laymans terms and lotsa handholding.
EDIT:
And sadly enough, VirtualDub2 has got a virus , and i already have corona, so i'm hesitant to give my laptop a virus too.....Last edited by KneeRow; 15th Mar 2020 at 02:26. Reason: FORMAT
Looking for subtitles of: Höök tt0997023, Lime tt0269480, La clé sur la porte tt0077348. tt=iMDb.com Found Desideria tt0081724 subtitle! :-) -
false positive.
virtualdub2 is easier and updated ffdshow has not been updated since 2014.
open ffdshow vfw config and enable h264 decoder
[Attachment 52352 - Click to enlarge]
Missing Codec (AVC1) in VirtualDub
By Water in forum Video ConversionReplies: 11Last Post: 8th Oct 2016, 17:52 -
Virtual Dub Missing Codec AVC1
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 8th Jan 2016, 22:07 -
How can i solve virtualdub missing codec avc1 ?
By Chocolade in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2015, 17:14 -
VirtualDub missing compression codec options?
By raena in forum Newbie / General discussionsReplies: 15Last Post: 9th Sep 2015, 20:47 -
Encode to AVC1 in Virtualdub?
By ChasVideo in forum Newbie / General discussionsReplies: 4Last Post: 25th Mar 2015, 02:43
