It has been awhile since I last posted here.
I have a DVB-T2 set-top box and record over-the-air TV program to a USB drive.
The recorded program is stored in a folder with 2 .DVR and 1 .TS files.
I have the latest VLC player installed and it couldn't read the .TS files.
Is there any software that can read and convert it to DVD ?
Many thanks.
Results 1 to 15 of 15
Can you post the make/spec of the DVB-T2 set-top box because some of them even the cheap ones encrypt the ts files.
I don't have it with me. If the TS files are encrypted, is there a chance to decrypt it ?
If no then I have to move on get a set top that does not encrypt.
Many thanks.
Wait a minute. I have this USB HDMI capture adapter and output to DVD format. This may work.
https://forum.videohelp.com/threads/392190-USB2-HDMI-Video-Capture-Sony-HD-Video-Cam-t...er#post2542550Last edited by pchan; 14th Sep 2019 at 05:37. Reason: More info.
Post a mediainfo report of one of the files. In Australia the local company Beyonwiz, made in South Korea make a good PVR and files are not encrypted as Topfield and Humax the same. Most of the "name" units like LG and Samsung etc do encrypt.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
Hello,
I am new here and want some help if possible.
I am trying to play this file: hxxxs://s0.2mdn.net/instream/video/13734_6879584ed17e7bb4f09978bf97184598/dash/fmp4_480p_750000.mp4?sid=2fdafa9b-34eb-4ee6-8ee6-6a84ccbec285
with the VLC media player but I do not have any picture or audio and the funny thing is I can see that the file is playing. Any input will be appreciated. Thanks. -
@jamespoo,
This is what I can up with. http://www.mediafire.com/file/sg9utsk35ny3jfn/vlc-record-2020-03-11-09h38m00s-fmp4_480....mp4-.mp4/file
Thanks. -
video plays in mediaplayer classic and also show the info of the file
just shows a black screenVideo
Format : AVC
Codec ID : avc1
Duration : 26 s 80 ms
Bit rate mode : Variable
Bit rate : 79.3 kb/s
Width : 854 pixels
Height : 480 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 25.000 FPS
Bits/(Pixel*Frame) : 0.008
Stream size : 253 KiB (99%)
Language : English
Encoded date : UTC 2020-03-11 13:39:28
Tagged date : UTC 2020-03-11 13:39:28
Codec configuration box : avcC -
The video you downloaded was probably a placeholder for the real video. And look at the bitrate: 79 Kb/s. A black video is about you can get with the kind of bitrate. In short, you downloaded the wrong file. What's the URL of the web page from which you got the mp4 link?
Here you go my friend. .
By the way I was able to play it under kodi using this. But the picture break down and it is unwatchable( At least it isn't black screen ). Thanks.<item>
<title>|irokotv.com| Inpustream</title>
<inputstream>https://s-stream.irokotv.com/8199_10151c5d04502035b4e4f08f526be5e6/dash//fmp4_480p_750000.mp4</inputstream>
</item>
Set Top Box recorded File conversion
By sarathkumar in forum Video ConversionReplies: 3Last Post: 21st Aug 2017, 23:31 -
How to watch videos from Laptop on 'TV with USB enabled set-top-box'.
By Anil Kagi in forum Video Streaming DownloadingReplies: 47Last Post: 29th Jan 2016, 21:26 -
How to record internet set top box/tv
By moein in forum Capturing and VCRReplies: 16Last Post: 26th Apr 2015, 12:24 -
Hauppauge Colossus still the best bet for capturing HD Set Top box?
By kkiller23 in forum Capturing and VCRReplies: 15Last Post: 7th Dec 2014, 11:38 -
IPTV Set-top box vs HD TV Media Player
By siluet in forum DVB / IPTVReplies: 1Last Post: 5th Dec 2014, 19:27
