I'm trying to convert this M4V file into an AVI file in VirtualDub but whenever I drag in the file I get "Missing Codec (AVC1)"
Same problem occurs when I drag in a MP4 or WMV file
I have the QuickTime plugin and WMV plugin.
I also downloaded ffdshow
Anyone have a solution to this problem?
Thank you!![]()
Results 1 to 12 of 12
Enable H.264 decoding in the VfW interface, not in the Directshow one.
Note that if you are using 64 bit VirtualDub you need 64 bit ffdshow. If you are using 32 bit VirtualDub you need 32 bit ffdshow.
Opening WMV files in VirtualDub requires:
a) the WMV input plugin, plus
b) WMV-decoding enabled in ffdshow's VfW interface -
Shekh's Vdub FilterMod opens virtually anything - it comes with an FFmpeg-based input plugin.
https://forum.videohelp.com/threads/378401-VirtualDub-fork-and-plugins -
It looks like you've solved your problem with x264vfw. But also consider that some source plugins for VirtualDub will require DirectShow decoders. So try enabling the ffdshow's DirectShow h.264 decoder too.
Virtual Dub Missing Codec AVC1
By TheRandomOne in forum Video ConversionReplies: 1Last Post: 8th Jan 2016, 21:07 -
How can i solve virtualdub missing codec avc1 ?
By Chocolade in forum Newbie / General discussionsReplies: 3Last Post: 24th Nov 2015, 16:14 -
VirtualDub missing compression codec options?
By raena in forum Newbie / General discussionsReplies: 15Last Post: 9th Sep 2015, 19:47 -
Virtualdub and audio codec missing.
By nzdreamer55 in forum EditingReplies: 20Last Post: 29th Dec 2013, 23:32 -
Virtual Dub AVC1 missing codec
By shokan22 in forum Newbie / General discussionsReplies: 8Last Post: 14th Oct 2013, 17:37
