First of I am a newbie, maybe I am doing some things very wrong.
Source is DVDISO downloaded online, so maybe it is the fault of whoever uploaded it. But hopefully you guys can help me out here.
Source is an anime, which is probably hard telecined. NTSC format. However, I am having problems with IVTCing it using TIVTC. It will always seem combed(?)
The following avisynth script would give this frame(screenshot from virtualdub2) : https://imgur.com/a/wHSUpBp
Mpeg2source("VTS_01_1.d2v", cpu=4)
tfm(order=0, mode=1, slow=2, pp=0)
Tdecimate(mode=1)
Here is a 3 second sample which is quite problematic, without any filters: http://www.mediafire.com/file/9tazkvd1zcnythx/Test.mkv/file
I am not very sure how to upload a sample of the original file, so it had to be encoded in x264 first.
What I think is happening, is that the video was first hard telecined, and then heavily compressed, such that the parts that are interlaced contain artifacts preventing a proper IVTC from happening. However I wonder what you guys think, and if there is any way to at least make it look better even if its not perfect.
Of course, as mentioned earlier, there is a chance the source I downloaded from (the only source I can find) is the problem and I should find another copy of it.
EDIT: Want to mention that using deblock() or smoothd2() and trying it out a bit didn't really help for me, maybe I am not using the right settings.
The video is 25 fps with hard pulldown. Use TDecimate(Cycle=5, CycleR=1) or TDecimate(mode=2, rate=25).
For more complete analysis you'll need to upload a sample of the original. Make a sample of the original MPEG 2 data using DgIndex (part of the DgMpegDec package). Open a VOB, mark-in, mark-out, File -> Save project and Demux Video. Upload the resulting M2V file.
You can use DeblockQED() to reduce macroblocking (there's a variation for interlaced video.
https://forum.videohelp.com/threads/361152-Correct-usage-of-Deblock_QED-for-Interlaced...ge#post2290489
Or use Mpeg2Source() to open the video and enable it's internal deblocking. You should almost always be using Mpeg2Source with DVD source anyway.
Use vInverse() to eliminate residual combing (over compression will keep the field matching of TFM from working perfectly).
Code:Mpeg2Source("filename.d2v") AssumeBFF() Deblock_qed_i(quant1=35, quant2=35) TFM() vInverse() TDecimate(Cycle=5, CycleR=1) McTemporalDenoise(settings="high")Last edited by jagabo; 31st Jan 2019 at 07:40.
Thank you for your time in explaining, I will try out the suggestions soon, but for now here is the m2v file. The sample in the first post is at the end of this m2v file.
http://www.mediafire.com/file/8yw91oeuv750cmo/VTS_01_1.demuxed.m2v/file
Using cpu=4 for mpeg2source helps a bit but does not fully remove the problem.
EDIT: While it kind of works better now using your suggestion, there are parts where are still far from perfect. Although I use higher quant values, I guess there are some limits to fixing a bad source.Last edited by attackworld; 1st Feb 2019 at 03:53.
I cannot tell if this clip is Telecined or not...
By Lathe in forum RestorationReplies: 20Last Post: 7th Nov 2016, 00:41 -
Deinterlacing inverse telecined video
By Colek in forum Video ConversionReplies: 4Last Post: 9th Aug 2016, 08:51 -
Advice for hard telecined, variable framerate DVD?
By xAlienxx in forum DVD RippingReplies: 16Last Post: 16th Dec 2014, 16:26 -
Video heavily out of sync after using Ripbot
By Okys in forum Newbie / General discussionsReplies: 2Last Post: 1st Sep 2014, 14:42 -
Any VST plugin (or ?) to automatically and heavily compress dynamic range?
By EmmB in forum AudioReplies: 15Last Post: 7th Jul 2014, 04:51
