Hello guys, i would like to put my ssa subs as an option on dvd movie... I used the convertxtodvd and did what i wanted but the quality of subs isnt that great.. Is any other program or combinations of programs that can help me?
MaestroSBT takes SSA subs as input and can output subs in SST format looking the same. Then use those SSTs in Muxman along with your DVD-compliant audio, video, and chapters as a celltimes.txt file to author a new DVD. Fix the colors afterwards in DVDSubEdit or PGCEdit.
If using your ConVertX DVD as a source, demux audio, video, and celltimes.txt using PGCDemux. Then, after creating the subs reauthor as described above.
That'll never happen. They have to be converted to a subtitle format acceptable to your authoring program.Hello guys, i would like to put my ssa subs as an option on dvd movie... -
well the only thing that i want is to have subs for my video as an option not sticked in the video and the other thing is to have them wherever i want (position).. is that possible? cuz i made them with convertxtodvd and the only thing i dont like is the quality the rest i wanted i nailed them
Okay, now I understand. The word is 'Selectable'. You want them selectable - able to be turned on and off. And that's what you'll get. But they won't be SSA subs. Those are text-based and DVD subs are graphics-based. They have to be converted to DVD-compliant subs. Any authoring program will either convert them or accept subs already in the particular graphics-based format they require.
That's why I suggested MaestroSBT - because you can make them to look any way you like. -
To hopefully save manono any additional typing, he answered all your questions in this post from July 2015: https://forum.videohelp.com/threads/373192-How-do-I-burn-DVD-with-custom-subtitles-and-...-position-font
@manono
There...now you have additional free braincells to answer some of MY questions. <GRIN> -
Hehe, thanks. And somewhere around here are complete guides for the use of MaestroSBT.
How can i put permanent subs into a video?
By LegendEpic in forum Newbie / General discussionsReplies: 3Last Post: 10th Nov 2015, 06:21 -
How do I convert DVD subs into BD subs?
By Patapin in forum SubtitleReplies: 2Last Post: 3rd Oct 2015, 12:26 -
Fastest method to add .ass (ssa, aegisub) SubStationAlpha subs to mp4?
By mateuszn0 in forum SubtitleReplies: 2Last Post: 18th Dec 2014, 15:51 -
Burn styled .ASS/.SSA anime subs to MP4
By taebog in forum SubtitleReplies: 7Last Post: 29th Jun 2014, 03:30 -
MKV w/SSA/ASS soft subs to MP4 w/hard subs using Format Factory
By Budman1 in forum Latest Video NewsReplies: 0Last Post: 13th Oct 2012, 00:59
