Hi guys,
I have a fair amount of experience with digital video. I usually use Virtualdub however I realise AVIsynth may be the appropriate tool for this job.
The footage here is sourced from a miniDV NTSC tape. The frametrate is currently 29fps however I'm not sure what the original framerate of the footage was when it was originallly shot.
Here is a clip of the footage - https://www.sendspace.com/file/grhwyo
I'm interesting in the best way to IVTC it. I've tried the auto IVTC in virtualdub however there are still some combed frames left over.
10-11 seconds into the source video (where the 2 ladys are running) there is no interlacing which is strange. When doing the IVTC in vDub, interlacing appears on that segement. Does the video contain both interlaced and de-interlaced footage? Can this be IVTCed?
Here is a sample of the footage -
Any help would be greatly appreciated. I would like to learn more and develop my IVTC-ing abilities.
				Results 1 to 21 of 21
	Most of the video is 24p but the short segment of the two women running is 30p. If you IVTC the whole clip to 24p the 30p shot will get jerky (see attached video). If that's the only 30p shot it probably isn't worth worrying about.
 AviSynth script:
 Resulting video (no audio):Code:AviSource("Video 1.avi") TFM() # field match TDecimate() #reduce 29.97 fps to 23976 fps, preferentially discarding duplicate frames
 Thanks. I'll try your recommendation. Out of interest would it possible to perform the IVTC in virtualdub to achieve the same result as AVisynth?
	TFM/TDecimate is so good, I can't imagine using anything else. It does many sophisticated tests to make sure the fields are matched and then decimated correctly.
	The particular 30p shot is mostly panning and can be converted fairly well to 25p with motion interpolation.
 SmoothFPS2() can be found here: https://forum.videohelp.com/threads/335908-How-can-I-get-the-smoothest-slow-motion-out...ip#post2085931Code:import("C:\Program Files (x86)\AviSynth\plugins\SmoothFPS2.avs") AviSource("Video 1.avi") part1 = Trim(0, 308).TFM().TDecimate() part2 = Trim(309, 343).SmoothFPS2(24000,1001) part3 = Trim(344,0).TFM().TDecimate() part1+part2+part3
 This type of motion interpolation can result in gross distortions but it works pretty well here.
	I bobbed the video (Bob Doubler in VirtualDub, Bob() in AviSynth and counted duplicate (aside from bob artifacts) frames. Most of the video had a 2:3 pattern of duplicates Ie, AABBBCCDDD... That means 2 two film frames was converted to 5 fields. 2/5 of 59.94 is 23.976. In the 30p shot every frame was repeated once, ie AABBCCDD... 1/2 of 59.94 is 29.97.
	Try this along with TIVTC to remove or hide the artifacts you do not wish to see.
 Santiag()
	I cannot find SmoothFPS2.avs anywhere. Does anyone have it so I can put it in my plugins folder?
	Apologies. Although I am experienced with digital video, I am an AVIsynth novice.
 I created SmoothFPS.avs in the Avisynth plugins folder with the following code:
 function SmoothFPS(clip source, float fps) {
 fp=fps*100
 backward_vec = source.MVAnalyse(isb = true, truemotion=true, pel=2, idx=1)
 # we use explicit idx for more fast processing
 forward_vec = source.MVAnalyse(isb = false, truemotion=true, pel=2, idx=1)
 cropped = source.crop(4,4,-4,-4) # by half of block size 8
 backward_vec2 = cropped.MVAnalyse(isb = true, truemotion=true, pel=2, idx=2)
 forward_vec2 = cropped.MVAnalyse(isb = false, truemotion=true, pel=2, idx=2)
 return source.MVFlowFps2(backward_vec, forward_vec, backward_vec2, forward_vec2, num=int(fp), den=100, idx=1, idx2=2)
 DirectShowSource("video.ext") #or whatever is appropriate for your source
 AssumeFPS(10) # 60 fps slowed to 1/6, 10 fps
 SmoothFPS(30) # interpolate new frames to 30 fps
 I then created a avs file in the same folder as the source video with the following code:
 Problem is I get an error stating there is no functio named "SmoothFPS2"
	You defined a function called SmoothFPS() then tried to call a function called SmoothFPS2(). The name of the AVS file doesn't matter, then name in the function declaration is what matters.
 Also, these lines:
 Should not be in the SmoothFPS2.AVS file.Code:DirectShowSource("video.ext") #or whatever is appropriate for your source AssumeFPS(10) # 60 fps slowed to 1/6, 10 fps SmoothFPS(30) # interpolate new frames to 30 fps
 Copy/Paste from the link I gave for SmoothFPS2.AVS.Last edited by jagabo; 21st Oct 2017 at 17:56.
 I thank and appreciate your help and patience with me so far. So I created SmoothFPS2.AVS in my plugins folder with the following:
 I then amended my AVS file for my video to read:Code:function SmoothFPS2(clip source, int num, int den) { super = MSuper(source, pel=2, hpad=0, vpad=0, rfilter=4) backward_1 = MAnalyse(super, chroma=false, isb=true, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) forward_1 = MAnalyse(super, chroma=false, isb=false, blksize=16, searchparam=3, plevel=0, search=3, badrange=(-24)) backward_2 = MRecalculate(super, chroma=false, backward_1, blksize=8, searchparam=1, search=3) forward_2 = MRecalculate(super, chroma=false, forward_1, blksize=8, searchparam=1, search=3) backward_3 = MRecalculate(super, chroma=false, backward_2, blksize=4, searchparam=0, search=3) forward_3 = MRecalculate(super, chroma=false, forward_2, blksize=4, searchparam=0, search=3) MBlockFps(source, super, backward_3, forward_3, num, den, mode=0) }
 Unfortunately, the AVS file does not open. Upon closer inspection in AVSP, when trying to view the video, I get 'Not a clip' error.Last edited by Imy; 22nd Oct 2017 at 07:24.
	Does the error message say anything else useful? Like the line number? The name of the function causing the problem? Do you have MvTools2 installed?
	Oh, you're missing the last line, the one that appends the three parts. See post #6.
	That work's now. Apologies for excluding that line.
 I'm amazed at how intelligdent TFM and TDecimate are..
  Staxrip 'Failed to open source, try another source filter?'By hanaluluelle in forum Video ConversionReplies: 0Last Post: 1st Mar 2017, 02:44
  Sync of video from one source to audio from another source (same content)By tbbttbbt in forum AudioReplies: 2Last Post: 5th May 2016, 16:10
  how to IVTC in handbrakeBy jamespoo in forum DVD RippingReplies: 2Last Post: 13th Oct 2014, 03:40
  How to IVTCBy jamespoo in forum DVD RippingReplies: 1Last Post: 29th Sep 2014, 19:39
  IVTC issueBy Acetyl in forum RestorationReplies: 39Last Post: 7th Aug 2013, 16:50
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
