Results 1 to 25 of 25
  1. Member Caiosouza's Avatar
    Nov 2013
    Capćo da Canoa, RS, Brazil
    I really did not want to bring this back, but this video is very rare, and I really did not get another source.
    So reviewing an old topic I felt a little hope of making it at least acceptable, lessen these comets and improve this crap a little.
    I would like some suggestion of bright minds, and I know have many here, thank you!
    Sample:
    1-More static
    2-More movement
  2. Member Caiosouza's Avatar
    Nov 2013
    Mr. Jagabo suggested me RemoveDirtMC() or RemoveSpotsMC()
    But I can not make it work
  3. Member Caiosouza's Avatar
    Nov 2013
    Mr. johnmeyer show me this:
    function Remove_TearsI(clip source) {
    #Create mask
    ml           = 100 # mask scale
    scene_change = 900 # scene change
    fields=source.SeparateFields()
    even_fields=selecteven(fields)
    odd_fields =selectodd(fields)
    super_even = MSuper(even_fields,pel=2, sharp=1)
    vfe = MAnalyse(super_even,isb=false) # forward vectors
    vbe = MAnalyse(super_even,isb=true)  # backward vectors
    cfe = MFlow(even_fields,super_even,vfe,thSCD1=scene_change) # previous compensated forward
    cbe = MFlow(even_fields,super_even,vbe,thSCD1=scene_change) # next compensated backward
    sadfe = MMask(super_even,vfe, ml=100,kind=1,gamma=1, thSCD1 = scene_change)
    msadfe= sadfe.Binarize() # binary inverted forward SAD mask
    sadbe = MMask(super_even,vbe, ml=ml, gamma=1, kind=1, thSCD1 = scene_change) # backward SAD mask
    msadbe= sadbe.Binarize() # binary inverted backward SAD mask
    msade = Logic(msadfe,msadbe,"OR") # combined inverted SAD mask
    msade = msade.Expand() # expanded inverted SAD mask
    msadie = Interleave(msade, msade, msade) # interleaved 3-frame inverted SAD mask
    Interleave(cfe,even_fields,cbe) # interleave forward compensated, source, and backward compensated
    even_result_fields=DeSpot(show=0,mscene=99,p1percent=3,dilate=3,maxpts=1000,p2=6,mthres=9,p1=12,pwidth=840,pheight=12,mwidth=7,mheight=5,merode=33,interlaced=false,seg=1,sign=0,ranked=true).SelectEvery(3,1)
    super_odd = MSuper(odd_fields,pel=2, sharp=1)
    vfo = MAnalyse(super_odd,isb=false) # forward vectors
    vbo = MAnalyse(super_odd,isb=true)  # backward vectors
    cfo = MFlow(odd_fields,super_odd,vfo,thSCD1=scene_change) # previous compensated forward
    cbo = MFlow(odd_fields,super_odd,vbo,thSCD1=scene_change) # next compensated backward
    sadfo = MMask(super_odd,vfo, ml=100,kind=1,gamma=1, thSCD1 = scene_change)
    msadfo= sadfo.Binarize() # binary inverted forward SAD mask
    sadbo = MMask(super_odd,vbo, ml=ml, gamma=1, kind=1, thSCD1 = scene_change) # backward SAD mask
    msadbo= sadbo.Binarize() # binary inverted backward SAD mask
    msado = Logic(msadfo,msadbo,"OR") # combined inverted SAD mask
    msado = msado.Expand() # expanded inverted SAD mask
    msadio = Interleave(msado, msado, msado) # interleaved 3-frame inverted SAD mask
    Interleave(cfo,odd_fields,cbo) # interleave forward compensated, source, and backward compensated
    odd_result_fields=DeSpot(show=0,mscene=99,p1percent=3,dilate=3,maxpts=1000,p2=6,mthres=9,p1=12,pwidth=840,pheight=12,mwidth=7,mheight=5,merode=33,interlaced=false,seg=1,sign=0,ranked=true).SelectEvery(3,1)
    interleave(even_result_fields,odd_result_fields)
    weave()
    [Attachment 46599 - Click to enlarge]
    [Attachment 46600 - Click to enlarge]
    Really effective, but it can be very complex to play with these numbers for me.
