Hi guys, what is the best way to transfer video8 tape to PC? Which video8 cam to search for, what outputs, do they have S-Video out?
Results 1 to 15 of 15
Aha, got it somewhere myself, seems there are digital 8 cams that playback both hi8 and video 8, and also have TBC/DNR, that way you can transfer via firewire same as with MiniDV.
Just one thing though, is it better to use backward compatible digital 8 cam and play video 8 tape to pc via firewire, or to use dedicated older video 8 cam and transfer via s-video? Depends on the quality of the source, if it needs hardware processing on the fly or not? Or one thing is mostly better than the other?
I would use a Hi-8 or Digital8 player/camera to play back Video8 over S-Video. And most Video8 camcorders don't have S-Video out to my knowledge.
My old thread https://forum.videohelp.com/threads/381533-Video8-Player-vs-Digital8-Camcorder-for-capturing-Video8 -
That's convenient and saves having to use a separate analog-digital converter. But you may not like the look of DV compression. And some cams (looking at YOU, Sony) render incorrect black level this way. Furthermore, if you have a newer computer you may run into finicky behavior over the IEEE1394 interface.
YesThe rule of thumb would be to use th S-Video out for Hi8 playback and transfer to PC?
Just occured to me, what am I gonna do with audio transfer? The camcorder has no standard RCA white and red out jacks, only AV minijack (I don't even have that cable, no idea what it looks like), and it also has headphone stereo minijack.
The camera is Sony DCR-TRV120ELast edited by kodec; 31st Jan 2019 at 12:04.
You are going to want to use the 3.5mm A/V jack over the 3.5mm headphone jack, as the A/V jack should be straight off the tape without any processing or amplification.
Ok got it, and now I know how the cable looks like for the A/V jack, thanks, found it already.
And the last thing; my usual workflow for the VHS is:
VCR - DVD Recorder pass - TBC - PC
Where should I put the this camera Hi8 source here? Also, leave something of the original workflow out? -
Your camera has TBC and DNR options built in. I would try those out first, that's what I use on my Sony Digital8.
+2 on what JVRaines said.
Straight wire is best unless other factors dictate additional components.
Video8 Player vs Digital8 Camcorder for capturing Video8
By KarMa in forum Capturing and VCRReplies: 0Last Post: 1st Dec 2016, 18:56 -
Starting off with Video8
By video8pal in forum Capturing and VCRReplies: 23Last Post: 14th Mar 2016, 20:29 -
Video recorded from IP Cam - No audio unless I play back with IP Cam app
By momo123 in forum Software PlayingReplies: 5Last Post: 10th Aug 2015, 12:58 -
Dig8 cam as passthrough for Video8 / Hi8 transfers
By KingBuZZo in forum Capturing and VCRReplies: 3Last Post: 21st Mar 2014, 14:18 -
Video8 Camcorder
By VideoChunkster in forum Capturing and VCRReplies: 3Last Post: 25th Jan 2014, 03:25
