Hi, but please I remember you that I'm a real cat: low ram usage, low cpu capabilities
[Attachment 50288 - Click to enlarge]
excluding AVFS I exactly don't remember what utility/programs can generate a fake .avi from an .avs script.
Please note that AVFS expose an output uncompressed, but in generally I try to understand what is all the rest of programs that do this including the specific fourcc inside the fake .avi file.
I have try avs2avi over a .avs script that have as source a large video file: but maybe because of the limit 2GB the output in my NLE result as truncated.
about AVFS: each time you load an .avs to a fake .avi you use a certain amount of ram that which could also become considerable when many clips are loaded.
But I wonder: what is the rest of all utulity/programs that to this? thanks
makeavis - from old ffdshow
avs2avi - note there are several different programs with the same name. Only one of them is the "fake avi" emulator
see post #4
https://forum.videohelp.com/threads/348212-Looking-for-copy-of-avs2avi-wrapper-v0-3 -
didn't you also have to be running an emulator or something? and is that old program still viable on current o.s.'s?
Not sure, last time I used one of those old ones was on Win XP
Newer CLI based AVFS versions work well - x86/x64 versions, v210 emulation as well (in the vapoursynth version, for professional programs)
The fourcc depends on what pixel format avisynth sends. The old AVFS PFM based version allows you to edit this in the script, even though the actual pixel format is something else. So you get garbage usually, because even though the "label" said one thing, it was actually something else
You need the actual pixel format to change, not just a label. For windows editors 8bit422 compatible fourcc and pixel format would be "UYVY". That usually "unlocks" everything, such as real YUV treatment (instead of RGB conversion, clipping). Avisynth is usually "YUY2" for 8bit422, although avisynth+ can use "YV16" or 8bit422 planar
The enable_v210 switch in vapoursynth changes the actual pixel format, 10bit422 interleaved (instead of P210, packed). v210 is accepted in all windows editors.
But he's trying to use a dinosaur, discontinued x86 NLE. So good luck with that and lack of memory problems. Have fun trying to edit UHD footage.
Create a function in Avisynth to apply this denoiser
By zerowalk in forum EditingReplies: 3Last Post: 19th Aug 2019, 08:45 -
I can create Avisynth filter with gcc?
By Megafox in forum Newbie / General discussionsReplies: 2Last Post: 21st Mar 2018, 09:33 -
does exist an avisynth fake .avi mjpeg?
By marcorocchini in forum Newbie / General discussionsReplies: 2Last Post: 12th Mar 2017, 19:31 -
Is 1080p fake?
By draig-llofrudd in forum Newbie / General discussionsReplies: 2Last Post: 7th Dec 2016, 15:40 -
H.264 video in MOV wrappers not supported
By TailG8R in forum Video ConversionReplies: 7Last Post: 22nd Aug 2016, 19:39