  4. I recognize that image. Isn't this an exact duplicate of what you (or someone else) asked about a year or two ago?
  5. Member Caiosouza's Avatar
    Nov 2013
    Yes,is this, is me
  6. Once again, with video this bad you will be trading one type of artifact for another. It's debatable whether anything you do is an improvement or not. But this might give you some ideas to work with:
    LWLibavVideoSource("1-Grotesque Anomaly-1996 MX 125.mkv")
    TNLMeans(Ax=0, Ay=0, Az=1, h=16) # reduces intensity of comets
    BilinearResize(288, 270) # smaller gives more noise reduction, larger gives less
    RemoveDirtMC(30) # reduce comets, adjust along with size
    TemporalDegrain(SAD1=200, SAD2=150, sigma=8) #general noise reduction
    MergeChroma(aWarpSharp(depth=20)) # sharpen colors
    Sharpen(0.3)
    nnedi3_rpow2(2, cshift="Spline36Resize", fwidth=src.width, fheight=src.height) # upscale
    Sharpen(0.3)
    The result is a very over filtered look but the comets are greatly reduced. You can try higher or lower settings in the filters to get the compromise you want.
  7. The following link will take you to a discussion, by this same person, of the exact same image posted here, from almost two years ago:
    Cleaning trash ...
    We're covering the same ground, going in circles.
    Déją vu.
  8. I know. I just thought I'd give it a shot since we passed the last time. And had some free time.
  9. Member Caiosouza's Avatar
    Nov 2013
    Sharpen(0.3)
    Sharpen(0.3)
    I believe you've thought about it on a coffee break ... because this looks really delicious!
    I geting error on last line, more precisely in "src"
    PS:I know it's not the same thing,but
    This Worked:
    Spline64Resize(width*2, height*2)
    Sharpen(0.3)
    Edit:
    Work... but I lost the aspect ratio...
  10. Member Caiosouza's Avatar
    Nov 2013
    Just, are my vacations
    Cleaning trash ...
    Déją vu.
    Started with..."I really did not want to bring this back..."
    I think we're walking in line, crooked, but going in some direction, thank you.
  11. Member Caiosouza's Avatar
    Nov 2013
    Does that make any sense?
    DirectShowSource("C:\Users\User\Desktop\2-Sample-1996 MX 125.mkv")
    QTGMC(InputType=1, EZDenoise=2.0, DenoiseMC=true) # Denoise
    BilinearResize(width/2, height) # downsize, clean edges, upsize, sharpen
    Santiag(strv=4, strh=4) #anti-aliasing
    Spline36Resize(width*2, height)
    [Attachment 46608 - Click to enlarge]
    Sorry renamed"My After"...It's actually jagabo mesh
  12. I'd run QTGMC while the video was downscaled. nnedi3 will get you sharper upscaling with less aliasing.
  13. Member Caiosouza's Avatar
    Nov 2013
    But I get error on "src"
    Could I have more something working focused only in this (aprox.) area?
    [Attachment 46610 - Click to enlarge]
  14. It looks like I took out the "src=last" line just after the source filter. It's just to restore the original frame size.
  15. Member Caiosouza's Avatar
    Nov 2013
    AviSynthxxx "I do not know what "src" is."
    I try This, but lost aspect ratio
    DirectShowSource("C:\Users\User\Desktop\1-Sample-1996 MX 125.mkv")
    RemoveSpotsMC()
    Spline36Resize(width*2, height*2)
  16. QTGMC(preset="very slow",edithreads=4).selecteven() plus Neatvideo V4 on Virtualdub works rather well
  17. Member Caiosouza's Avatar
    Nov 2013
    Look's Very interesting!
    Sample please
  18. Originally Posted by Caiosouza View Post
    Jesus christ!
    src=last
    Sharpen(0.3)
    Sharpen(0.3)
  19. Member Caiosouza's Avatar
    Nov 2013
    Jesus christ!
    Eu ja vi que voce nćo fez a pausa para um café...
    Muitas das vezes isso é irritante mesmo, voce fazer entender coisas que sćo simples para voce,
    Porem muitas frases podem nao ser tćo claras dependendo o contexto, ou algo assim, tipo "Sua batata esta assando, nćo fica dando sopa"...
    Bom, de repente voce prefere tomar seu "café acompanhado de um nego deitado..."
    Obrigado!
    Abraēo.
  20. As my work seems to be appreciated, for once i have uploaded the neat profiles
    video processed by neatvideo v4: here
    neatvideo profiles: here
    comparison original Vs qtgmc + neatv4
  21. Member Caiosouza's Avatar
    Nov 2013
    Really good!
