Hello everybody,
I'm using MKVToolNix GUI (V.9.2.0) to mux a mkv file with chapters.
After creating a chapter file (in format "chapters.xml"), I add that chapter file in MKVToolNix GUI and start muxing, and then the muxed mkv file with the added chapters works fine by softwares on PC (such as MPC, WMP, I easily click next forward to select a chapter) but it does not work on BD player. On BD player when I click next forward, the screen becomes froze; nothing happens!
Why? Anyone knows what problem is here, please help?
In the window of Output of MKVToolNix GUI, what I should set on section "Chapters" to get mkv file working well on BD player?
Thanks in advance.
Do you have the problem with all mkv files that have chapters included or only some? If it's the latter try: https://forum.videohelp.com/threads/379188-Seek-issue-on-my-mkv-file
Hi, sneaker,
I have the problem with both mkv files including chapters and without chapters. Let me try the threads you gave above and will inform you the result later. Thanks for your respond. -
Hi, sneaker,
It's great, the problem is solved! Just follow your guidethe chapters work fine on my BD player (for both chapters included in mkv file and new chapters created from mkv file)!MKVToolNix GUI->Preferences->Merge->Default Values. Enter into field "Default additional command-line options":
--clusters-in-meta-seek --disable-track-statistics-tags --engage no_cue_duration --engage no_cue_relative_position
Videohelp.com is an amazing website, very helpful for everyone, who loves video and moives!
Thank you, sneaker. Thank you, videohelp.com!
mkvmerge gui is corrupting my mkv files when muxing
By steve1232 in forum Newbie / General discussionsReplies: 51Last Post: 25th Feb 2022, 11:46 -
MKVToolNix GUI - Added chaprter in mkv file not work on BD player. Why?
By anhlinhp4 in forum Authoring (Blu-ray)Replies: 1Last Post: 22nd Jun 2016, 23:24 -
MKVToolNix GUI v8.9.0 issue with timecodes
By Han Solo1 in forum Newbie / General discussionsReplies: 6Last Post: 13th Mar 2016, 18:55 -
Why mkvmerge (mkvtoolnix) shortens files when muxing ?
By Marus Nebunu in forum Video ConversionReplies: 3Last Post: 25th Jun 2014, 06:27 -
gui for mkv to mp4 muxing on windows 7?
By Ofek in forum Newbie / General discussionsReplies: 6Last Post: 19th Dec 2013, 23:32
