I have several videos I need to process using avisynth then encode to hevc/aac mkv format. I can use avsproxy and open in avidemux but I can't batch it. I have a lot of videos that use basically the same script. I can easily create a script for each file if needed but I don't have anything that takes it as an input. Can someone please recommend some software that takes avisynth files as an input or where I can use avs within the software to batch?
Also, if all the Avisynth scripts should contain identical commands, here's a nice tip I read here, from jagabo above, posted two years ago :
https://forum.videohelp.com/threads/381322-ConvertToYV12-in-Avisynth-Rec601-Rec709-PC-...ge#post2468325
Just adapt to your case... Apparently this works directly by dragging-and-dropping a file on the .bat script (I haven't tried that), but it can be modified by adding FOR loops, to process a whole directory by just double-clicking on the .bat script. Each echo ... >> ... line adds the specified command to each .avs file (with only one > it overwrites the file's current contents, that's why only the first echo line has >).Here's a convenient batch file that uses DgIndex to build an index file and create an AviSynth script to open that file:
Code:"G:\Program Files\DgIndex\DGIndex.exe" -i "%~d1%~p1%~n1%~x1" -o "%~d1%~p1%~n1" -fo 0 -om 2 -exit echo Mpeg2Source("%~d1%~p1%~n1.d2v", CPU2="ooooxx", Info=3) > "%~1.avs" echo TFM(d2v="%~d1%~p1%~n1.d2v") >> "%~1.avs" echo TDecimate() >> "%~1.avs"
If you're not familiar with Windows command line arguments (assuming you're using Windows), look here.
Also specify a -crf value if you want a better quality than the default but I just looked at ffmpeg's included help, it says that default is -1, what is that supposed to mean ? (Many other parameters have -1 as default.)replace "libmp3lame" with "aac" or "libfdk_aac". The latter is better quality but not included in some ffmpeg builds.Last edited by abolibibelot; 21st Dec 2018 at 20:22.
batch that delete one line in avisynth
By marcorocchini in forum Newbie / General discussionsReplies: 23Last Post: 1st Jan 2018, 04:15 -
Issue - Software for batch conversion SEO
By vita85 in forum Newbie / General discussionsReplies: 1Last Post: 6th Apr 2015, 07:46 -
Looking for a Batch x264 Encoder with AviSynth Support
By VideoFanatic in forum RestorationReplies: 8Last Post: 19th Sep 2014, 12:08 -
Tool for batch scaling and conversion
By MedConv in forum Video ConversionReplies: 7Last Post: 22nd Jul 2014, 13:24 -
How to check if AviSynth is installed (from a Windows batch file)
By as264 in forum EditingReplies: 9Last Post: 10th Feb 2014, 09:19
