Results 1 to 20 of 20
  1. I am encoding mp4 videos in Staxrip selecting x264 ffmpeg on format profile Main & High, Levels 4.0,4.1,5.0 & 5.1 after encoding video I got "Jerky Playback" video. The same video encoding using RipBot264 works fine no jerky playback. I prefer Staxrip it's quite better than RipBot264 with so many encoder options. Please guide and advise where I am making a mistake and help to resolve this issue.
    Hope to hear soon.
    canada
    Post mediainfo of the before and after videos.
  3. Thanks for the response, your required files attached herewith.
    canada
    Please don't post a duplicate thread,I deleted it,just continue here.
  5. Sorry! continue here please and ignore others.
  6. Hi Johns0
    Please confirm the receipt of MediaInfo files Before and After encoding.
    Mar 2008
    Originally Posted by deepfrayder View Post
    Hi Johns0
    I did not spot any obvious problem with the mediainfo. Can you post a clip
    of the output file showing the problem? (10 -15 seconds with some steady movement should be enough).
    Also post the StaxRip log
    Aug 2008
    Australia
    These clips with jerky playback problems,are they in any way related to the clips you had problems with in this POST
    https://forum.videohelp.com/threads/394736-Staxrip-Encoding-Issue#post2564246
  9. Please guide where and when I can get the Staxrip Log.
  10. Hi!
    Thanks for the response, PFA required clips using "x264 ffmpeg mp4" of Original Video, Staxrip encoded video, MediaInfo of Original Video, MediaInfo of Staxrip encoded video along with Staxrip encoded video Log.
    Hope to hear soon regarding the Staxrip "Jerky Playback" encoded video problem.
  11. staxrip encode is missing frames and has duplicates in that sample
    Probably a source filter error, a bad version of lsmash
    LoadPlugin("C:\Users\Arslan\Desktop\StaxRip-x64-2.0.4.0-stable [Portable] 8.4\Apps\Plugins\both\L-SMASH-Works\LSMASHSource.dll")
    LSMASHVideoSource("C:\Video Sample.mp4")
    #AssumeFPS(25)
    You can try dropping in a newer lsmash version, or adjust the script to load a different .dll, or use a different source filter
    Log says you are using 2.0.4.0
    The 2.0.4.1 beta has a newer Lsmash version, you can try that
    2.0.4.1 Beta
    update: L-Smash Works 2019-09-10 HolyWu
  12. Thanks for the support, unfortunately same result after encoding "Jerky Playback" video. Any other suggestions for this problem?
    Mar 2008
    You could create a simple script and open the script in StaxRip, easier to test things that way.
    This worked fine on your original source in an older version of StaxRip
    loadplugin("d:\Program Files\AviSynth\plugins\LSMASHSource.dll")
    V = "C:\Users\davex\Desktop\Original Video Sample.mp4"
    Video=LSMASHVideoSource(source=V)
    Audio = directshowsource("C:\Users\davex\Desktop\Original Video Sample.mp4", video=no)
    Video = Video.ConvertToYV12()
    audiodub(video,audio)
  14. I've tried latest version of Staxrip but got the same result.
    Mar 2008
    I tried your original sample in StaxRip 2.0.6.0 and it came out fine, did not do anything special
  16. I'm, selecting output x264, ffmpeg mp4 with 2 passes, Preset: Medium (Default) but no change in output got "Jerky Playback" video in result. I've downloaded Staxrip latest version and tried again but same "Jerky Playback" video output.
    Would you like to share your Staxrip Log, profiles and settings detail ?
    I've tried with latest Lsmash version and Lsmash plugin already loaded in staxrip as advised earlier to load that plugin. Please guide and advise my problem area to got perfect encoded video output.
    Mar 2008
    One thing different, I used mp4 (mp4box) instead of mp4 (ffmpeg). Here is my log:
  18. Any suggestions for resolving "Jerky Playback" video issue output selecting x264, ffmpeg mp4 with 2 passes, Preset: Medium (Default).
    Mar 2008
    Why don't you recreate the problem and post a fresh log, the previous log does not show FFmpeg libx264 being used.
    Why do you have to use STaxRip and why FFMpeg ?
    You're probably better off making a post in the main StaxRip thread, perhaps the devs can take a look
    Post a screen shot from StaxRip of your ffmpeg x264 options
  20. I'm selecting beside x264 ffmpeg container options mp4 by clicking top of container option.
