Results 1 to 11 of 11
  1. I've installed Lagarith codec from the official website. However, XMediaRecode can't see it. I don't know how to use command line programs. I just need to convert videos as fast as possible to a lossless/i-frame format to use as intermediates to edit on Sony Vegas 12 (build 770) 64-bit, since mjpeg is not working so well for me. What's the best way? Which file extension should I use to work better on Vegas?
    Edit: MediaInfo
    General
    Complete name : C:\Users\Me\Desktop\Video_1.MOV
    Format : MPEG-4
    Format profile : QuickTime
    Codec ID : qt 2007.09 (qt /CAEP)
    File size : 3.97 GiB
    Duration : 8 min 52 s
    Overall bit rate : 64.1 Mb/s
    Encoded date : UTC 2016-11-09 16:14:55
    Tagged date : UTC 2016-11-09 16:14:55
    com.apple.quicktime.make : Canon
    com.apple.quicktime.model : Canon EOS 70D
    Video
    Format : AVC
    Format profile : High@L5.1
    Format settings, CABAC : No
    Format settings, ReFrames : 1 frame
    Format settings, GOP : N=1
    Codec ID : avc1
    Bit rate mode : Variable
    Bit rate : 62.5 Mb/s
    Width : 1 920 pixels
    Height : 1 080 pixels
    Display aspect ratio : 16:9
    Frame rate mode : Constant
    Frame rate : 29.970 (30000/1001) FPS
    Color space : YUV
    Chroma subsampling : 4:2:0
    Bit depth : 8 bits
    Scan type : Progressive
    Bits/(Pixel*Frame) : 1.006
    Stream size : 3.88 GiB (98%)
    Language : English
    Color range : Full
    Color primaries : BT.709
    Transfer characteristics : BT.709
    Matrix coefficients : BT.709
    Audio
    Format : PCM
    Format settings, Endianness : Little
    Format settings, Sign : Signed
    Codec ID : sowt
    Bit rate mode : Constant
    Bit rate : 1 536 kb/s
    Channel(s) : 2 channels
    Sampling rate : 48.0 kHz
    Bit depth : 16 bits
    Stream size : 97.5 MiB (2%)
    Language : English
    Other
    Type : Time code
    Format : QuickTime TC
    Time code of first frame : 23:51:29;17
    Time code, striped : Yes
    Language : English
    Bit rate mode : CBR
    General
    Complete name : C:\Users\Me\Desktop\Video_2.MOV
    Format : MPEG-4
    File size : 1.15 GiB
    Duration : 2 min 36 s
    Overall bit rate : 63.2 Mb/s
    Encoded date : UTC 2016-11-09 16:23:48
    Tagged date : UTC 2016-11-09 16:23:48
    Video
    Format : AVC
    Codec ID : avc1
    Bit rate : 61.7 Mb/s
    Color space : YUV
    Bit depth : 8 bits
    Bits/(Pixel*Frame) : 0.993
    Stream size : 1.12 GiB (98%)
    Language : English
    Color range : Full
    Audio
    Format : PCM
    Codec ID : sowt
    Bit depth : 16 bits
    Stream size : 28.6 MiB (2%)
    Language : English
    Other
    Type : Time code
    Time code of first frame : 00:00:22;03
    Language : English
    Bit rate mode : CBR
    Last edited by Clever Sleazoid; 27th Nov 2016 at 03:31. Reason: Lack of information about the videos I'm working with
  2. Avoid Lagarith please. If possible use UT Video instead.
    EDIT this may be the source of the glitch problem you mention here.
  3. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Virtualdub should be able to do it.
  4. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    use DNxHD...I use it for everything.
    'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  5. Originally Posted by raffriff42 View Post
    I was using mjpeg and even the raw files... it didn't work, videos keep glitching. For real, I've never managed to use Lagarith, so thanks for the tip. I will try UT video if I can use it with my programs.
    Virtualdub can't open my files... (their info from MediaInfo are on the thread which raffriff mentioned). Anyways, I've never managed to use VirtualDub or VirtualDubMod properly with any files. I am starting to suspect that something is wrong with my laptop, seriously. Even after formatting my HD I was never been able to make them work.
    I've tried it. My Vegas couldn't read or import it. By the way, it makes files too large.
  6. Dinosaur Supervisor KarMa's Avatar
    Jul 2015
    US
    Virtualdub can only really open certain formats in AVI. Like Divx/Xvid, lossless formats, and MJPEG. We just don't know what your starting with.
    And I've never had any problems with Lagarith.
  7. Member DB83's Avatar
    Jul 2007
    Scroll down the vd page and install the input plug-in to suite your source.
    When you then go to open your video in vd, you select that plug-in rather than the default source (avi etc.)
    But then, if Vegas reads your files correctly, Vegas can also export to an intermediate format such as lagarith.
  8. Try Grass Valley HQX as an intermediate. There is a converter utlilty as well which may be able to accept your original files. You can download the codec and utility from the links on THIS PAGE of my 'slo-mo' guide..or from Grass Valley direct, if you prefer..
  9. Try turning off the null frame option in lagarith. That might cause problems with some readers/decoders.
    But I suspect the real problem is reading your original h.264 MOV file. Frames are getting out of order while reading it and your Lagarith compression isn't the problem.
  10. Rancid User ron spencer's Avatar
    May 2005
    Ish-ka-bibble
    Clever Sleazoid:
    Vegas reads them perfectly well. What version do you have? Yes they are BIG, but everything can edit them. I thought "what am I doing" when I started to use them, but in reality, there really is nothing better, other than the huge files sizes.
  11. aBigMeanie aedipuss's Avatar
    Oct 2005
    666th portal
    personally i always use sony yuv when working exclusively with vegas. it will even do no re-compression rendering when possible going yuv -> yuv when editing a video piece by piece.
