Why would my Panasonic DMP-BD60 playback HD Blu-ray BDMV (MPEG2) burnt onto BD's (BD-R), but won't play HD Blu-ray BDMV (AVC) burnt onto BD's (BD-R)? All I get is audio with the AVC.
My Sony BDPS390 will play both without issue.
How do you convert, author and burn on BD-R?
What is your video source?
Some players are very picky about the blu-ray avc format. Like correct frame size/resolution, avc encoding profile, etc. -
Thanks for your reply.
In the case of MPEG 2, I am just using TMPGenc Authoring Works to Convert/Author
With AVC, I am capturing with Hauppauge HDPVR, I am using VideoReDo to edit, and then TSMuxer to author
In both instances I am using ImgBurn to burn to BD-R. -
I'm having similar issues myself; see my thread at
https://forum.videohelp.com/threads/376887-AVCHD-DVD-produced-by-Powerdirector-works-bu...iAVCHD-doesn-t -
@ _brice
Panasonic players can be quite picky indeed.
You can try to load your (edited) video in multiAVCHD. Like johns0 said in the thread linked by Panash,
multiAVCHD will highlight the sourcefile in red when not meeting bluray/avchd standards.
Then you'll have to re-encode.
@ Panash
I remember having difficulties with tsMuxer errors within multiAVCHD.
Maybe replacing the tsMuxeR.exe file in multiAVCHD's tools folder with another/newer one will solve the issue?
cheers
Ennio -
There is a difference between long & short format - see my thread
Yep. So try author the avc with VSO Free AVCHD Editor and see if it plays in your Panasonic Player. Report back if it works!
And I think I have to add a note to the software tsmuxer page about this issue.
Playback issues
By efiste2 in forum Newbie / General discussionsReplies: 7Last Post: 29th Jun 2015, 13:09 -
mkvmerge append playback error when joining 2 mkv files from diff sources
By Owdrai in forum EditingReplies: 1Last Post: 26th Mar 2015, 11:53 -
Issues authoring a DVD...
By mjl1297 in forum Authoring (DVD)Replies: 13Last Post: 27th Jul 2013, 15:06 -
PLAyback Mode Issues
By akerekes in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 1Last Post: 8th May 2013, 23:23 -
16:9 Playback Issues
By DocD in forum Newbie / General discussionsReplies: 3Last Post: 4th May 2011, 00:12