    This can be an interesting combination:
    RemoveDirtMC(30)
    +neatvideo v4
    PS: ...+Tortelli Wins!
  22. tnlmeans h=16 is too strong
    qtgmc(inputtype=1) that's for a real progressive video which is not even close for this source
    My 2 cents
  23. Originally Posted by themaster1 View Post
    Yes. I was using that to reduce comets on the still shots. It does very bad things on moving shots.
    Certainly, Neat Video does a good job. Unfortunately, it's not free.
  24. I almost forgot the magic script that you could use after neat (it's not artifacts free, careful) :
    a=last
    #clense(reduceflicker=false).merge(last,0.5).clens e(reduceflicker=false)
    mot=removegrain(8,0).DepanEstimate(range=2)
    take2=a.depaninterleave(mot,prev=2,next=2,subpixel =2)
    clean1=take2.selectevery(5,2)
    sup1 = clean1.minblur(1).removegrain(11,0)
    \ .mt_lutxy(clean1,"x 1 + y < x 2 + x 1 - y > x 2 - y ? ?",U=2,V=2)
    \ .msuper(pel=2,sharp=0)
    sup2 = a.msuper(pel=2,levels=1,sharp=2)
    ###### Good mvtools values, Do not change, checked##########
    bv22=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
    bv21=sup1.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=16,ov erlap=8,search=5,searchparam=4,DCT=5)
    fv21=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
    fv22=sup1.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=16,overlap=8,search=5,sear chparam=4,DCT=5)
    interleave(a.mcompensate(sup2,fv22),a.mcompensate( sup2,fv21),a,a.mcompensate(sup2,bv21),a.mcompensat e(sup2,bv22))
    mergeluma(TMedian2(),0.9).mergechroma(TMedian2(),1 ).selectevery(5,2)
    sup3 = last.msuper(pel=2,sharp=2)
    bv33=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    bv32=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    bv31=sup3.manalyse(isb=true, truemotion=false,global=true,delta=1,blksize=8,ove rlap=4,search=5,searchparam=4,DCT=5)
    fv31=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    fv32=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    fv33=sup3.manalyse(isb=false,truemotion=false,glob al=true,delta=1,blksize=8,overlap=4,search=5,searc hparam=4,DCT=5)
    last
    # To remove small Black streaks and some white dots :
    noisy = last
    nonoise = RemoveDirtMC()
    # note:Can work best with : nonoise = RemoveDirtMC.fft3dfilter(sigma=7.0,sigma2=7.0,sigm a3=7.0,sigma4=7.0, bt=1, bw=32, bh=32, ow=16, oh=16,plane=0, sharpen=0.0,interlaced=false,dehalo=0.0)
    diff = 5 # default10 / between 18- 5 to remove more or less
    m = mt_lutxy(noisy,nonoise,"y x - "+string(diff)+" - 255 *")
    mt_merge(noisy,nonoise,m)
    Function EdgeCleaner(clip c, float "strength", bool "rep", int "rmode", int "smode", bool "hot", bool "fix") {
    strength = default(strength, 8.0)
    rep = default(rep, true)
    rmode = default(rmode, 17)
    smode = default(smode, 0)
    hot = default(hot, false)
    fix = default(fix, true)
    c = (c.isYV12()) ? c : c.ConvertToYV12()
    strength = (smode==0) ? strength : strength+4
    main = c.aWarpSharp(strength,1)
    main = (rep) ? Repair(main,c,rmode) : main
    mask = c.mt_edge("prewitt",4,32,4,32).mt_invert().mt_conv olution()
    final = (!hot) ? mt_merge(c,main,mask) : Repair(mt_merge(c,main,mask),c,2)
    final = (fix) ? Overlay(final,c.ConvertToRGB24().Crop(0,1,-c.width+1,-c.height+2),x=0,y=1) : final
    final = (smode != 0) ? mt_merge(final,c,c.StarMask(smode)) : final
    return final
    function StarMask(clip c, int "mode") {
    mode = default(mode, 1)
    clean = (mode==1) ? c.RemoveGrain(17) : Repair(c.Deen("a3d",4,12,0),c,15).RemoveGrain(21)
