I'm trying to use AmaRecTV with a Diamond VC500 via composite video to capture some Hi8 tapes for restoration and editing. However, there is a perpetual issue plaguing every capture.
When watching the playback through the viewfinder on the Hi8 camera, the picture is smooth, steady and free of interference of any kind. However, when I play back the video through AmarecTV, the picture continually has some kind of flickering 'breakthrough' of red and green in the image, and the picture sometimes offlocks entirely. Here are five consecutive frames from one such tape demonstrating the issue (click for full size):
This is a relatively minor example; sometimes the picture breaks up entirely and is a complete mess. The issue is less prevalent when the video is still (for example, it was shot on a tripod). However, the red/green flickering still occurs.
Does anyone know what is causing this and how I might rectify it? A while back I dubbed some Hi8 tapes onto miniDV using the DV camera's AV in jack and those digital dubs exhibited none of these problems. Sadly, I no longer have access to that camera and have had to resort to this method.
Thank you to anyone who may be able to help.
Results 1 to 10 of 10
Do you see these artifacts during capture? What camera output are you using? Have you ruled out the cable as a source of the problem?
Yes, the artefacts are there during capture. I am using the Hi8 camera's compososite out. It's a brand new cable, too
Does your camera have an s-video output? You will get a better picture and you might be able to bypass the bad output/cable.
Well, you could still try a different cable. I've had brand new bad cables that took up oceans of my time until I thought to suspect them. Other ideas: bad connector or output circuitry on the camera, VC500 wants signal conditioning (standalone or DVD recorder's TBC/frame sync), software goofiness. What encoder/file format are you using?
Did you find a solution for this issue. I'm hitting the same problem while capturing and can't figure out how to get it working.
I actually gave up and returned it. I have no idea how anyone is getting anything out of this bit of kit. Sorry I cannot be of more help
The VC500 requires the use of a TBC. That's all it is.
https://forum.videohelp.com/threads/383391-White-single-frame-flashes-VHS-capture
https://forum.videohelp.com/threads/383160-jitter-on-capture-but-not-on-tv (one of the devices sold as Elgato uses the same chip as VC500)
VirtualDub not detecting Diamond VC500
By Xoanon in forum Capturing and VCRReplies: 8Last Post: 27th Jul 2016, 20:30 -
video quality issues - Diamond vc500
By brwalter in forum Capturing and VCRReplies: 9Last Post: 29th Jan 2016, 10:39 -
video quality issues - on a Diamond vc500
By brwalter in forum Newbie / General discussionsReplies: 1Last Post: 25th Jan 2016, 14:20 -
Diamond VC500 One Touch Capture Device problems
By ZEROthefirst in forum Capturing and VCRReplies: 18Last Post: 26th May 2015, 14:35 -
Diamond VC500 - install problems with Windows 7
By ry1633 in forum Capturing and VCRReplies: 12Last Post: 17th Feb 2015, 16:08
