Here is the situation, I have old TV-Show DVD (dating back to 2002), they never been re-released (and probably never will) and the colors are clearly wrong (way too dark or simply flat).
I there a codec(s) with avisynth that can correct that to a normal standard (I mean automatic way) ?
I've searched and found codec autolevel and HDRAGC but not sure if it's the good way.
kalemvar1
There is no such thing as a 'normal standard', but using AutoAdjust (https://forum.doom9.org/showthread.php?t=167573) and tweaking the settings to your liking might help. SmoothAdjust (https://forum.doom9.org/showthread.php?t=154971) might also be interesting.
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini -
ColorYUV() has autogain and autowhite options: ColorYUV(autogain=true, autowhite=true). But you're usually better off doing manual adjustments.
Autolevel and HDRAGC aren't "codecs". They're luminance level adjusting filters. Sometimes they work well, sometime they don't work so well, and they always require that you learn to adjust their operating parameters for best results. Neither of those filters will correct colors.
As jagabo suggested, ColorYUV() and the Tweak() functions are suggested form manual adjustment, which usually works better anyway. Learn tom work with histograms so you can look at data graphs to know what you're doing.
http://avisynth.nl/index.php/ColorYUV
http://avisynth.nl/index.php/Tweak
http://avisynth.nl/index.php/Histogram
It would be more helpful if you could post a short sample from the video you're working with. No one is going to try to guess what your video looks like or what settings to suggest. How to make video samples from DVD or MPG using DGindex: https://forum.videohelp.com/threads/359295-Record-without-interlacing/page2#post2272359.- My sister Ann's brother -
There is also RGBAdjust() and Levels(). Some corrections need to be done in YUV, others in RGB. Some YUV operations can only be done in ColorYUV(), others in Tweak().
If you upload a sample, be sure to include shots with a range of brightnesses, multiple colors, and things where we have some idea what the colors should be.
Auto color correction in editing - Green water diving
By ShadowWizard in forum EditingReplies: 5Last Post: 9th Jul 2019, 06:32 -
To use color correction or not?
By That Tommy in forum EditingReplies: 3Last Post: 30th Aug 2018, 16:35 -
Help with color correction
By navi82 in forum RestorationReplies: 6Last Post: 3rd Apr 2017, 05:42 -
Color correction...
By ziggy1971 in forum EditingReplies: 24Last Post: 8th Feb 2015, 08:45 -
By jda in forum RestorationReplies: 4Last Post: 17th Nov 2014, 04:37
