I compressed a dvd using x264. The length of the movie is 2 hrs 9 mins but when i add the .ac3 track to the video file using mkvtoolnix the output file shows a length of 2 hrs 55 mins in media player. I checked it in vlc, mpv, and mpc hc. All three of them display 2 hrs 55 mins runtime. Can someone tell me why the video duration changed after adding audio track?
Duration : 2 h 9 min
Bit rate : 1 419 kb/s
Width : 702 pixels
Height : 460 pixels
Display aspect ratio : 1.85:1
Frame rate mode : Constant
Frame rate : 23.976 (24000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 0.183
after adding audio track with mkvtoolnix v20
[Attachment 44713 - Click to enlarge]
The problem is probably video ends at 2hrs9mins and rest is audio. Have you checked the end of videofile? If video is also 2:55 and audio is in sync everything is o.k.
Bernix -
But both video and audio are in-sync and overall correct in the first 2:09 of the file? Then you could simply cut the remaining garbage in mkvtoolnix.
Which DVD, btw? How did you decrypt it? There are times when you can't simply use DGIndex on the VOBs. -
[Solved] Wrong length in IFO and missing subtitles after extracting
By ZikO in forum DVD RippingReplies: 3Last Post: 16th Nov 2015, 09:48 -
Stream length is wrong in Audacity
By sambat in forum AudioReplies: 8Last Post: 4th Nov 2014, 13:00 -
Remuxing M4V video into WMV
By JackSpicer0 in forum Newbie / General discussionsReplies: 9Last Post: 7th Feb 2014, 12:36 -
Remuxing mp4 makes video different length and desynced
By javaman in forum Video ConversionReplies: 3Last Post: 19th Aug 2013, 21:20 -
Remuxing give different bitrate for video
By moth2daflame in forum Blu-ray RippingReplies: 5Last Post: 12th Mar 2013, 14:35
I forgot to check subtitle before.
