Results 31 to 40 of 40
So now that things are working (well, in a sense) I'm left wondering how best to configure Mpeg2Source. The documentation is fine but not as explicit as I'd wish. I have two questions:
1. info=3 "Output hints in the video (as defined in utilities.cpp/utilities.h)" but what does that do exactly?
2. Post-processing options? Can I leave deblocking on by default? And when would I want to enable deringing? -
Oh I did not see your post jagabo, completely missed that the thread had reached 2nd page
So why, Mpeg2DecPlus did fix the 64 bits issue, thank you for that
I'm not sure about everything it passes but the most important is that it flags field order. This is critical with some videos.
I find its deblocking to be too strong -- it erases too much small low contrast detail. When I need deblocking I use deblock_qed(). I lets you control the strength of the deblocking. I usually use the deringing filters (CPU2="ooooxx") because it reduce the DCT ringing noise around sharp edges, without causing much damage otherwise.
Apparently there is a bug in the 64 bit version of DgDecode.dll. And whoever made Mpeg2DecPlus fixed it. -
Hmm sadly the issue isn't fully resolved. It seemed to be working fine until I stumbled upon a DVD where it does not.
[Attachment 49274 - Click to enlarge]
It only does that on the first two frames mind you, but that's still an issue. The demuxed m2v from DGIndex does not display this issue, but only because the first two frames have been dropped by DGIndex during the demuxing. That is why I believe there is no problem this time with DGDecode or MPEG2DecPlus. Just to be sure I tried encoding the file using x86 builds and even through StaxRip. Here's the d2v
So what now? I am supposed to strip the first two problematic frames? Has anyone ever run into this issue?Code:DGIndexProjectFile16 15 D:\Ripping\VIDEO_TS.VOB D:\Ripping\VTS_01_1.VOB D:\Ripping\VTS_02_0.VOB D:\Ripping\VTS_02_1.VOB D:\Ripping\VTS_02_2.VOB D:\Ripping\VTS_02_3.VOB D:\Ripping\VTS_02_4.VOB D:\Ripping\VTS_03_0.VOB D:\Ripping\VTS_03_1.VOB D:\Ripping\VTS_04_1.VOB D:\Ripping\VTS_05_0.VOB D:\Ripping\VTS_05_1.VOB D:\Ripping\VTS_06_1.VOB D:\Ripping\VTS_07_1.VOB D:\Ripping\VTS_08_1.VOB Stream_Type=1 MPEG_Type=2 iDCT_Algorithm=5 YUVRGB_Scale=1 Luminance_Filter=0,0 Clipping=0,0,0,0 Aspect_Ratio=16:9 Picture_Size=720x576 Field_Operation=0 Frame_Rate=25000 (25/1) Location=3,3818d,4,9be9 900 5 3 470575104 0 2 10 72 72 d2 f2 f2 e2 f2 f2 e2 d00 5 3 470667264 0 2 6 d2 f2 e2 f2 f2 e2 f2 f2 e2 f2 f2 e2 900 5 3 470857728 0 2 6 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 900 5 3 471044096 0 2 6 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 900 5 3 471232512 0 2 6 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 900 5 3 471427072 0 2 6 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 900 5 3 471625728 0 2 6 72 72 d2 f2 f2 e2 f2 f2 e2 f2 f2 e2 ...
Interlaced or telecine?
By gamjerr in forum Newbie / General discussionsReplies: 15Last Post: 9th Apr 2018, 19:11 -
how to Telecine in handbreak
By jamespoo in forum DVD RippingReplies: 9Last Post: 23rd Jun 2016, 10:37 -
Telecine vs De-Telecine (Handbreak)
By rdeffley in forum DVD RippingReplies: 12Last Post: 5th Jan 2015, 01:58 -
Weird weird issues - remux blu-ray m2ts to TS/MKV
By qweqwe in forum Newbie / General discussionsReplies: 2Last Post: 4th Jul 2014, 05:40 -
Unable to remove pulldown - weird VOB format?
By bergqvistjl in forum DVD RippingReplies: 84Last Post: 19th Jun 2014, 04:19
