Some time ago, I started this thread: https://forum.videohelp.com/threads/373770-Sony-Vegas-glitching-videos-while-editing
I've learnt to convert videos to lossless or i-frame intermediates (by using XMediaRecode to convert them to mjpeg .mov files) in order to make them stop to mess their frames, since they changed places every time I did something. By converting them to i-frame intermediates, frames still changed places, but I could easily remove them or change their places in order to make a good resulting video.
However, through the time, I've realized I hadn't solved the whole problem. Frames are still getting messed up, and that's very frustrating, especially for long editings with few files, even if I can remove the wrong frames. Why can I definitely stop that problem?
I use Sony Vegas Pro 12 (Build 770) 64-bit.
Those are the raw videos I am actually trying to edit:
General
Complete name : C:\Users\Me\Desktop\Video_1.MOV
Format : MPEG-4
Format profile : QuickTime
Codec ID : qt 2007.09 (qt /CAEP)
File size : 3.97 GiB
Duration : 8 min 52 s
Overall bit rate : 64.1 Mb/s
Encoded date : UTC 2016-11-09 16:14:55
Tagged date : UTC 2016-11-09 16:14:55
com.apple.quicktime.make : Canon
com.apple.quicktime.model : Canon EOS 70D
Video
Format : AVC
Format profile : High@L5.1
Format settings, CABAC : No
Format settings, ReFrames : 1 frame
Format settings, GOP : N=1
Codec ID : avc1
Bit rate mode : Variable
Bit rate : 62.5 Mb/s
Width : 1 920 pixels
Height : 1 080 pixels
Display aspect ratio : 16:9
Frame rate mode : Constant
Frame rate : 29.970 (30000/1001) FPS
Color space : YUV
Chroma subsampling : 4:2:0
Bit depth : 8 bits
Scan type : Progressive
Bits/(Pixel*Frame) : 1.006
Stream size : 3.88 GiB (98%)
Language : English
Color range : Full
Color primaries : BT.709
Transfer characteristics : BT.709
Matrix coefficients : BT.709
Audio
Format : PCM
Format settings, Endianness : Little
Format settings, Sign : Signed
Codec ID : sowt
Bit rate mode : Constant
Bit rate : 1 536 kb/s
Channel(s) : 2 channels
Sampling rate : 48.0 kHz
Bit depth : 16 bits
Stream size : 97.5 MiB (2%)
Language : English
Other
Type : Time code
Format : QuickTime TC
Time code of first frame : 23:51:29;17
Time code, striped : Yes
Language : English
Bit rate mode : CBR
General
Complete name : C:\Users\Me\Desktop\Video_2.MOV
Format : MPEG-4
File size : 1.15 GiB
Duration : 2 min 36 s
Overall bit rate : 63.2 Mb/s
Encoded date : UTC 2016-11-09 16:23:48
Tagged date : UTC 2016-11-09 16:23:48
Video
Format : AVC
Codec ID : avc1
Bit rate : 61.7 Mb/s
Color space : YUV
Bit depth : 8 bits
Bits/(Pixel*Frame) : 0.993
Stream size : 1.12 GiB (98%)
Language : English
Color range : Full
Audio
Format : PCM
Codec ID : sowt
Bit depth : 16 bits
Stream size : 28.6 MiB (2%)
Language : English
Other
Type : Time code
Time code of first frame : 00:00:22;03
Language : English
Bit rate mode : CBR
Are your project properties set to 29.97 frame rate?
Have you tried editing the MOV files natively? The container isn't as bad as AVI for long GOP formats.
Many people edit Canon DSLR footage natively in vegas without issues. I'm beginning to suspect something is wrong with either your software install or your hardware setup. Also try disabling GPU acceleration , it can cause problems for some people in vegas -
Yes, I did try it. You may be right. There's something obscure about my laptop, not just because of that problem. There is a lot of other problems I got when I am handling videos.
Buuuuuuuuuuuuuuut... disabling GPU acceleration solved all my problems with my editing! There isn't a single frame out of place now, and I didn't need to re-edit my project or to make any conversions! And I had converted those files to various other formats, without solving the issue.
You must be some kind of editing god, since it's not the first time you pinpoint the solution for a problem with my editings. Thank you so much!Last edited by Clever Sleazoid; 27th Nov 2016 at 00:39.
The GPU issue is fairly common issue with vegas. Vegas's GPU implementation is very buggy
But the long GOP in AVI issue(s) are also very common in all programs (not just vegas) . Personally, I would convert AVI videos to I-frame before editing as suggested in your other thread. Way too many headaches otherwise. But the MOV or MP4 container is fine with AVC. Very rarely any problems related to mixed up frames and such. Since you still had problems after converting to I-frame with those videos in the other thread, it must have been the GPU issue on your setup as well
How to use sony vegas to process videos
By achy635 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2016, 16:55 -
Sony Vegas glitching videos while editing
By Clever Sleazoid in forum EditingReplies: 19Last Post: 9th Sep 2015, 15:23 -
Quality Problem When Using Sony Vegas to Edit
By newsgroup guy in forum EditingReplies: 13Last Post: 9th Jan 2013, 04:16 -
Sony Vegas 11 GPU rendered videos look terrible, help!
By Mitalis in forum EditingReplies: 1Last Post: 29th Sep 2012, 00:34 -
Sony Vegas Platinum 8.0 Vs 10 + using Vegas to edit AVIs + converting AVIs
By jonford in forum Newbie / General discussionsReplies: 1Last Post: 10th Jul 2012, 15:16
