I know the review for this product is not so good. But taking into consideration that the user is steadfast hanging on to Windows XP and all my attempt to use software approach had not been effective, it this tool good enough to get video from Sony HD video cam to Win XP system and author into DVD format ?
that disc says it is for windows 10. doubtful it will run on winxp. what video camera?
that camera has a built in usb cable to connect to a pc, it doesn't get any easier. no need for any capture device, just transfer the files.
Sony has PlayMemories Home but it wouldn't work on WinXP. I know it best to junk the XP system. The user still have a bunch of older camcorders and familiar with XP system and his home video workflow. I already have a workaround with software approach but he seems to have problem with it. So, I am thinking that this gadget is very similar to his current camcorder video import via Firewire. I "think" he can still capture to AVI format with this device and continue on with his DVD workflow.
that camera records in XAVC S (HD 50 Mbps) and AVCHD recording onto a memory card. no need for any capture device. take out the card and use a memory card reader attached to the computer. or use the usb cable that is part of the cam to transfer files to the computer.
software to create a dvd from it - good luck with winxp i can't help you there. not only are the video formats probably not supported, the computer is probably way to old and slow to deal with newer types of video.--
I have placed an order for this item. Yes, I agree that XP is the main road block.
Will report back once I have tested it. -
OK. I got the unit. It captured OK from HDMI input and output to 720x576. This output is OK for Win XP system.
Just that the capture software that comes with it only output to DVD format. I need to capture in AVI format.
Tried using VirtualDub capture but having problem setting the 2GB file size. I will post for help in the Capture section.
Looking to make BluRay video from 1080p/60fps video shot on Sony NX100 cam
By liberty610 in forum Authoring (Blu-ray)Replies: 38Last Post: 26th Sep 2018, 21:13 -
lost charger for Sony video Hi8 analog cam
By carioca(da_gema) in forum TestReplies: 2Last Post: 12th Feb 2016, 12:10 -
Lost charger for Sony analog video cam - options?
By carioca(da_gema) in forum Newbie / General discussionsReplies: 2Last Post: 4th Jan 2016, 21:30 -
Strange Audio issue on Mobile Devices - Video taken with Sony HD Cam
By timothy001 in forum AudioReplies: 12Last Post: 6th Aug 2015, 11:38 -
Seeking HDMI -> USB2 capture device with quick pause ability?
By EmmB in forum Capturing and VCRReplies: 31Last Post: 25th Jun 2014, 12:03
