I have a movie in mkv format in a samba server. Its bit rate is 2200kbps. I try to play it on my smart tv via network share. It can be played but I try to seek to a certain point. For example seek to 40min position. It will go back to the position before seek. Very strange. Anyone can help? Thank you so much.
Try newest MKVToolNix GUI->Preferences->Merge->Default Values. Enter into field "Default additional command-line options":
--clusters-in-meta-seek --disable-track-statistics-tags --engage no_cue_duration --engage no_cue_relative_position
(see FAQ for more info)
After that open your file and remux. Then try again.
Audio Sync Issue Converting MKV to File Folder Structure Using AVStoDVD
By Polotzka in forum Newbie / General discussionsReplies: 1Last Post: 23rd Sep 2015, 02:05 -
Strange issue with an mkv file.
By Anand08 in forum DVD & Blu-ray PlayersReplies: 1Last Post: 28th Jan 2015, 14:29 -
Cannot Seek/Fast-Foward MKV Video
By cebao in forum Newbie / General discussionsReplies: 4Last Post: 26th Apr 2014, 20:13 -
Dolby Digital Plus issue - AC3 instead of E-AC-3 in MKV file
By psychoboust in forum AudioReplies: 9Last Post: 20th Jan 2014, 08:08 -
Blu-Ray to MKV with forced subtitles - Size of file not issue
By rajsharma714 in forum Blu-ray RippingReplies: 3Last Post: 16th Nov 2012, 22:25
