i'm trying VirtualDub FilterMod. Trying to export an mp4 file, but getting
i tried these old steps, but i don't see a VirtualDub "Color Depth" option on Video menu.raw video codec not currently supported in container
https://encodingtalk.com/threads/virtualdub-save-direct-to-mp4-fraps-to-youtube-with-e...encoders.2446/
also found these old steps, but i already seem to have mp4 codec I THINK.
https://forum.videohelp.com/threads/355062-VirtualDub-MPEG-2-MPEG-4-saving#post2232615
and
http://forum.timescapes.org/phpBB3/viewtopic.php?p=34660&sid=8f01ce42c587026b03216b15a5bfcb16#p34660
i've got this installed:
https://sourceforge.net/projects/virtualdubffmpeginputplugin/
any ideas?
thx
AnonymousGuestMaybe you're trying to save UN-compressed video to an MP4 file?i'm trying VirtualDub FilterMod. Trying to export an mp4 file, but getting
In fact, the MP4 container does not support uncompressed video.
I don't use VDFMod, so I'm only guessing...
Some uncompressed variants work in mp4.
Working: YV12, YV16, YV24, YUYV, V210
Not working: rgb24, rgb32 -
Depends on codec - i bet that mov container i.e. foundation for mp4 container had support for uncompressed RGB.
MP4 is highly limited container and personally trying to avoid mp4 as much as possible.
ffmpeg error "mp3 not supported by h264_mp4toannexb"?
By pxstein in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2017, 04:45 -
[SOLVED] "--ipratio" "--pbratio"+"--scenecut" "--minkeyint" / "--keyint
By Kdmeizk in forum Video ConversionReplies: 14Last Post: 21st Jun 2015, 08:21 -
convert three files : ".au" ".temp_audio" " .temp_video" files to mp4
By correx in forum Video ConversionReplies: 4Last Post: 20th Nov 2014, 05:15 -
Problem with MeGUI: Error Code "1" when using .MP4 source
By ArmoredChocobo in forum Video ConversionReplies: 1Last Post: 1st May 2014, 01:29 -
FFMPEG/Virtualdub: "error: multiple chroma blocks not supported"
By marcorocchini in forum Newbie / General discussionsReplies: 0Last Post: 20th Apr 2014, 08:15