    diff = (mode==1) ? mt_makediff(c,clean) : NOP
    final = (mode==1) ? diff.Greyscale().Levels(40,0.350,168,0,255).remove grain(7,-1).mt_edge("prewitt",4,16,4,16) : \
    Subtract(mt_merge(clean,c,c.mt_edge("roberts",0,2, 0,2).mt_expand(mode=mt_circle(1)).mt_invert()),c). mt_edge("roberts",0,0,0,0).mt_deflate()
    return final
    function MinBlur(clip clp, int r, int "uv")
    uv = default(uv,3)
    uv2 = (uv==2) ? 1 : uv
    rg4 = (uv==3) ? 4 : -1
    rg11 = (uv==3) ? 11 : -1
    rg20 = (uv==3) ? 20 : -1
    medf = (uv==3) ? 1 : -200
    RG11D = (r==0) ? mt_makediff(clp,clp.sbr(),U=uv2,V=uv2)
    \ : (r==1) ? mt_makediff(clp,clp.removegrain(11,rg11),U=uv2,V=u v2)
    \ : (r==2) ? mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20),U=uv2,V=uv2)
    \ : mt_makediff(clp,clp.removegrain(11,rg11).removegra in(20,rg20).removegrain(20,rg20),U=uv2,V=uv2)
    RG4D = (r<=1) ? mt_makediff(clp,clp.removegrain(4,rg4),U=uv2,V=uv2 )
    \ : (r==2) ? mt_makediff(clp,clp.medianblur(2,2*medf,2*medf),U= uv2,V=uv2)
    \ : mt_makediff(clp,clp.medianblur(3,3*medf,3*medf),U= uv2,V=uv2)
    DD = mt_lutxy(RG11D,RG4D,"x 128 - y 128 - * 0 < 128 x 128 - abs y 128 - abs < x y ? ?",U=uv2,V=uv2)
    clp.mt_makediff(DD,U=uv,V=uv)
    return(last)
    # median of 5 clips from Helpers.avs by G-force
    Function Median2(clip "input_1", clip "input_2", clip "input_3", clip "input_4", clip "input_5", string "chroma")
    chroma = default(chroma,"process") #default is "process". Alternates: "copy first" or "copy second"
    #MEDIAN(i1,i3,i5)
    Interleave(input_1,input_3,input_5)
    chroma == "process" ? Clense(reduceflicker=false) : Clense(reduceflicker=false,grey=true)
    m1 = selectevery(3,1)
    #MAX(MIN(i1,i3,i5),i2)
    m2 = input_1.MT_Logic(input_3,"min",chroma=chroma).MT_L ogic(input_5,"min",chroma=chroma).MT_Logic(input_2 ,"max",chroma=chroma)
    #MIN(MAX(i1,i3,i5),i4)
    m3 = input_1.MT_Logic(input_3,"max",chroma=chroma).MT_L ogic(input_5,"max",chroma=chroma).MT_Logic(input_4 ,"min",chroma=chroma)
    Interleave(m1,m2,m3)
    selectevery(3,1)
    chroma == "copy first" ? last.MergeChroma(input_1) : chroma == "copy second" ? last.MergeChroma(input_2) : last
    ConverttoRGB32(matrix="rec601",interlaced=false)
    LoadVirtualDubPlugin("C:\Program Files (x86)\VirtualDub\plugins\Camcorder_Color_Denoise_s se2.vdf", "CCD", 1)
    CCD(7,1) # de 0 ą 100 # Défaut =30 /
    converttoyv12(matrix="rec601",interlaced=false)
    Return(last)
    function TMedian2(clip c) {
    Median2( c.selectevery(1,-2), c.selectevery(1,-1), c, c.selectevery(1,1), c.selectevery(1,2) ) }
    function RemoveDirt(clip input, int limit, bool _grey)
    clensed=input.Clense(grey=_grey, cache=4)
    alt=input.RemoveGrain(2)
    return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,dmode=2,debug=false,noise=li mit,noisy=4, grey=_grey)
    # Alternative settings
    # return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=4,cthreshold=6, gmthreshold=40,dist=1,dmode=2,debug=false,noise=li mit,noisy=12,grey=_grey,show=true)
    # return RestoreMotionBlocks(clensed,input,alternative=alt, pthreshold=6,cthreshold=8, gmthreshold=40,dist=3,tolerance= 12,dmode=2,debug=false,noise=limit,noisy=12,grey=_ grey,show=false)
    Processed video (with the script above): https://mega.nz/#!N05DTQaJ!2GCTwr9AYDFAIa8czzzx7oosga2wegIHNOh2NHG5PA8
    example (Neat v4, Neat+Script above, Original):
  25. I just A/B'd between the two pics, and your improvement over using just Neat Video was quite good. Nice job.
