Hello everybody,
while messing around with a bad-quality video footage, I couldn't get rid of some strong block effect. Tried with Deblock_QED, but had no luck.
Can anybody help me, please?
Here's a sample - the block effect can be found after 5 seconds, in some other spots it's even a bit stronger. For me it would be nice to remove those artifacts.
Thanks in advance.
deblock_qed() usage for interlaced video:
https://forum.videohelp.com/threads/361152-Correct-usage-of-Deblock_QED-for-Interlaced...ge#post2290489
I put it in its own function, deblock_qed_i():
In your code use something like:Code:# Deblock_QED for interlaced video function deblock_qed_i ( clip clp, int "quant1", int "quant2", int "aOff1", int "bOff1", int "aOff2", int "bOff2", int "uv" ) { quant1 = default( quant1, 24 ) # Strength of block edge deblocking quant2 = default( quant2, 26 ) # Strength of block internal deblocking aOff1 = default( aOff1, 1 ) # halfway "sensitivity" and halfway a strength modifier for borders aOff2 = default( aOff2, 1 ) # halfway "sensitivity" and halfway a strength modifier for block interiors bOff1 = default( bOff1, 2 ) # "sensitivity to detect blocking" for borders bOff2 = default( bOff2, 2 ) # "sensitivity to detect blocking" for block interiors uv = default( uv, 3 ) # u=3 -> use proposed method for chroma deblocking # u=2 -> no chroma deblocking at all (fastest method) # u=1|-1 -> directly use chroma debl. from the normal|strong deblock() last=clp par=getparity() SeparateFields().PointResize(width,height) Deblock_QED(last, quant1, quant2, aOff1, aOff2, bOff1, bOff2, uv) AssumeFrameBased() SeparateFields() Merge(SelectEven(),SelectOdd()) par ? AssumeTFF() : AssumeBFF() Weave() }
Your video has another big problem, torn fields:Code:Mpeg2Source("Sample.d2v", CPU2="ooooxx", Info=3) Deblock_QED_i(quant1=40, quant2=45)
[Attachment 49515 - Click to enlarge]Last edited by jagabo; 4th Jul 2019 at 11:29.
No, I didn't resize my source. The file I uploaded is the raw source as I received it. Thanks a lot jagabo for the tip, I played a little bit more with some parameters and the result is quite good. If anybody is able to suggest anything about the field issue, I would be very grateful.
I don't see an obvious automated fix. You could always go through the video manually:
Of course, it will take a long time to go through a full movie.Code:Mpeg2Source("Sample.d2v", CPU2="ooooxx", Info=3) Deblock_QED_i(quant1=40, quant2=45) QTGMC(preset="fast") p1 = SelectEvery(6, 0,1,2,3,4).Trim(0,89) p2 = SelectEvery(6, 1,2,3,4,5).Trim(90,294) p3 = SelectEvery(6, 0,2,3,4,5).Trim(295,415) p4 = SelectEvery(6, 0,1,3,4,5).Trim(416,596) p5 = SelectEvery(6, 0,1,2,4,5).Trim(597,762) p6 = SelectEverY(6, 0,1,2,3,5).Trim(763,954 p1 + p2 + p3 + p4 + p5 + p6 -
Here's a slightly simpler method:
That first builds the 6 possible skip-frame clips. Each will have some segments where the torn frames are removed. ReplaceFramesSimple(), included in the RemapFrames package, replaces frames in the first clip with frames taken from the second clip, as instructed by the mappings (see the docs). We use skip0 as the starting clip. Any segments where there are torn frames need to be replaced with a segment from one of the other drop-frame clips. For example, frames 295 to 415 contain torn frames in skip0 but are correct in skip2, hence the call to ReplaceFramesSimple(last, skip1, Mappings="[295 415]"). You still have to go through the video by hand looking for tears but this is easier than the way it was done in the earlier script.Code:Mpeg2Source("D:\Downloads\Sample.d2v", CPU2="xxxxxx", Info=3) Deblock_QED_i(quant1=40, quant2=45) QTGMC(preset="fast") skip0 = SelectEvery(6, 1,2,3,4,5) skip1 = SelectEvery(6, 0, 2,3,4,5) skip2 = SelectEvery(6, 0,1, 3,4,5) skip3 = SelectEvery(6, 0,1,2, 4,5) skip4 = SelectEvery(6, 0,1,2,3, 5) skip5 = SelectEvery(6, 0,1,2,3,4 ) skip0 ReplaceFramesSimple(last, skip5, Mappings="[0 89]") ReplaceFramesSimple(last, skip1, Mappings="[295 415]") ReplaceFramesSimple(last, skip2, Mappings="[416 596]") ReplaceFramesSimple(last, skip3, Mappings="[597 762]") ReplaceFramesSimple(last, skip4, Mappings="[763 954]") ReplaceFramesSimple(last, skip5, Mappings="[954 1099]")
TS Muxer creating block video?
By luciofulci in forum Authoring (Blu-ray)Replies: 4Last Post: 2nd May 2019, 08:14 -
Strong block effect
By Marcoh_ in forum RestorationReplies: 5Last Post: 18th Nov 2018, 05:39 -
Black Block during Dark Sequence
By kalemvar1 in forum Video ConversionReplies: 2Last Post: 14th Sep 2017, 19:19 -
Need Recommendation on Capture Device. (Miss Jackson if you're nasty)
By Owi in forum Capturing and VCRReplies: 26Last Post: 11th Oct 2016, 21:52 -
Block of pixels!
By alkoon in forum Capturing and VCRReplies: 3Last Post: 12th Aug 2015, 21:22
