Hi,
I can't download the 1080p video from http://www.msn.com/en-gb/video/watch/neil-clough-the-apprentice-2013-exit-interview/vp-BBGrMq with youtube-dl.
However I got this resultCode:youtube-dl >youtube-dl -v -F "http://www.msn.com/en-gb/video/watch/neil-clough-the-apprenti ce-2013-exit-interview/vp-BBGrMq" [debug] System config: [] [debug] User config: [] [debug] Custom config: [] [debug] Command-line args: ['-v', '-F', 'http://www.msn.com/en-gb/video/watch/ne il-clough-the-apprentice-2013-exit-interview/vp-BBGrMq'] [debug] Encodings: locale cp949, fs mbcs, out cp949, pref cp949 [debug] youtube-dl version 2017.06.05 [debug] Python version 3.4.4 - Windows-8-6.2.9200-SP0 [debug] exe versions: ffmpeg N-86175-g64ea4d1, ffprobe N-86175-g64ea4d1 [debug] Proxy map: {} [MSN] neil-clough-the-apprentice-2013-exit-interview: Downloading webpage [MSN] neil-clough-the-apprentice-2013-exit-interview: Downloading ISM manifest WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WMAP is not a supported codec [info] Available formats for BBGrMq: format code extension resolution note http-0 mp4 320x180 http-1 mp4 640x360 http-2 mp4 1024x576 http-3 mp4 1280x720 http-4 mp4 1920x1080 (best)
I works fine with other resolution. can't download only 1080p.Code:>youtube-dl -v -f http-4 "http://www.msn.com/en-gb/video/watch/neil-clough-the-a pprentice-2013-exit-interview/vp-BBGrMq" [debug] System config: [] [debug] User config: [] [debug] Custom config: [] [debug] Command-line args: ['-v', '-f', 'http-4', 'http://www.msn.com/en-gb/vide o/watch/neil-clough-the-apprentice-2013-exit-interview/vp-BBGrMq'] [debug] Encodings: locale cp949, fs mbcs, out cp949, pref cp949 [debug] youtube-dl version 2017.06.05 [debug] Python version 3.4.4 - Windows-8-6.2.9200-SP0 [debug] exe versions: ffmpeg N-86175-g64ea4d1, ffprobe N-86175-g64ea4d1 [debug] Proxy map: {} [MSN] neil-clough-the-apprentice-2013-exit-interview: Downloading webpage [MSN] neil-clough-the-apprentice-2013-exit-interview: Downloading ISM manifest WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WVC1 is not a supported codec WARNING: [MSN] WMAP is not a supported codec [debug] Invoking downloader on 'http://msnvideo-s.akamaihd.net/ondemand/o01/ENGB _msnvideo_ENGB_msnvideo_original_tv/1004/77d81fbd-1824-4a5b-bc0e-1d9b422bc66b.is m' ERROR: unable to download video data: HTTP Error 400: Bad Request Traceback (most recent call last): File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\bu ild\youtube_dl\YoutubeDL.py", line 1804, in process_info File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\bu ild\youtube_dl\YoutubeDL.py", line 1746, in dl File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\bu ild\youtube_dl\downloader\common.py", line 360, in download File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\bu ild\youtube_dl\downloader\http.py", line 61, in real_download File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp6q2mjw76\bu ild\youtube_dl\YoutubeDL.py", line 2107, in urlopen File "C:\Python\Python34\lib\urllib\request.py", line 470, in open File "C:\Python\Python34\lib\urllib\request.py", line 580, in http_response File "C:\Python\Python34\lib\urllib\request.py", line 508, in error File "C:\Python\Python34\lib\urllib\request.py", line 442, in _call_chain File "C:\Python\Python34\lib\urllib\request.py", line 588, in http_error_defau lt urllib.error.HTTPError: HTTP Error 400: Bad Request >
Anyone can help with this issue?
Results 1 to 9 of 9
I just noticed that when I try to download 1080p, youtube-dl gives me the url "~.ism" unlike other resolution.
So I was searching how to download files from '.ism' url, and I found out "ismdownloader" reading this thread.
And it works!!! -
Hi ,
There are only 4 qualities available : LQ , SD , HQ , HD .
Cheers .JE SUIS CHARLIE !!! -
nzhd
Given the url:
Can you explain exactly (with screenshots) how you downloaded the 1080p file. I can't follow the lengthy thread you referred to.Code:http://msnvideo-s.akamaihd.net/ondemand/o01/ENGB_msnvideo_ENGB_msnvideo_original_tv/1004/77d81fbd-1824-4a5b-bc0e-1d9b422bc66b.ism
I've one question: how can you select (among those listed, see below) the bit rate? I see that if you don't select a bit rate, the best one is automatically downloaded.
Link to ismdownloader:Code:ismdownloader "http://msnvideo-s.akamaihd.net/ondemand/o01/ENGB_msnvideo_ENGB_msnvideo_original_tv/1004/77d81fbd-1824-4a5b-bc0e-1d9b422bc66b.ism/Manifest" "output.mkv"
https://files.videohelp.com/u/61125/ismdownloader.zip
How to use:
I placed the yellow folder of ismdownloader on the C drive (see screenshot1). The output file (when completely downloaded) will appear in the ismdownloader folder (see screenshot2). I start the command prompt and navigate to the ismdownloader folder.
Then I paste in above command.
Note: parts in blue are what I typed or pasted into the command line
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
C:\Documents and Settings\default>cd..
C:\Documents and Settings>cd..
C:\>cd ismdownloader
C:\ismdownloader>ismdownloader "http://msnvideo-s.akamaihd.net/ondemand/o01/ENGB
ismdownloader v2.0.0.0 beta
Created by DVB-Crew
Manifest:
Url: http://msnvideo-s.akamaihd.net/ondemand/o01/ENGB_msnvideo_ENGB_msnvideo_ori
Duration: 00:04:18.0930000
Stream 1:
WVC1 1920x1080 (1920x1080) @ 5500 kbps [selected]
WVC1 1464x824 (1920x1080) @ 3711 kbps
WVC1 1124x632 (1920x1080) @ 2504 kbps
WVC1 852x480 (1920x1080) @ 1689 kbps
WVC1 656x368 (1920x1080) @ 1140 kbps
WVC1 496x280 (1920x1080) @ 769 kbps
WVC1 384x216 (1920x1080) @ 519 kbps
WVC1 292x164 (1920x1080) @ 350 kbps
Stream 2:
WMAP 2 channels 48000 Hz @ 128 kbps [selected]
Recording duration:
00:04:18.1356667
Downloading finished!
Muxing selected tracks to MKV
99%
Mux completed in 00:00:06.9218750
Done
C:\ismdownloader>Last edited by jimdagys; 11th Jun 2017 at 21:56.
Inability to download Youtube video by Youtube Downloader HD
By jgp123 in forum Video Streaming DownloadingReplies: 9Last Post: 17th Nov 2015, 05:03 -
Download 1080p video from YouTube (savefrom.net)
By DonSeenu in forum Video Streaming DownloadingReplies: 3Last Post: 4th Nov 2015, 09:10 -
What tool can at the moment (!!) download 1080p from youtube?
By flashandpan007 in forum Video Streaming DownloadingReplies: 40Last Post: 25th Aug 2014, 13:35 -
Why can't I get 1080p videos from Youtube?
By jmac698 in forum Video Streaming DownloadingReplies: 26Last Post: 7th Aug 2014, 13:46 -
SIZE - Hauppauge PVR 1080p HD capture vs Youtube 1080p HD video
By the Devil in forum Video ConversionReplies: 4Last Post: 18th Feb 2014, 19:49
