That sounds a very logical approach. Except that.....
The WD Passport Ultra is not compatable under WinXP. Or so the box tells me.
Results 31 to 40 of 40
Update:
Just installed that on Win7. All drives/volumes/partitions seen.
Currently creating the image for the OS partition. Estimated total completion time is 25 mins (67 gig) -
^^ There was no compression. All files/folders could be seen. And as I stated, if I had had the patience to see it though then I doubt if I had seen the Windows folder since it was listed in the exceptions list.
The trial with Terabytes has completed in 29 mins. Since I have a slow system and other things are happening I am quite happy with that. The HDD is on order so I'll be crossing fingers, thumbs, legs and any appropriate parts of my anatomy when I come to attempt the restore. -
LOL! Sounds like user error to me. Restoring an image is equivalent to the old DOS command format c: /s (should only be used by experts). FWIW, O&O is updated constantly (I am currently two versions behind), so I imagine the version you used was ancient. I need an image program that comes with a Pre-Install Environment. I am constantly nuking my OS and reloading custom images I build. With modern SSDs, the process takes literally just a few minutes.
In truth, I never image my data drives. That is what incremental backup software is for (very different than imaging). But I don't even do that anymore. I just write out my data to DL BD-R now.
Bottomline, I am no longer a prisoner of any of my drives. If a drive starts to malfunction, I just yank it and get a warranty replacement. No hesitation. Reload the image or data as needed from the BD-R. I have a LOT of data burned to BD-R. The thought of all that data sitting on spinning rust just gives me shivers. -
I have an IDE ssd installed in my ooold toshiba laptop (xp home). Goes like a rocket compared to hdd.
XP is not dead!! They are tryin, but they cant kill it!!
I have used pwfree to clone multiple times with no problems. I have used acronus but didnt really like it. Only cloning problems were with newer laptop w/ W-7 on it. <- & the problem was cloning an ssd.
-c-Yes, no, maybe, I don't know, Can you repeat the question? -
Didn't mean XP was dead, but support for it is, so no new updates that could improve SSD capabilities.
I'll add Terabyte Image for Windows to that list. This morning I attempted to create an image of the 'troublesome' partition and the program coughed as soon as it hit some bad sectors.
Resorted to a plain 'n simple folder-by-folder/file-by-file copy to the passport drive. Ignored the inaccessible folder(which drew my attention to the potential issues with the drive in the first place) and the rest appear to have transferred fine. -
correct !! even firefox will end support for XP next year - http://www.myce.com/news/firefox-53-marks-end-support-windows-xp-vista-80548/
In the distant past, if my spinning rust was choking and on its last legs, my go-to rescue plan was a Knoppix boot CD/USB. Mount the drive then copy-paste just as you did. Knoppix would mount when Windows would often fail. I still keep a CD around just in case although I haven't had a need in a long, long time.
HDD Data Recovery - from Pioneer DVR-530H-S failed hard drive
By fortisMilvus in forum DVD & Blu-ray RecordersReplies: 17Last Post: 15th Feb 2025, 03:20 -
lg hdd/dvd recorder lrh-880-how to copy/record from disc/hard drive
By waynebyron7 in forum FeedbackReplies: 2Last Post: 5th Mar 2015, 14:33 -
Hard Drive of Philips HDD 3455h is broken, how to replace it?
By 1234567 in forum DVD & Blu-ray RecordersReplies: 2Last Post: 2nd Jan 2014, 13:46 -
Backing up HDD
By R.A.J. in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jun 2013, 18:09 -
Backing up Hard Drive
By didikai in forum Newbie / General discussionsReplies: 10Last Post: 26th Jan 2013, 11:43
. But, because we are only human, we make mistakes and pay for that, and also learn.
