I noticed Orsetto and few people talking about the ER310
most vcrs had composite or s-video output
vcr --> s-video --> polaroid 2001g --> component --> AverMedia ER310 --> h.264 files
has anyone tried using the ER310 for vhs capture?
[update 2018-07-05]
i picked one up, used a tivo hd for test as a component source
[followup #1 .. ugh]
VRD has a problem editing 480i recordings
[followup #2.. solution]
VRD has a workaround setting for 480i recordings
[followup #3.. more progress]
i'm discussing it more over on avsforum,
but found esata to hdd cables can be used backwards
to connect an external esata device to the internal sata connector
did a youtube video
the on device video editor is not bad, but can delay when marking edit points
while it searches for GOP points where it can make fresh cuts
the er310 seems to have Black level control, which it calls STB range
the er310 has an ethernet port, but its not very useful
in three years and ten firmware updates they seem
to have focused on stability and bug fixes
rather than adding new features
there is more to explore
- not sure if the IR blaster is for controlling an STB or being controlled by an STB
- scheduler and input detected power on seem to be alternatives of the same feature
- remote hints at either a CD playback or DVD burner feature using USB drives
wish i could just talk to an avermedia developer for a few minutes
nothing has come of a tech support ticket
Results 1 to 1 of 1
[AVerMedia News] Avermedia RECentral HDCP Protect Remove!!!
By Cauptain in forum Capturing and VCRReplies: 222Last Post: 10th Dec 2025, 12:12 -
Issues with AVerMedia Capture Card and AmaRec
By ArianK in forum Newbie / General discussionsReplies: 1Last Post: 10th Aug 2017, 16:07 -
Game HD capture devices (Elgato, Avermedia, Hauppage) for vhs capturing
By videorecover in forum Capturing and VCRReplies: 4Last Post: 7th Jan 2016, 18:48 -
AverMedia H727 HD Capture PCIe problems!
By daryljones92 in forum Capturing and VCRReplies: 17Last Post: 1st Feb 2014, 18:41 -
AVermedia Capture HD - Playstation
By kurtangle in forum Capturing and VCRReplies: 2Last Post: 14th Dec 2013, 21:03
