I'm going to capture some VCR video to my computer to convert to a DVD.
When you convert a VCR video to DVD format, I assume it converts the VCR video into 720 by 480. However, I don't think the original quality of the video is truly increased.
So with all the advancements in software that has been made over the years, is there anything that will truly increase the quality of a VCR video to DVD 720 by 480 or even higher especially if you could play your video on 40 or 60 inch screens through a flash drive since many TV monitors will play back different video formatted files from a USB connected flash drive.
You can upscale the VHS capture to HD no problem with something like nnedi3_rpow2() for high quality upscaling. Will extra detail be added, no it's just a good upscaler. While you capture VHS at the same resolution as DVD (720x480) it's still certainly below DVD quality. With its very low chroma bandwidth, and the medium itself being very noisy.
Maybe you can talk about your VHS capture set up. -
The other thing that VHS generally benefits from is deinterlacing with a quality tool like QTGMC especially if you keep all the frames.
Improve blurry low quality video into clear high quality video.
By Osram123 in forum Video ConversionReplies: 2Last Post: 4th Apr 2016, 01:48 -
Capture high-quality video from VCR
By APATEC in forum Capturing and VCRReplies: 3Last Post: 26th Jun 2015, 20:24 -
how to remaster an old video into High Definition?
By kenny1999 in forum Newbie / General discussionsReplies: 8Last Post: 9th Jan 2015, 17:28 -
Confused about High Definition video capturing and editing. Please help.
By Ashfaqul Taposh in forum Newbie / General discussionsReplies: 16Last Post: 27th Apr 2012, 13:48 -
Is there an easy way to burn a ts high definition video file to blu ray?
By JBIIRockets in forum Blu-ray RippingReplies: 25Last Post: 22nd Feb 2012, 10:51
