I downloaded a vr video from Youtube using youtube-dl.
But the video is not as expected. I guess there is a problem with youtube-dl or ffmpeg downloading vr material.
See my post regarding my problem here in the forum:
https://forum.videohelp.com/threads/392980-youtube-download-vr-videos-with-one-stream-...l-split-inside
I think the problem is caused by me, handling youtube-dl and/or ffmpeg without using the necessary parameters/configuration.
Is here any experienced user who can help?
Regards
I expect that download is a vr (virtual reality 360°) video.
VR video has special format, distorded in high and width.
But has no horizontal split.
The download from youtube-dl is a wrong composition of video elements.
I guess the video is a composition of 4 x 90° components (equivalent to 4 cameras used ??)
(like hvq mentioned, potplayer shows 4 interactive angles).
And youtube-dl can't build this in a correct way.
But why? -
The video downloaded is definitely composed in this way by youtube-dl, because I switched off the use of ffmpeg and got the same download.
Maybe I can use ffmpeg to repair the video. -
Would try to find information on format - Google should have description somewhere - have no time currently to dig internet - try to do some research on this, if you find something please provide links.
Seem this is new VR format called Equi-Angular Cubemaps
https://blog.google/products/google-ar-vr/bringing-pixels-front-and-center-vr-video/
https://code.fb.com/virtual-reality/next-generation-video-encoding-techniques-for-360-video-and-vr/
Seem facebook created ffmpeg filter (afraid it need to be added to special ffmpeg build)
https://github.com/facebook/transform360
this topic may be beneficial too
https://github.com/ytdl-org/youtube-dl/issues/15267Last edited by pandy; 11th May 2019 at 15:49. Reason: Equi-Angular Cubemaps
The easiest way to get correct format is to use --user-agent "" for download,
then the video was downloaded in equirectangular panorama format from youtube.
Thanks to Pandy for it's great work.
how to use youtube.dl or ffmpeg to download video in ts
By Wizard23 in forum Video Streaming DownloadingReplies: 5Last Post: 12th May 2018, 22:00 -
please help!!! youtube-dl ERROR: ffmpeg exited with code 1
By steven salas in forum Video Streaming DownloadingReplies: 2Last Post: 4th Mar 2018, 13:12 -
Stream image and video in youtube with ffmpeg
By jonaszo in forum Video ConversionReplies: 1Last Post: 6th Jan 2018, 17:45 -
Looking for expert in ffmpeg and all codecs
By PuTa in forum LinuxReplies: 2Last Post: 13th Dec 2015, 06:02 -
Want to hire a FFMPEG expert
By gorilla_bob in forum Video ConversionReplies: 0Last Post: 15th Aug 2014, 06:07
