Let's see. First there was Yahoo! Then, yadif. Now, there is yafnle—the magic answer to 90% of the questions on this forum. Of course, it is crippleware (check out the "Comparison"), and unfortunately for me, some are deal killers. Anyhow, definitely worth a look if you ever wanted to play like the big boys.
http://www.avid.com/media-composer-first
Καλημέρα . Μήπως κάποιος φίλος γνωρίζει κάποιο πρόγραμμα αξιόπιστο για μενού και κάψιμο dvd . Και ποιο είναι ;
Good morning. Does a friend know a reliable program for menus and burn DVDs and which ones?
JMO,
Very crippled on import formats. Still Avid sticks with Quicktime codecs, that's a real shame.
Really this reminds me of Avid Free that was based on Newscutter. Avid really screwed themselves about 6-7 years ago. They didn't support a lot of file formats, so it required transcoding first. Grass Valley Edius has really taken over Avid's spot -
The way I see it, Avid First is a glass half empty/glass half full kind of deal. You have almost all the editing power of Avid -- same interface, most of the capabilities, but some retrictions on number of tracks and input and output formats.
True your output is restricted to .mov, but you are not (as far as I can tell) restricted to the ultra slow quicktime engine while working. DNxHD and DNxHR both use Avid's own 64-bit media processing for transcodes and effect rendering. (Same-As-Source outputs should also be fast.)
For actual content creation editing, it should be almost as good as using Media Composer -- and of course there's a free 30 day trial version of Media Composer if you want to check that out. I believe projects are NOT compatible, so you can't for example, make your show, download MC, bring the A|1 project in and output. -
Avid Media Composer 8.7.2. Normal playback too slow.
By CardioidB in forum EditingReplies: 1Last Post: 4th Feb 2017, 16:46 -
Getting video from AVID to anything else
By MollyO17 in forum Video ConversionReplies: 6Last Post: 26th Mar 2016, 18:08 -
Media Composer Advice
By SameSelf in forum Video ConversionReplies: 4Last Post: 16th Apr 2015, 20:23 -
How much Harddrive Space does Avid Media Composer require?
By p3aul in forum Newbie / General discussionsReplies: 5Last Post: 4th Jun 2014, 23:54 -
looks like avid is going it's own way again
By aedipuss in forum Latest Video NewsReplies: 1Last Post: 20th May 2013, 19:36
