Trying to find a good one. Tried YAMB, but it muxes a 29.97fps video at 25fps, ruining sync. MP4Multiplexer works perfectly up until about halfway through the clip at which point the audio stops, then starts from the beginning while the video continues on.
Results 1 to 9 of 9
You've mistaken me for someone who can use a CLI.
Nonetheless, after a bit of Googling I tried this:
Code:mp4box -add track1.h264:fps=23.970 -add track2.m4a#audio -new res.mp4
I have no idea how to find muxer.exe or use ffmpeg to mux. Google is no help on either front. -
My-MP4Box-GUI
https://www.videohelp.com/software/My-MP4Box-GUII love it when a plan comes together! -
Evidently not; it crashes every time I try to start muxing.
Found this:
Code:ffmpeg -i audio.m4a -i video.h264 -acodec copy -vcodec copy output.mp4
I can confirm that I use the MP4Box cli all the time to mux .264 and .aac streams at 29.97 fps without a hitch. Fast and easy. In fact, it is an integral part of my workflow when I am generating content for the wide world webs. I don't recall the exact cmd because I am not at my PC, but I can guarantee it is plain vanilla, nothing fancy, and works every time. If you are having problems, I would suspect the input files are the problem, not MP4Box. How are you generating your audio stream? Perhaps you can post short synced clips of each, and someone here can try to mux?
Homemade mp4 files quality vs. ripped movies in mp4 format
By MrMX in forum Newbie / General discussionsReplies: 11Last Post: 26th Nov 2015, 22:12 -
Plain English Guide to MP4Box and Repacking MKV-MP4, MP4-MP4 (M4V).
By raregrit in forum Video ConversionReplies: 3Last Post: 8th Jul 2013, 12:52 -
SUPER converter: difference between MP4 file and Android (MP4)?
By mindstormer in forum Video ConversionReplies: 12Last Post: 30th Jan 2013, 05:15 -
Cannot seem to convert MKV to MP4 or AVI to MP4 without audio sync issues
By Matth3w in forum Video ConversionReplies: 0Last Post: 16th Sep 2012, 13:36 -
which 'create DVD from MP4" app for Mac that takes any kind of MP4?
By callagga in forum Authoring (DVD)Replies: 1Last Post: 25th Jan 2012, 19:46
