According to Jeff Bellune here, Advanced Frameserver is much, much better than DMFS ever was. However, I am surprised it is not listed under the Video Frameservers on VH.
Does anyone have any experience using AFS? And why isn't it hosted on this site?
TAA
Results 1 to 12 of 12
Frame server either works or does not. It depends on NLE version as well. I use Vegas 8.1c and no problem whosoever. Vegas 10, gives me a problem with audio, after frame server is ran once , audio does not work and frame server needs to be restarted for other encoding. So if I want to encode couple of versions over night, audio is pre-rendered and batch script handles all that.
I use Sony Vegas so I cannot try Advanced Frameserver, and website is in Russian. After translating, I gathered that served avi could be played over LAN, which would be a great feature. Imagine playing your NLE timeline on big screen in your living room. I tried to make it work in the past with regular dmfs and I was not successful. It would be nice to know if it works like that with that Advanced Frameserver.Last edited by _Al_; 19th Mar 2016 at 13:05.
I know, I just pointed into that NET encoding/ perhaps possible playback over LAN feature, so YOU could look into it if there is an interest. And that fact that frame server either works or not.
To watch edited video in living room, or much bigger screen, in different , calm and comfortable environment, one can usually catch more editing mistakes before final render.Last edited by _Al_; 19th Mar 2016 at 13:23.
According to the site you linked to, it is based on the Debugmode FrameServer and is optimized for 64-bit for use in PP only. I don't use Premier, so can't test it out. Since you use PP, why don't you test and compare the two frameservers and make recommendations based on your findings?
I seriously doubt one is much greater than the other. A 64-bit version would help on 4k+ sources maybe....Got my retirement plans all set. Looks like I only have to work another 5 years after I die........ -
Here is something interesting. AFS offers the following export formats:
- RGB
- YUY2
- UYVY
But here are some questions:
Is there another workflow that I am not considering for the resulting signpost.avi? I tried opening that directly in ffmpeg. Maybe I didn't do it right? I am basically just trying to avoid a pathway that requires YUY2 conversion, if possible. -
After frameserving out of PP as UYVY and loading the signpost using QTInput() and transcoding to UYVY with ffmpeg, the transcode is lossless! Fantastic! A new lossless workflow to add to my arsenal!
All frameservers are lossless. I don't get what you are trying to say. If you applied any filters in your NLE, then it got converted to RGB. Vegas works only in RGB, I don't know about Premier. Sounds like you are making a big deal about nothing to me.
Just read the Lossless Worklows thread in my sig and you will know what I am talking about.
Using Vegas, that works in RGB, thus 100% lossless out is really not 100% anyway, because there is always YUV to RGB right there since the beginning. So,
YUV loaded into Vegas -> RGB out using frame server -> then changing it into UV12 in Avisynth
But Premiere COULD behave like that as well if particular filters are applied. Not sure how many or what those filters are, poisondeathray brings this subject every now and then. If that is true, then it is similar like in Vegas, trying to be exact with already rounded up numbers. If you know about this, never mind, just bringing this up. If you just cut video, original suppose to be intact. -
I can't speak to Vegas, but there are lossless YUV pathways through PP. They all require UYVY versus YUY2 or YV16 even though they are all 4:2:2, iow technically the same just as 1+2+1, 1+1+2, and 2+1+1 are the same. I should also add that DV AVI YUV 4:1:1 is lossless through PP. But unfortunately for whatever reason, PP does not treat YUY2 and YV16 the same as UYVY. And of course, frameserving a YUV source as RGB out of any NLE will result in the lossy YUV -> RGB conversion. But then frameserving a YUV source out as YUY2 is not lossless either. As a result, I have deleted DMFS entirely from my build, so I can't even test it any more.
I am a happy Advanced Frameserver user, now frameserving my video as UYVY.
L-SMASH not loading Debugmode Frameserver
By SameSelf in forum Video ConversionReplies: 2Last Post: 26th Feb 2016, 21:24 -
Interlaced video from Vegas to Ripbot via frameserver
By lonrot in forum Video ConversionReplies: 24Last Post: 1st Jul 2014, 21:33 -
[Guide] Using DMFS on Windows7 64bit (with Sony Vegas Pro 10 64bit)
By Luponius in forum User guidesReplies: 20Last Post: 19th May 2014, 12:55 -
Virtualdub as frameserver?
By marcorocchini in forum Newbie / General discussionsReplies: 8Last Post: 18th Oct 2013, 16:50 -
Premiere 6.5 + Debugmode frameserver work on Windows7
By pchan in forum EditingReplies: 1Last Post: 29th Aug 2012, 08:01
