hi, i used the h265 codec for a video, but it needed 10 minutes for rendering 2 seconds, and after that i could not open the video. when i opened it, there was only a black screen, the video did not play. why?
AnonymousGuest
H.265 require approximately (at least) over 16 - 32 time more computing power to encode video data.
Black screen may be outcome of few things but for sure you need to have proper H.265 decoder installed on your system - as you didn't provided any information on this there is no way to help you. -
AnonymousGuest
Thanks, what exactly on information do you need? The H265 is installed in the videoeditor I use. ALSO: when i try to delete the files, the message "com surrogate has stopped working" appears. And i cant delete the files. And the files do not have a thumbnail picture.
yep, x265 is really slow unless you have uberpowerful, modern hardware. methinks you have an older, slower system at that fps. system specs pls.
AnonymousGuest
Help with ffmpeg settings H265
By remainz in forum Video ConversionReplies: 1Last Post: 8th Jun 2016, 13:54 -
Codec question H265
By ro2124 in forum Newbie / General discussionsReplies: 16Last Post: 4th Dec 2015, 12:14 -
H265 encoding on Solaris
By tola5 in forum Video ConversionReplies: 3Last Post: 8th Feb 2015, 21:29 -
Sony Vegas no longer reading my Lagarith Codec videos?
By DarkShadowRage in forum EditingReplies: 24Last Post: 29th Dec 2014, 13:57 -
Youtube H265
By raphaelolaguer in forum Newbie / General discussionsReplies: 6Last Post: 15th Feb 2014, 04:58
