I'm puzzled by how MKV Cutter is supposed to save my edit.
Have tried may times and something goes wrong where all that is created is a shortcut.
The problem is at the second screen where the Output and Temp tabs are at top.
No combination I've tried has given me a Save mkv file. The Temp folder stays empty.
While this should be a simple problem it has me stumped-- even with a little help file I made
long ago, nothing seems to save the file.
What I had was:
Click Output
The name the file at the new window
A Save button is in that window, so
Then there's something to do with the Temp Button in MKV Cutter which has
some function.
Please give the sequence to save the edit.
Closed Thread
This is how one uses 'MKV Cutter': (or how the author envisioned one would use it)
- Start MKV Cutter
- Press 'Open Source' and select the .mkv file you want to cut.
- MKV Cutter will now use MkvInfo, Mediainfo and h264_analyse to anaalyse the source will, once it's finished a new screen will show.
- Here one selects the parts of the movie one wants to keep.
- Go to a 'start-point' of a section you want to keep.
- Press 'Cut-Start'
- Go to the 'end-pont' of the current section you want to keep.
- Press 'Cut-End'
- The selected section should now be highlighted on the slider.
- Press 'Add to Cut-List', so the selection section will be remebered.
- Repeat step 5.-10. for all sections you want to keep.
- Press 'Commit Cut-List' to finish the selection definition.
- In the next view you set the 'Output' (File) and 'Temp folder'
- Press 'Output' and set the name and location of the output file.
- Press 'Temp folder' to set the folder that is used for temporal files.
- Press 'Next' to start the actual processing.
- Wait till 'MKVCutter' is done and the 'Finished!' popup appears.
The 'Save'-button allows one to optionally save a text file which contains the cuts.
(this is only useful if you have to make a lot of cuts and don't have the time to select all the cuts in one go)
Cu Selurusers currently on my ignore list: deadrats, Stears555, marcorocchini
Since you have asked the same question in another thread, I'll close this one.
Please do not cross post. Continue in: https://forum.videohelp.com/threads/381818-Help-me-How-to-use-MKV-CUTTER
Moderator redwudz
Help me: How to use MKV CUTTER?
By minegroasprilla in forum EditingReplies: 8Last Post: 25th Jun 2017, 03:41 -
Webm/MKV file crashes on Machete edit-save and makes mess in Avidemux
By gumbygum in forum EditingReplies: 6Last Post: 19th Mar 2017, 14:44 -
edit and save idx/sub (vobsub) files
By KamikazeBE in forum SubtitleReplies: 5Last Post: 4th Nov 2014, 03:40 -
Edit .ts video, save for iTunes
By lschwarcz in forum Newbie / General discussionsReplies: 2Last Post: 11th Nov 2013, 10:29 -
Best mkv editor (+ effects + save as mkv)
By thinredline in forum EditingReplies: 1Last Post: 29th May 2013, 08:57
